Question about Car Audio & Video
I have a john deere tractor. I let the hood drop shut and it cracked. can I repair this?
Yes. Go to a parts store and pick up a fiber glass repair kit. It shoud come with fiber mat "cat hair", resin, and hardener. Get a face mask, plastic applicator and latex gloves and wear old clothes, IT IS MESSY. Sand the crack + 6" in all directions. Do this to the back side of the hood so the repair won't show. For best result, remove the hood to work on it. Follow instructions on kit. not that hard to do
Posted on Jul 08, 2008
you will need to look for second hand areas -ebay ,local classified -web searches- JD parts for those series are very hard to find but their out there look on ebay under john deere 1020 tractor and also tractor boneyards like marshall machinery in pa or steiner parts -if the exhaust is cracked look for a machine shop they may be able to do repair until replacement is available
Aug 31, 2016 | John Deere Tractor 1020, 1520, 1530,...
My brakes are sticking and/or locking up on my john deere 2355 tractor has anyone had this problem and fixed it
Troubleshooting - Operator's Manual - John Deere
See your John Deere Dealer. Fuel pump not ... Brakes dragging. Misadjusted .... Parkbrake locked. ... Cruise Set/Decel switch is held or stuck on. No cruise ...
Service Engine - Operator's Manual - John Deere
Warranty repairs must be performed by an authorized John Deere dealer. ... 3. Push down on front of hood to lock latch. ... brake. 2. Stop engine. Allow engine to cool. 3. Raise hood and latch open. 4. ... Remove right side engine shield from tractor. ....Check engine speeds when engine is warmed up and not under load.
Oct 29, 2015 | John Deere Garden
Hood release
Two screws on back side of latch.
Mar 10, 2014 | John Deere 3010,3020 Tractor Basic...
Where is the fuse located in the John Deere GT275?
Replacing Fuse
1. Lift hood.
2. Pull defective fuse (A) out of socket.
3. Check metal clip in fuse window and discard fuse if clip
is broken.
4. Push new fuse into socket.
5. Lower hood.
May 20, 2012 | John Deere Garden
Charging john deere toy tractor
you just remove the two screws on the side of the hood then lift the hood up
Jul 23, 2010 | Peg Perego John Deere Turf Tractor
Where is the hood release for the 3320 John deere tractor?
Below the bottom of the hood you will find two metal tabs,push down on either one to release the hood.You will have to release the grill guard pin and roll it forward before the hood will open all the way[if it has a loader on the tractor].Under the hood and to the left of the battery is the prop rod to hold it up.Hope this is helpful.
Jan 02, 2010 | John Deere 3010,3020 Tractor Basic...
My John Deer 1020 turns fine to the left but when turning to the right the power sterring does not work. It seems to me an intermittant problems. Occasionally the sterring is fine but most of the time it...
open hood to get to top steering gear check for lube and check adjuster worm gear known to crack or break a gear tooth than check thru view plate opposite of the steering cylinder which is connected to the rack&pinion make sure timing marks line up may have skipped a tooth or the thrust pad(shims) have shifted
Oct 30, 2009 | John Deere 420,1020,2010,2020,2510,2520...
My 1979 111 john deere lawn tractor deck blades shut off
If it has a clutch, that would be the problem. An electric clutch will kick on and off when it is hot if it is bad.
Sep 27, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Car Audio & Video Logo
255 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
