Question about LG Washing Machines
My washer is flashing LE WHAT DO I DO ?? - LG Washing Machines
  • brianmcgi803 Jan 01, 2011
    thankyou great info great site !!
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
Is this a new installation?
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Has a large load size been used with a gentle wash setting?
Gentle wash cycles such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because the cycles are more gentle while tumbling and spinning, too many items in the drum can register as an issue with the motor. In this instance reset the unit and run a test rinse and spin cycle.
Has the washer been overloaded?
Single bulky items or large loads can add extra weight to the drum and place stress on the motor. Remove some of the clothing and restart. If the issue is still present after a few items have been removed, unplug the washer for 30 minutes to allow the motor to cool and then restart the cycle.
NOTE: Make sure the drum is not overloaded
Are there soap suds visible in the drum?
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Sorry to read about your problem, I hope this helps you out.Is this a new installation?
Gentle wash cycles such as Perm Press, Delicate, Hand Wash, and Wool/Silk should only be used for smaller loads. Because the cycles are more gentle while tumbling and spinning, too many items in the drum can register as an issue with the motor. In this instance reset the unit and run a test rinse and spin cycle.
3 Thumbs - Helpful
Posted on Jan 01, 2011
Lg wm2101hw code le
Press "end of cycle" for 3 seconds or till the flashing goes off . Plug off the wall. Code can be an indication of several issues. The most common cause is over sudsing in the machine. Overloading the wash with too much laundry may also cause the LE error code. Lastly, a breakdown in the signal between the microprocessor and the motor may cause that error code. This can occur if there is a loose wire, see that all wires are tightened..........
Click helped if helped.........
Mar 15, 2013 | LG WM2101HW 4.0 cu.ft. Washer
Lg front loading washer flasing LE and stops midcycle
OVER SUDDSING
Jun 16, 2012 | LG WM-2277HW Front Load Washer
It says LE and will not start washing
LE means your motor or hall sensor is faulty. if u r confident please reply back and i will guide u thru how to find exact fault. 95% of the time it is the hall sensor.
Apr 14, 2010 | LG WM-2277HW Front Load Washer
Washer won't work
le means your hall sensor on motor is faulty. if u r confident change sensor.or phone service companys 4 price on hall sensor replacement, or reply back 4 more help
Mar 27, 2010 | LG WM2277H Front Load Washer
My LG washer is flashing LE and won't contiue the
First try unplugging the machine for a few minutes and then retry a cycle. If you still get the LE error:
The Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty (in the US). Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
In the US, find a service provider using your zip code at http://us.lgservice.com/index_b2c.jsp or call LG at 800-243-0000
Sep 06, 2009 | Washing Machines
LE code flashing on WM1812CW
LE code is overload on motor. This unit actually has a magneto and stator. This is what needs to be replaced. Usually find a magnet cracked.
Aug 27, 2009 | LG WM-1832C Front Load Washer
Washer
Greetings jannd,
The message "LE" can indicate that the thermal overload protection circuit in the motor has been tripped. The remedy for this can be to allow the washer to stand for 30 minutes to allow the motor to cool, then restart the cycle. If the LE error code still appears, unplug the washer and call for service. Keep in mind that this unit carries a 7 year warranty on the motor also.
I hope this helps!
Best regards,
Dorothy
Go Ahead. Use Us.
May 11, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LE Code on control panel
Press "end of cycle". Plug off the wall. Code can be an indication of several issues. The most common cause is over-sudsing in the machine. Overloading the wash with too much laundry may also cause the LE error code. Lastly, a breakdown in the signal between the microprocessor and the motor may cause that error code. This can occur if there is a loose wire, see that all wires are tightened..........
Dec 31, 2007 | Washing Machines
LE code
LE error is a locked rotor you need to have your hall sensor on the stator or better yet just have the whole stator replaced which comes with the sensor on it (P.S. the stator is part of the motor and has a 5 year warranty)
Oct 30, 2007 | LG WM-1832C Front Load Washer
LE code flashing
Try replacing the sensor assembly. Part number 6501KW2002A. It is on the stator itself where the 4 wire connector clips to. Only costs $17 + change & shipping. Mine works fine now!
May 07, 2007 | LG WM-1832C Front Load Washer
Washing Machines Logo
176 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
