Question about Kodak EasyShare M530 Digital Camera
New camera - I need to set date and time. - Kodak EasyShare M530 Digital Camera
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kodak Master
  • 102,366 Answers
Press MENU, use left/right to select Setup, use up/down to select "Date&Time." Use left/right to move between fields, up/down to change the value. Press OK to accept.
Posted on Jan 02, 2011
Testimonial: "Very helpful. The book that came with the camera is too small. I am used to a bigger manual. Thanks for your help."
My Camera keeps asking me for the date and time every time I turn it on How do i stop this?
Press the m button during shooting or playback to display the setup menu. The setup menu provides access to a variety of camera settings, including options not listed in the function menu, display options, and the time and date. Once you have the date and time set it should stop asking.
Aug 26, 2013 | DMCOM Olympus Vr-320 14 Mp Digital Camera...
Tip
DATE RESET PROBLEM ON DIGITAL CAMERA
Have you encounter on your camera that the TIME and DATE are always cleared once you turning ON? Menu of the date setting appears everytime inserting the battery and turing the power ON?
Dont worry the problem of your camera is only a minor. For your technical information, all cameras have a capacitor together with board that provide power to save your date setting or its work as a battery.
Once you open you camera and you found out color green stain can be seen in the part of the said capacitor. You need to clean first by brush and make it sure be gently while brushing the capacitor just to remove the stain.Then try to turn On your camera and set the date and time, after this turn off and remove the battery for a second. Once again put the battery on your camera and turn On. Once you need to set the date again it means the capacitor was damage and need to replce new.
if you have knowledge about repairing electronics what you need to do is remove the damage capacitor and replace it new with the same specifiction and size.
I hope my tips will help you
Good luck and thank you
on Jul 21, 2010 | Cameras
Date/Time resets every time i turn on camera.
Hi, yes, there is a small coin memory battery, usually something like a CR3032 lithium battery. Turn off the camera and insert a new 'coin' battery (correct side up). Close battery cover, turn on camera and go to menu and set time and date. It should remember the time and date for a year or two, provided you put a regular battery on the camera on a regular basis. Also note, some older Sony cameras allow you to set it so that it shows only the date for the 1st 5 seconds when you first turn on the camera that day, then shuts it off unless you want it to superimpose the time and date on the video. Good luck, and let me know if this solves your problem. John
Jan 17, 2012 | Sony Handycam HDR-XR520 High Definition...
Everytime I turn on my camera it asks me to set date/time. It goes to the default date/time setting of 00.00.0000 00:00 mm/dd/yy. What do I do to set the date/time so that it permanent? The photos are...
It takes around four hours for a freshly charged main battery to charge the internal backup battery. It you do that and it still doesn't charge it, you need a new internal battery. The fully charged internal battery in most of them will hold the charge for up to 3 weeks with the main battery out of the camera.
Oct 19, 2011 | Canon G12 Digital Camera
The date and time is asked whenever the camera is switched on
Have you set the date and time? If so then your camera's date battery is probably dead and needs to be replaced. First get yourself a CR1220 battery, most often found at your local Radio Shack or online at amazon. Then open the camera's terminal cover (where your USB is) and using your fingernail. Open the battery holder, remove the old battery, and replace with the new one. Reinsert the holder with new battery in your camera and turn on your unit. set the date and time and you should be all set. For further information see your instruction manual or download from Canon at:
http://gdlp01.c-wss.com/gds/7/0900011217/01/PSA520510CUG-EN.pdf'
The instructions for changing the date battery start on page 137.
Hope this helps!
Hiram
Photo Tech Repair Service
110 East 13th Street
New York, NY 10003
212-673-8400
Jul 05, 2011 | Canon PowerShot A510 Digital Camera
How to set time on your camera so that when you print your photo's, it shows the date
The date/time setting process may be slightly different on different camera. Which camera do you have ? Nevertheless, you first need to set the date/time on your camera. And when you print, say using PictBridge, you need to set the DPOF date setting at WITH DATE. And you need to use a printer that supports date printing.
Feb 18, 2011 | DSC Cameras
My wife is complaining that every time she turns off/on the camera she has to reset the data/time. I understand that when the batteries are changed the settings may be lost, but not simply when the camera...
Sounds to me that there may be another battery inside the camera that is going bad.
Issue: Everytime I power on the camera the Date / Time needs to be set.
Solution: Replacing the Date Battery for the PowerShot A480.
Replacing the Date Battery. If the Date/Time menu appears when the camera power is turned on, the date battery charge is low and the date and time settings have been lost. Please purchase a lithium coin battery (CR1220) and replace it as follows.
Please note that the first date battery may appear to expire relatively quickly after you purchase the camera. This is because it is installed in the camera at the point of manufacture, not when you make the purchase. caution.gifBe particularly careful to keep the date batteries out of the reach of children. Seek medical assistance immediately if a child swallows a battery since corrosive battery fluids can damage the stomach or intestinal walls. 1. Confirm that the camera power is turned off.
2. Open up the battery door / cover and remove the AA Batteries.
3. Remove the date/time battery holder.
4. Grasp the battery and slide it in the direction of the arrow.
a480backupbatt.jpg 5. Insert a new battery with the (+) side facing up.
6. Replace the battery holder and battery cover.
7. When the Date/Time menu appears set the date and time.
note.gif After purchasing the camera and turning on the power for the first time, although the Date/Time menu will appear, you do not need to replace the date battery. If you ever dispose of your camera, first remove the date battery for recycling according to the recycling system of your area.
Dec 31, 2010 | Canon PowerShot A480 Digital Camera
Date keeps resetting, when camera is turned off
hi, the problem why evrytime you turn on your camera you need to be set the date/time is the capacitor inside of the camera you need to do is replace with new one.it is easy if you now how to repair electronics or if you have knowldege. try to bring to service center and for sure they will charge a minimun charges.
Jul 08, 2010 | Olympus FE-340 Digital Camera
Can't change date or time on my new Pentax K2000
Date/time are set at "first use" or through the tools menu.
Remove the batteries.  Leave the camera overnight, this may be enough to lose the current settings and allow setting new date/time.
Press Menu button.
Press right arrow on the 4-way controller to get the Tools (spanner) highlighted.
Press down arrow to get to date (or time).
Press right arrow
Now set to your preferred format.
If this does not work, try changing another item in the Tools menu.  If that change is not accepted, then it's into the dealer.
Jun 21, 2009 | Pentax K200D 10 Megapixel Digital SLR...
Wrong date and time
Date and time controlled by a cmos battery attached to the motherboard of the camera. Factory repair necessary. Costs $90 for the board with battery and $90 for installation. Camera now at Nikon certified repair shop. Thank you, A. Ward
Mar 03, 2009 | Nikon Coolpix 8400 Digital Camera
Kodak EasyShare M530 Digital Camera Logo
60 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
