Question about Dryers
9 yr old Whirlpool Electric dryer has stopped and when you press the button to turn it on nothing happens. Checked fuse box and everything is okay there.
  • Dryers Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Jan 03, 2011
My whirlpool gas LGB6300PW0 dryer won't start. I press the start button and hear a humming noise, but no motor turning over. Please tell me that my 5 yr old dryer doesn't already need a new motor!...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
heatman101
May 18, 2011 | Whirlpool LGV4634JQ Gas Dryer
I have a 4 yr. old kenmore elite HE4 dryer. I put the clothes in and hit normal cycle. 41 minutes automatically comes on. I hit various buttons and nothing happens. I hit the start button and it finally...
if I am understanding the problem correctly then this website should work, if I am misunderstanding then the second one might help.
http://www.epinions.com/msg/show_~threads/cat_id_~17/id_~3088/forum_id_~409
http://fixitnow.com/wp/2009/03/17/easy-fixes-for-two-common-problems-with-the-whirlpool-even-heat-dryers/
Nov 03, 2010 | Kenmore Elite HE4 Electric Dryer
Whirlpool dryer model number WED5300SQ0 wont start
take a meter and check door switch then if good take the back off and check all thermostats,thermal fuse,AND if your belt is off theres a safety switch on the idler pully.hope this helps
Nov 15, 2009 | Whirlpool WED5300S Electric Dryer
Dryer not working at all
Hi, UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it.
Please let me know if this help or if I can assist you further.
Thanks
Vic
Jul 01, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer model LEQ8800JQ won't start when push start butto
I posted today (Jan 2, 2009) that I had same problem. Handyman tested for blown thermal fuse, etc and everything was fine. He said I have to replace the timer switch .. well guess what - I fidgeted with the start button (on/off) hard a few times while simultaneously pressing & releasing door switch and it did the trick. In my case the problem was most likely with the start button. Dryer is working fine now!
Jan 02, 2009 | Whirlpool LEQ9858P Electric Dryer
Whirlpool LER5644EQ2 Electric Dryer that won't start
HI yes it could be a fuse its called a thermal fuse located at back of dryer remove back on the left sede on air duct a fuse with 2 smaller blue wirse that should be your problem thanks THE APPLIANCE DOC
Sep 06, 2008 | Whirlpool LER5636P Electric Dryer
Dryer
either door switch or thermal fuse on rear of unit Exhust duct check those and let me know..(Fuse is white with 2 wires)
Feb 18, 2008 | Dryers
Wont start
try turning the drum by hand...is it jammed? if not, then: the motor will not turn due to a number of reasons: 1.) simply burned out copper windings 2.) switch not turning on motor or not turning on motor starting circuit-depending on design ...if jammed, then try to find the interference to turning
May 31, 2007 | Estate TEDX640JQ Electric Dryer
Dryers Logo
29 people viewed this question
Top Dryers Experts
