Question about Frigidaire Dryers
My daughter has a 3 1/2 year old dryer that just stopped heating up...any suggestions? and ballpark range of what it would cost to repair...thank-you
  • Frigidaire Master
  • 7,482 Answers
It will all depend on what is wrong to be able to judge the cost of the repair.
If your going to attempt repair or call a repairman.
Anyway I will give you some things to check
Please rate me
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape and running the dryer to check to see if the element is red or not,
or with an ohm meter check the two terminals of the thermostat/thermister
after you have removed the wires, the thermostat/thermistor should have/show continuity across the terminals.
If the coil heats up, or the thermostat/thermistor shows an open circut
then replace the thermostat/thermistor as it is defective.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the an element go to the following website, it will give you an idea what you are in for:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Posted on Jan 02, 2011
Lg lmlv2055sb just stopped working
6 years may be the point where the repair could cost more than a new unit----Call a local shop to see what it costs to look at the unit and if possible get a ballpark estimate---then weigh repair versus replacement.
Dec 03, 2012 | LG Microwave Ovens
We have an older dryer (ultimate care - super plus capacity) 12+ years old. It no longer "heats". Drum is still turning. I am assuming it is a thermostat - how much do those cost to repair?...
When it doesn't heat it could range from the timer to the heat element to the thermostat or even the motor so it could be as little as $125-350 to repair.
Aug 12, 2011 | Whirlpool Dryers
Dryer will not start. About 4-5 years old. Electric motor sounded a little weak when running the past few months. Heating seemed fine and heat vent is clean. What is cost of new electric motor?
the part # for the motor is 31001589 i have found the price range of it from$100.00 to $140.00
you could copy and paste the part number and perform a google search under the "shopping" tab to find the motor
Jul 25, 2011 | Maytag PYE2300AY Electric Dryer
No heat in the dryer. It is Maytag Neptune gas dryer about 9 years old. The drum rotates just fine but heat stopped a couple of days ago.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
May 14, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Hello my dryer is only 3 years old. Last night it stopped drying. The drum will turn and the light comes on. It is an electric dryer. What might be the problem. Thanks.
Have you tried a different cycle? The thermostat that controls heat has failed. There are more than one for the different heat settings. Try a different setting, then go from there.
Jul 01, 2009 | Dryers
Dryer not hot
Tht means that the element is not heating on.
You need to call a technician to test the element, the thermic sensor, and the control assembly.
The most likely is a defective heating element, that must be replaced.
Jan 31, 2009 | Kenmore 73952 Gas Dryer
Dryer no heating up
defective thermal fuse ,,replace
Dec 13, 2008 | Kenmore 72802 Gas Dryer
Whirpool electric dryer: heat turns on but no rotation
Your problem could be as simple as a broken drive belt.. or an overtemp switch.... If you've never replaced the drive belt.. then that is in all probability your problem.. If you reach inside the dryer drum and try to rotate it.. does it offer any resistance like it is turning a motor pulley system or is it free to rotate with very little resistance ( would suggest the belt broke).. If the cost to repair exceeds the cost to replace then you'd be better off replacing.. However ..if it is just a drive belt.. then I would just replace that.. Hope that helps...
Aug 24, 2008 | Dryers
3 1/2 year old Whirlpool Duet Dryer stopped heating up
it could be several things but the element could should be the last part i would check first if you are still using fuses change them both if that doesnt work call for service call a good service man stay away from major companies they are expensive i know i worked for most of them
Nov 22, 2007 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
37 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
