Question about Microwave Ovens
How to unlock ariston induction cooktop - Microwave Ovens
Prestige induction
There may be an electrical issue causing the unit to lose its electrical insulation in time. This may as well be due to the heat.
A heat shrink tube -providing insulation- facing too much heat may may have melted.
If non of the above, try plugging in the other way -if possible, for European plugs, that is possible-. Or replace your faulty fuse / residual-current circuit breaker (RCCB)
Oct 28, 2013 | Microwave Ovens
Have no manual for my newly installed Electrolux Induction Cooktop
Hi judykeys,
Kindly specify the Model no. of the product to get a specific Manual..However plz try this link...Hope it works if not plz revert:
http://www.electroluxappliances.com/low/node51?aspxerrorpath=/low/kitchen-appliances/cooktops/induction/ew36cc55gs
Thanx
Aug 24, 2011 | Microwave Ovens
The induction cooker when put on it shows E6 after about a minute or so and no heating takes place.
There is a error message there, it indicate a problem with your induction cooker. It cause a defective winding wire or circuit controllers your know induction cooker works similar to the principle of electro magnet induction, it give heat to metal cooking pot. I hope I give you a idea regarding what happen to your unit.
Mar 23, 2011 | Microwave Ovens
My appliance is " prestige
Hello Nivedh 1991,
You are going to have to contact one of the service centers listed on the following link as they do not have any service manual or owners manual available form there corperate site. Here is a link to all of there service centers http://www.ttkprestige.com/contacts/servicecenters
Thank you for choosing FixYa.
Mar 06, 2011 | Microwave Ovens
I have a Brandt induction cooktop and 2 hotplates don't work at all and the other 2 now don't appear to be connecting with the saucepan. Heat light starts to flash then turns off completely. Unable to...
Sounds like a wiring problem,take off of course with no power and check it out. No harm if no power,and replace wire and or componet with same.
Jan 11, 2011 | Brandt Microwave Ovens
Omega Induction cooktop ITC1BB. Is it single pole or double pole switched?
Double pole switching should always be employed in items like this for safety.
Dec 14, 2010 | Microwave Ovens
Omega 0164BB induction cooktop
Here is a tip that will help you to get better results from your question on Fixya.
How to ask a question on FixYa
heatman101
Nov 21, 2010 | Microwave Ovens
My ariston cooking range ignitirs not working
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Aug 22, 2010 | Microwave Ovens
Have a brandt 4 burner induction cooktop about 8 years old. 2 left hand burners no longer operate. is this a common problem? can it be repaired?
Replace the burner and the control where ever necessary ... this is not uncommon and easily repaired.
Jul 21, 2010 | Microwave Ovens
Microwave Ovens Logo
197 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
