Question about Gateway MT6728 Notebook
How do i remove optical drive? - Gateway MT6728 Notebook
  • 98 Answers
You need to open up your Laptop's casing and remove parts until you reach the Optical Drive. Then you need to unscrew it or remove any clips from it, and then remove it carefully. That's on some laptops, but i should consult you to hire a professional to do this.
Posted on Jan 01, 2011
How can I remove the barrier to install a second optical drive
Two things have to be done in order to add a second optical drive.
1. Open case, remove front cover of case.
2. Remove blank from lower optical drive from front of case - remove blank (chassis part) from optical drive space.
The black insert that can be seen, removes from back on this model.
The 'steel' part on the chassis should pop out fairly easily.
Jan 19, 2012 | Dell Inspiron 620 MT Desktop Computer...
Is it possible to remove the top optical drive bay's front panel and fit the optical drive without it?
The front panel drive panel needs to be removed so you can install an optical drive. There may be a metal panel behind the plastic front panel, if so this will need to be removed so the optical drive can be inserted into the drive bay.
Nov 12, 2011 | ASUS TA-891 ATX Mid-Tower Case
We have a disk stuch in a dell inspiron 1318, there is no OS on it right now. how can we get disk out? there is no place to stick the paper clip
Remove the optical drive, and then open the drive. Remove the disk.
With most laptops this is a simple job.
Turn the laptop over on it's top, remove one Philips head screw, pull the optical drive out.
Remove 2 to 4 screws from a cover on the optical drive, and ease the tray open.
With the Inspiron 1318 Notebook PC it is more difficult.
A) Remove the Display Assembly.
(Removal covers removing the Display Assembly as a whole unit, off of the laptop)
B) Remove the Keyboard.
C) Remove the Palm Rest. (Top cover under the Keyboard. Your palms rest on it when you use the touchpad)
D) Remove the Optical Drive
Dell Support > Dell Inspiron 1318 Service Manual,
http://support.dell.com/support/edocs/systems/ins1318/en/sm/index.htm
In the list click on Optical Drive.
For additional questions please post in a Comment.
Regards,
joecoolvette
Aug 16, 2011 | Dell Inspiron 1318 Notebook
Help my dvd drive is stuck and wont open
Desktop or Laptop computer wasn't stated.
With most desktop computer optical drive's there is a tiny hole located right under the optical drive tray.
(The tray the disk is inserted in)
A paper clip is straightened out, then inserted into the hole.
This is a manual override, and will open the tray.
There are some desktop computer optical drives, that the computer case has a door that flips down, then the optical drive tray comes out.
The door must be eased down far enough to see if the optical drive has the small hole.
With a laptop computer the optical drive is removed from the laptop.
Generally there is one small Philips head screw that is removed from the bottom side of the laptop, then the optical drive tray is opened with the paper clip, and the optical drive is then removed by using the tray as a handle.
The optical drive is then pulled straight out.
Once out the top cover is removed for access to the disk.
If this information is not what you seek, or you would like it explained, please post in a Comment, and we'll work together on finding a solution.
Regards,
joecoolvette
Apr 21, 2011 | HP Compaq Computer Speakers
How do I remove a cd-rom from a hp dv5
1) Work on a table.
2) Remove ALL power to the laptop. AC adapter (Charger) and Battery.
3) Turn the laptop over Front facing you. There is one single Philips head screw to remove.
It's on the bottom of the laptop towards the Front, and is just past the Microphone, and Headphone jacks.
4) Screw removed use a paper clip to open the optical drive tray.
The paper clip is straightened out, then a third of it is bent into a handle to hang onto.
Looking at the optical drive with the laptop upside down, there is a small hole to the Left, on the optical drive tray. Insert the paper clip tool you just made into the hole.
This is a manual release to open the optical drive tray.
Hold onto the optical drive tray with your fingers, pull the optical drive out.
If you are going to replace the optical drive, be sure to remove the optical drive bracket from the back of the optical drive. (Two Philips screws) Install the bracket on the new optical drive.
Regards,
joecoolvette
Nov 15, 2010 | Computers & Internet
How do i remove the optical drive from my Acer AS7736z4015 laptop?
Usually there is a screw or two on the bottom of the notebook holding the optical drive in place. If you unscrew these screws, eject the optical drive's door & pull it outwards (of course while the notebook is switched off, unplugged & the battery removed, you will be able to remove the optical drive out of its bay.
Oct 31, 2010 | Acer AS7736Z4015 Notebook
Removal of eMachine M6410 optical drive
There are two small screws that the monitor cable would screw into, these have to be removed (7mm i believe) to be able to remove the base. The optical drive will typically pull out of the side after a screw has been removed and latch has been opened. I wouldn't go as far as removing the entire base.
Dec 08, 2008 | E-Machines M5305 Notebook
How to replace cd/dvd rom in Toshiba notebook Satellite A105-S1014
Steps for Removing and Replacing the Optical Drive
Steps 1 - Remove the battery
  • Slide and hold the battery release latch to the release position.
  • Lift the front edge of the battery and remove it from the battery bay.
Step 2 - Remove the optical drive
  • Remove the 7 mm P1 Phillips-head screw that secures the optical drive to the bottom of the notebook.
  • Use your finger to grasp the edge of the optical drive bezel and slide the optical drive out of the base enclosure.
Step 3 - Replace the optical drive
  • Insert the optical drive into the base enclosure until the connector is seated.
  • Replace the 7 mm P1 Phillips-head screw that secures the optical drive to the bottom of the notebook.
Step 4 - Replace the battery
  • Toe the rear edge of the battery into the base enclosure.
  • Lower the front edge of the battery and press the battery into the battery bay until the release latch clicks.
If you want to See the Video for replacing the DVD drive. You can go to this URL :- http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01271783&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Jul 05, 2008 | Toshiba Computers & Internet
Blue ray
Yes , You can put Internel Blue ray Drive Into Laptop and the steps are mentioned below for the replacment of Blue ray Drive.
Jul 05, 2008 | Sony DRU-820A DVD RW Dual Layer Burner
Gateway MT6728 Notebook Logo
41 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
