Question about eMachines eMD620-5133 Notebook
Emachines D620 laptop - hanging - strange problem. This is my daughter's laptop. It's a budget 1gb ram / vista laptop with an AMD single core processor. She was complaining it was hanging unexpectedly, leaving a black screen. I'm reasonable with computers so have had a good look at it. I expected it to be virus / software related, now I don't think it is. It only seems to hang after it's been on a while and after the laptop is moved. For example, I put it on a flat surface and installed and run AVG 2011. It scanned the whole hard disk - no problem - and took just over an hour. As soon as I moved it, it hung. Seems to me to be some sort of physical problem inside the box. Also, when it hangs it often won't re-start (I have to turn it off by holding down the power button, but when it's turned on again it goes straight to the black screen). Could be heat related? It starts ok after leaving for ten mins or so. I've had the panel off the back and looked for anything obvious. I've taken the HDD out and back in, but it still hangs. Any ideas on what to do next? I'm running out of ideas. Thanks in advance. Tony.
Check your memory. Run task Manager and check the volume of physical memeory.
Posted on Jan 10, 2011
Emachines D620 laptop - hanging - strange problem. This is my daughter's laptop. It's a budget 1gb ram / vista laptop with an AMD single core processor. She was complaining it was hanging unexpectedly,...
Hi
My cousin had a laptop that ran extremely hot.
My solution was to put it up on blocks.
Or you can space two books apart, rest the laptop on them and see if the problem goes away..
Two kids Lincoln logs would be perfect.
Might save you a trip to the repair shop.
Good luck
Joe
Mar 04, 2017 | eMachines E620-5885 Notebook PC
Can the Dell Latitude D610 run any of the following games: Age of Conan Star Trek Online Champions Online Aion
Check your system if it meets the following requirements
Age of Conan
Required
OS: Windows Vista/XP
Processor: 3GHz Pentium IV
RAM: 1GB RAM
Video Card: Shader Model 2.0 and 128MB RAM: NVIDIA GeForce 5800 or ATI 9800
Recommended
Processor: Intel Core 2 Duo 2.4 GHz (E6600) or better
Video Card: NVIDIA GeForce 7950GX2 or better
RAM: 2GB or more
Enhanced for: DirectX 10, 64-bit processors, multi-core
Supports Parental Controls on Windows Vista
Start Trek
System Requirements
  • OS: Windows XP SP2 / Windows Vista / Windows 7 (32 or 64-bit)
  • CPU: Intel Core 2 Duo 1.8 Ghz or AMD Athlon X2 3800+
  • Memory: 1GB RAM
  • Video: NVIDIA GeForce 7950 / ATI Radeon X1800 / Intel HD Graphics
  • Sound: DirectX 9.0c Compatible Soundcard
  • DirectX: Version 9.0c or Higher
  • HDD: 8GB Free Disk Space
  • Network: Internet Broadband Connection Required
  • Disc: 6X DVD-ROM
Recommended System Configuration
  • CPU: Intel E8400 Core 2 Duo or AMD Athlon X2 5600+
  • Memory: 2GB RAM+
  • Video: NVIDIA GeForce 8800 / ATI Radeon HD 3850+
  • Disc: 6X DVD-ROM
To check your system hardware> click on start>all programs>accessories>system tools> system information.
Thanks for using Fixya
proton
Mar 27, 2010 | Dell Latitude D610 Notebook
When installing ram i hear a single long repeated beep im trying to install 1gb DDR ram sticks two of them
either you have the wrong ram! for the gateway or your trying to add too much to it gateways only will hold so much before thet reject the ram the machine goes into a over draft in the onboard memory
Jan 19, 2010 | eMachines W3118 AMD Sempron 3100+ 1.8GHz /...
Hey, I have a hp zd8000 netbook with an ati mobility radeon x600 128mb video card i would like to know if i can run cod4 on it thx.
According to this you can't.
X600 Specs:
http://ati.amd.com/products/mobilityradeonx600/specs.html
COD4 System Requirements
Recommended requirements:
CPU: 2.4 GHz Dual Core or better
RAM: 1GB for XP and 2GB for Vista
HD: 8GB Free Space
GFX: 3.0 Shader Support, Nvidia Geforce 7800, ATI Radeon X1800 or better.
Minimum requirements:
CPU: Intel® Pentium® 4 2.4 GHz, AMD® Athlon™ 64 2800+ processor
or any 1.8Ghz Dual Core Processor or better.
RAM: 512MB RAM (768MB for Windows Vista)
HD: 8GB Free SPace
GFX: NVIDIA® Geforce™ 6600, ATI® Radeon® 9800Pro or better
Jul 05, 2009 | Dell RADEON X600, (128 MB) Graphic Card
Emachines D620 laptop. I can´t open the rear cover to install RAM
my fan broke on mine over heated and then the fan packed up i can only go on it for about 1hour at a time buying a cooling station but trying to find a new fan
Jul 01, 2009 | Toshiba Satellite M35X-S161 Notebook
Dell latitude d620 wont turn on
Did you upgrade the RAM when you upgraded to Vista. The D620 does not have the resources to run vista as pre-configured and requires, at the least, a memory upgrade. 1gb or greater is recommended.
Please upgrade the ram, or try F8 during boot for Safe-Mode and see if your RAM is not the issue. To check the amount of RAM you have:
Press and Hold Windows Key + PauseBreak
If you still have 256mb or 512mb vista is likely to barely crawl.
Let us know what you find.
Apr 17, 2009 | Dell Latitude D620 Notebook
Heating problem
Intel D102GGC2 Motherboard
i am having 1GB Ram in Single slot,when I add another 1GB ram in the other slot the memory shows only 896Mb.The processer is dual core.
Dec 05, 2008 | Intel D102GGC2 Motherboard
Adobe cs3 installation in vista 64bit
I am sure but I think it isn't compatiable with vista home ..
Jun 07, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Acer aspire 5100 + AMD TURION 64 + DDR2 1GB + WINDOWS VISTA - IS VERY SLOW, AND HANGS
hmmmm...now..that's weird..did you do any disk maintenance? shut down all applications, all of em, and run disk cleanup and defrag..usually good for about 25% improvement in speed, at least..
got backup for that acer?
Feb 21, 2008 | Acer Aspire 5100 3010 Notebook
eMachines eMD620-5133 Notebook Logo
177 people viewed this question
Top eMachines Computers & Internet Experts
Michael Vincent Cruz
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
