Question about Whirlpool Gold GU2475XTV Builtin Dishwasher
The button covers are falling off of my control panel. Can I glue them down?
I have a whirlpool tub, with a side panel that allows access to the mechanics, and the panel is just held on with cheap velcro. We put commercial grade velcro on, as the panel kept falling off, but it too...
If Velcro is not working for you try some magnetic strips. Purchase some magnetic strips attach to both the cover and the tub. Be sure the polarity of the magnetic strips is correct so they attract each other. You could glue the strips to the cover attach the tub strips to the cover strips then apply glue to the tub strips and apply the cover to the tub allow the glue to dry and that would insure correct polarity and positioning of the strips. Hope this helps.
Bob
Aug 22, 2014 | Home
Headlight gap cover installation
the item you are talking about is the cover for the headlamp washer jet has it got headlamp wash? if so the washer jet has fallen off the headlamp and dropped in the bumper liner, the cover clips on to end of jet if it does not have headlamp wash the cover has 2 clips one on each side but they break and fall off in that case we use epoxy glue to refit it
Feb 20, 2014 | 1997 Jaguar XK8
How do I remove crazy glue from control panel? The cover over the plus control(to raise oven temperature) was coming off so I thought I would glue it back on! Bad idea ....now that control remains...
Not to much can repair / remove the crazy type glues once they are applied to plastics and plastic overlays. Some people attemp to use these not knowing that some types of plastic will not bond. most of the solvents that can desolve the glues will also damage the panels.
Mar 27, 2012 | GE Microwave Ovens
My door locks are woring by them them self,they unlock about ever 30 seconds or so,will also turn the interior lights on
On your year , the door locks and several other things are controlled by the Body Control Module (BCM). It is located on the passenger side under the dash. The is a panel to remove to acess it. It is black, and about 7" X 5" square and about 1 1/2" thick. Unfortunetly your car also has a problem with water leaking in on that side threw the cabin filter hole, that is located under the windshield wiper panel on the outside of the car. There is a trim piece that falls off the body and lets water enter. this needs fixed first. Remove the panel (black) there are 4 to 6 screws to remove ,plus the wiper blade arms. The trim piece falls down, fish it out and glue it back in place, over the cabin filter hole. Use RTV or a caulk type glue. Reassemble it. Also a good time to replace that filter. Now go to the BCM. once you get the panel off, 2 screws, You will have to remove the light/bracket that is there also. The BCM clips on to its bracket, so slide it off. Remove the plugs in the BCM and check them for corrossion, A soft wire/brass brush works great. Now for the BCM, this is very suseptable to static charge, so touch any piece of metal before you open it. The plastic case around the BCM will come apart, look at it you will see the tabs. One you get the cover off it will also have corrossion. use the same soft brush to clean it up. Don't scrub on it hard as you can clean things off that you don't want to come off. Once clean, reassemble the cover. Before I ptu the BCM back in place I get some plastic, thin like a trash bag, And wrap the BCM. Put it back in place and pull the plug wires down alittle below the BCM. So if water does get in there again the BCM is protected and the water will follow the wires down, instead of going into the BCM. Have question let me know Randy PS this is not hard to do and New BCMs are expensive and you have to get a new one reprogrammed, more money.
Jul 21, 2011 | 1999 Pontiac Grand Prix
My passenger window will just fall down and when i hit my power window button you can hear the window motor moving..i havent taken the door panel off yet..any suggestions
psbowlchoker, Sounds like the window has fallen out of rail, When the glue or opoxy gets brittle it happens. The rail is moving witthout the window in it. Get your self some door panel tools and go for it. Also get the door panel buttons, no matter how careful you are they always get buggerd up somehow. Two part epoxy- metal-weld is the best bet to re attach the window to the rail. good luck
Feb 15, 2011 | 2001 GMC Sierra 2500HD
Some of the buttons on my laptop has come of, how do i put them back?
Hello
Use a small dab of super glue to replace keys that have fallen off.laptops often have keys that fall off, especially as the computer ages or is used quite frequently. Place a small dab of glue directly on the round part that holds the key in place and lightly press the key down. When the glue dries, you'll be able to use your laptop again.
Dec 15, 2010 | Acer Computers & Internet
Power window not working can hear motor turning also window is falling down
pull the side panel off the door. Gears in the slide on the motor may be offsheared. Or hold button down on window and tap the motor
Apr 05, 2010 | 1994 Lincoln Town Car
JVC HR-S9500 S-VHS VCR. all functions work except the eject on the vcr. there is no eject on the remote.it plays, ff, rew, stops etc. I can't get the tape out.
the eject button is a plastic piece that turns and pushes down on the board and is more then likely broken open the vcr take off the front face plate and check the button, it will propaply fall out. you can use super glue and glue the button back in place
Jan 05, 2010 | JVC HR-S9500 S-VHS VCR
Glue down controller cover lost
You can have it replaced by contacting the manufacturer or the provider from who you purchased it from. Most likely you are using a PG Drives VSI controller with the on/off, horn, and increase and decrease speed buttons on it. They are normally between 5 and 10 bucks. If you do get it, use Loctite rubber glue to glue it back on.
Mar 17, 2009 | Jet 3 Ultra Power Chair
Lense cover keeps falling off
The spring must have grown tired, or displaced. If you don?t want to loose it in the meantime, you can glue a string one side to the cover and one side to the camera?s body using small points of super glue. But a more creative solution would be to get to a cannon selling shop and nag them to help you get a new one, or go to a second hand shop and look for a standard cover that?s a good fit for your lense.
Feb 21, 2006 | Canon PowerShot S2 IS Digital Camera
Whirlpool Gold GU2475XTV Builtin Dishwasher Logo
237 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
