Question about Canon MP490 InkJet Printer
We are trying to remove ink cartridges on our Canon MP490. When the lid is lifted the cartridges stay on the right hand side and don't come to the middle. How do we get the cartridges to come to the middle?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 544 Answers
Close the lid.
Turn printer off then back on.
Open lid.
Cartridge holder should move to the middle.
Posted on Jan 02, 2011
How to change ink cartridge on nx220 printer
Turn the printer on.
Lift the lid, to expose the print-carriage and the print-heads.
Wait a few seconds, and the print-head (holding the ink-cartridges) will slide over to some point where you can remove the cartridge.
Push on the "holder" surrounding the ink-cartridge, to "unlock" it, and gently lift the ink-cartridge out. Insert the replacement, "lock" it in place, and close the lid.
Feb 09, 2015 | Epson Stylus 2200 InkJet Photo Printer
Hw do I open the MP490 canon printo to replace ink
With the printer plugged in and turned on, lift the entire scanner unit; you can lift it from just above the paper tray. Make sure that there are no documents on the scanner glass or in the automatic document feeder (if present). There is a support on the right side of the unit that will hold the scanner unit in place that will engage.
The ink cartridge carrier will move to the install ink position. Then replace the cartridge(s) and lift up the scanner unit then press the support in towards the printer. Then lower the scanner unit to close the printer. Wait until the printer stops charging the ink system before printing.
I hope this helps.
Jun 14, 2012 | Canon MP490 InkJet Printer
Cartridge Jammed in Canon MP520
Gently lift it out by pulling it toward you. Lift it up.
May 18, 2017 | Canon MP520 All-In-One InkJet Photo...
Reset ink level mp490
Hi
Open the printer cover.
Remove the ink cartridges and then reinsert them.
Mar 01, 2012 | Canon MP490 InkJet Printer
I want to change the black ink cartridge for my Canon MP 490 Series printer. Where are the cartridges located? I do not have a Manual
When you open your printer to see the inside of it (you open it either on the front or side) you should see the cartridge at the far right or left. If you still don't notice it then just print and it'll move from left to right as if it were scanning. That is your cartridge. You can take it out then. If it has a latch then lift it up, but other than that; that's all you need to do to change it. Oh and also sometimes if the ink gets low you can shake the cartridge a little.I hope this helps!!jessicascott.png
Jul 22, 2011 | Canon Office Equipment & Supplies
How do I remove the ink cartridge?
Lift the lid when the power is on and the ink cartridge carrier will centre itself then lift the cartridges out from the side nearest you first watch out for the bottom of the cartridge as it will still have some ink on it
Dec 21, 2010 | Canon iP100 Portable Printer
How to load a MP130 cartridge?
  • 1 Turn on the printer and check the LCD screen for an indication of which ink cartridges are low. Note that recycled ink cartridges sometimes read "Ink low" even when they still have ink, so print a test page if you're not sure.
  • 2 Expose the ink tray by lifting the entire LCD control panel, which is attached to the underside of the copier tray.
  • 3 Pull out the used ink cartridge by pulling straight up from the print head,
  • 4, insert the new cartridge into the print head and push down until you feel a click. Close the printer lid and let the printer reset the ink tray.
  • 5 Print a test page to make sure the new ink works. If it doesn't, you may have forgotten to remove the protective tab under the cartridge.
  • Nov 13, 2010 | Canon PIXMA MP130 All-In-One InkJet...
    How do you change the ink cartridges
    Lift the top part of the printer and then lift the black cover after the cartridges have moved to the centre of the printer. Then depress the clip that holds the desired cartridge in place and remove and replace.
    Oct 23, 2010 | Canon MP490 InkJet Printer
    How to change the ink cartridge in a Canon iP1900 printer please
    1•Protect your desk, printer stand or work surface by placing an old newspaper in front of or next to the printer. The newspaper will provide you with a place to work without getting ink anywhere you don't want it. It seems as though no matter how careful or neat you are, a little bit of ink always manages to escape when replacing an ink cartridge.
    •2
    Prepare the new ink cartridge for installation. Remove the replacement cartridge for your Canon printer from all of its packaging. You may need scissors to remove the heavy wrapper. Leave the protective orange cap or tape in place for now. Set the new cartridge aside on the newspaper.
    •3
    Remove the old ink cartridge from the Canon printer. With the printer on, open the front door or panel of the printer. Wait a second or two and the ink cartridge holder should move to the opening where it is accessible. If it does not move, shut the door, turn the printer off for a moment, turn it back on and try again. Lift the small lever that secures the ink cartridges within their holder. On most Canon printers, it is colored green and located on the right side of the ink cartridge holder. Gently lift the old ink cartridge out of the printer.
    •4
    Place the new ink cartridge in the printer. Remove the plastic cap or tape protecting the ink cartridge, being careful not to touch the black and gold "sensor" area of the cartridge. Gently but firmly push the new cartridge into the empty slot left where you removed the old ink cartridge. The label should be facing outward. You should feel the cartridge pop into place. Then push the lever back down that you lifted in Step 3. Close the printer door. Use paper towel or wet wipes to clean any ink from your hands.
    Aug 18, 2010 | Canon Office Equipment & Supplies
    Trying to change ink cartridge in canon pixma 3000
    Hi
    If you are replacing. Power on - lift top front lid of printer - wait till cartridges come to centre and stop FULLY. Lift clear tab at front of cartridge being replaced and remove cartridge. Insert new cartridge -press top fron down until clear tab clicks then shut top lid of printer.
    Then go Start-Programs- Printers select the Ip3000 priter icon, right click - select maintenance - selelct nozzle check and follow instructionson screen. You may have to do a deep clean (ee on screen) if the ink has dried a bit in the printhead.
    If tryinmg to refill the cartridge - unless you are an expert at it forget it - buy either genuine or quality aftermarket cartridges - No mess - no fuss - no ruined printer .
    Feb 19, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
    Canon MP490 InkJet Printer Logo
    479 people viewed this question
    old marine
    old marine
