Question about Vacuums
Do i need to do anything special when replacing the brushes in a lamb ametek 117500 motor? It looks like I can just remove the old brushes and insert the new ones. Is it this simple? Will the motor work again? Thanks
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=758676
Generic problem for all Vacuums
Do I need to do
Posted by edkraynak on Jul 08, 2008
Do I need to do anything special when replacing the brushes in a lamb ametek 117500 motor? It looks like I can just remove the old brushes and insert the new ones. Is it this simple? Will the motor work again? Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Make sure they are the right carbon brushes for your particular lamb motor and once you have installed the new ones then there is a seating chalk that you place against the armature to help seat the carbon brushes, you can pick up the seating chalk @ your local vacuum cleaner store or contact Lamb / Ametek listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.ametek.com/contact/index.cfm
Customer Service – 610-647-2121
AMETEK Corporate Office
37 N. Valley Road, Building 4
P.O. Box 1764
Paoli, PA 19301 U.S.A.
Tel: 610-647-2121 Fax: 215-323-9337
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 09, 2008
Ametek 119697-00
There is a 14 Amp motor
119905-00
It is special order but it is powerful and will drop in to unit.
Jan 17, 2014 | Ametek Lamb 116158-01 Vacuum Cleaner Motor
Need wiring schematic for ametek 119550
I had the same problem after not paying attention to the connections when replacing my motor. I spent days searching for information and only found several non-answers with small photos that no one can read.I contacted Oreck for wiring information. They explicitly stated that they can't provide any wiring information for safety and liability reasons.
I found the Ametek schematic which shows the LINE and TAP locations on the motor.
Note: I have a 2600HH XL with 2 headlights.
Connect as follows:
3A, LINE: White lead w/piggy back terminal from light harness #1 & white lead from the power harness to the piggy back terminal
2A, TAP: Black lead from light harness #1
3B, LINE: White lead w/piggy back terminal from light harness #2 & black lead from the power harness
2B, TAP: Black lead from light harness #2
Dec 13, 2012 | Vacuums
Riccar model 8625 need compatible repalcement motor for original Ametek # 117405-00 12 amp no longer available ?
You can likely get any 8000 series motor to fit but there are different motors and you really need to talk to a qualified trained Riccar repair technician to determine the proper motor for your model. Your model is almost 30 years old and a newer motor would be difficult for the average homeowner to safely install. You were given good advice because they told you to discuss it with a qualified retailer for the proper way to safely get your vacuum running again. If done properly there could be many more years of usable service left I your old vacuum. If done wrong it could cause damage to the motor or other parts of the vacuum or even cause a fire, death or injury.
Jan 21, 2012 | Riccar Vacuums
Carbon brushes on ME-48 power head motor worn out. Where can I get replacement brushes? Motor is O 90197X7, Lamb, Model 118173-73 - 240V 50/60Hz
Hi Les,
Most sites sell only the motor.
Here's a website that includes motor brushes: http://www.kleen-ritecorp.com/search.aspx?IsSubmit=true&searchTerm=lamb+motor&gclid=CIbZ59zwiKgCFQprKgod8W2itQ
Hope you can find the right brushes.
I hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Apr 06, 2011 | Filter Queen Vacuums
I have a 20yr old electrolux central vac that the motor just went bad. in wondering whether to replace motor or replace whole unit i have found an electrolux unit and a aerus unit. someone told me elect....
Motor to replace or rebuild:
Depending if your motor just started to get noisy, you can take it to a private vacuum repair shop and most rebuild for around $80 to $100.00. Usually they replace top/bottom bearing and the armature carbon brushes.
If it's loud and vibrating and probably sparking. Do not bother to rebuild, the armature is now probably damaged and not worth the new parts.
Replacing the motor is pretty basic and usually saves you about $150.00. They're pretty simple to release out of the unit and are pretty simple to remove and reinstall.
To find out your replacement motor number you will need to find the stamped model number on the motor itselt. It is a 6-8 digit number. That is the Ametek Motor Model number. Ametek is used in pretty well all central vacuum systems. Motors range from $99 to $239.00
www.ametekfsm.com/Product_Compare.aspx?MT=1&MST=1&FanStyle=Bypass&Discharge=Tangential
Dec 30, 2010 | Electrolux Centralux Vacuum
How to change carbon brushes
You need to know that very seldom will new carbon brushes alone `FIX`a motor in todays vacuums as they are higher RPM than those of 30 years ago.
On a salvageable motor a good rebuild procedure will generally include repacking bearings, cleaning suction fans and reseating new brushes with an abrasive seating stone at low speed with a motor run in device with variable voltage
That said, I have not done a HENRY in years but it likely will contain a generic AMTEK Lamb type motor as it is sold as more durable vac.
On a traditional vac motor, carbon brushes are removed by releasing a clamp over the brush. The brush holder will have either a flag terminal on it where the wiring will disconnect from the side, or a flat flag terminal which slides into a pocket on the carbon brush housing.
. If you are going to the trouble of replacing the brushes, remove and inspect the old ones for wear and chipping. Also inspect the commutator surface on the motor where the brushes contact. If there are any curved gaps between segments, or if the com is worn like an apple core , you need a motor complete.
If the motor has simply worn to the point where a brush has stuck or worn to nothing, you may be bale to reseat the new brushes, however any evidednce of BLUE sparks or noise is not a good sign . Best of luck. Post back if you need more help
Nov 01, 2009 | Henry Numatic "" Canister Vacuum
Eureka canister vacuum cleaner Model 6865
The 6865 has a high rpm AMTEK Lamb motor, Brushes will seldom solve the problem at this stage.
Once the sparking and burning starts the conectiion between the brush and commutator is arcing and burning. If the sparks are blue, save your time.
A good service tech will run in brushes with a seating stone and a low voltage setup to allow new brushes to seat, but this is generally best accomplished on heavy duty , lower rpm motors.
IF YOUR ARMATURE IS SCRATCHY LOOKING OR WORN LIKE AN APPLE CORE,OR THE SEGMENTS ARE NOT PARALLEL IN THE SPACING YOU WILL NEED A NEW MOTOR.
Oct 16, 2009 | Vacuums
No power. electric is OK. system will not turn on. Please help
Detach the vac itself from low voltage thin wiring leading to the house. With the vac plugged into power, try the manual switch and then try shorting across the low voltage exterior terminals with a rubber gripped set of pliers.
If you can hear a clicking inside, this is the vac's relay trying to start the motor. If the vac is more than 5 years old , or used more than 2 hours a week, you may need new carbon brushes, or a motor overhaul or replacement depending on wear. Carbon brushes are specific to the motor model # inside the vac, most often an AMTEK Lamb motor.
If you need brushes, the motors comutator should also be inspected for excess,wear, like gap ing between its conatct segments and "apple core" shaped wear
You you have a meter and can test for continuity across the motor leads, do so and post back.
If you don't have a meter, you will likely want to lift the vac off the wall after these checks and take to a repair shop, saving $$$$ for a house call...
Oct 06, 2009 | Broan-NuTone CV353 Central Vacuum
Need to replace motor brushes on Kenmore canister vacuum 116.25914503 - Getting lots of arcing at brush ends. Need tear-down steps to get at the brushes.
If you can see the arcing you are likely in the motor housing. The brushes are specific to the motor depending on RPM. Most brushes and motors in Sears units are supplied by AMTEK Lamb. The color on the plastic housing and stamped model # on motor will help identify the correct carbon brush, however new brushes will NOT always solve your problem if the motor is arcing.
If the armature is worn like an apple core or if the lines between segments on the copper commutator are gaping and not parallel you will need a new or rebuilt motor.
If brushes are properly removed there is a tiny flag terminal which will slide out of most brush housings where the wire meets the brush itself. New brushes are best installed after dressing the armature surface with a fine carbarundum seating stone or very fine wet dry sandpaper and then the motor is run in at half speed at reduced voltage.
|There is usually a hold down clamp over each brush to seat it and a lock tab underneath to align the new brush.
Sep 30, 2009 | Vacuums
Kenmore progressive 300 smells like it is burning
These vacs use Ametek motors which are practically designed to fail. Frequent complaints are a burning smell and louder than usual noise in the canister. The problem is the poor quality
bearings Ametek uses in the motors in the units. They have low-end ball bearings with a nylon "crown" that breaks up and gums up the bearing. Further the fan end of the motor is a bear to get to because of poor (intentionally?) design. With great difficulty I WAS able to remove the fan and housing and inspect the bearing. Since finding a replacement is too much trouble or impossible, I cleaned up the ball bearings and switched the bearings on the two ends moving the remaining good one from the brush end to the fan end where I assume the load is. I packed the damaged one with grease.
Now the motor runs smoothly. I doubt however this jury rig will last very long. It is very irritating to toss a $120 motor because of a failed bearing. Kenmore and Ametek should be embarassed but I'm sure they are NOT!
Jul 15, 2009 | Oreck XL2200 Bagged Upright Vacuum
Vacuums Logo
211 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
