Question about Ovens
I just bought a new home and find the oven door will not close properly. It stays open about an inch with lots of heat escaping. Any ideas?
    Problem Solver:
  • 13 Answers
Most oven doors are equipped with spring closures as part of the hinge assembly, and are designed with a "detent" feature so that the door can be removed for cleaning without requiring tools. Usually, with the door wide open, you lift the hinged edge of the door straight up, and wiggle it straight out at the same time. When you reinstall the door, it is important that both hinges "seat" equally, and that one or the other hasn't tripped out of the detent positiion. You may have to experiment wit it several times, and a second pair of hands may be helpful. You may also find that maybe a freind will know the trick, my wife can pop the door out and back in in a flash! Goodluck Rob.
Posted on Jan 02, 2011
Our electric convection oven heats up and when you open the door and close again it no longer heats, fan stays on and the light goes on when door open and off when door is closed, any ideas?? Thanks
Hi, You can look at the micro switch on the oven door, sounds like it might have been installed on a normally open auxiliary rather than a normally closed aux. hope this helps
Oct 09, 2014 | Ovens
Door stays open about 2 inches
Replacing the hinges is risky because you need to be 100% sure the new hinges go back in the exact spot the old ones were.
Otherwise, there might be leakage, which can lead to arcing and possible fire.
The exploded view / parts list is here.
If the hinges are not secure, the door may slip, which can cause leakage or failure to operate correctly.
Also, there is a bulletin about these regarding the door locking _closed_ but maybe it's applicable in this case, too.
Here's the text of the bulletin:
KitchenAid & Whirlpool Electric Wall Ovens And Dual Fuel Range
MODELS: KEBC101K, KEBC107K, KEBC141K, KEBC147K, KEBC171K, KEBC177K, KEBC206K, KEBC207K, KEBC208K, KEBC247K, KEBC276K, KEBC277K, KEBC278K, YKEBC107K, YKEBC177K, YKEBC208K, YKEBC278K GBD277PD, GBD307PD, YGBD307PD, GMC275PD, GMC305PD, RBD245PD, RBD275PD, RBD276PD, RBD305PD, RBD306PD, RBD307PD, AND KDRP407HS
PRODUCTS BUILT BETWEEN CODE DATES: XP22 - XP29
CONCERN: Error Code "F5 E1" or "F5 E7" (door latch not unlocking the door after self-clean cycle).
CAUSE: This problem is caused by defective material in the core of the solenoid on the door latch. The solenoid works properly at normal temperatures, and at the beginning of a self-clean cycle. However, when heated, the plastic core binds the metal plunger, and will not allow it to unlock at the end of a cycle. Once cooled, the solenoid will again work properly. When a technician inspects the solenoid while it is cool, it will function normally.
SOLUTION: Replace the solenoid with service solenoid #4452224.
Jul 23, 2013 | Ovens
We have a Jenn Air Wall over that the door will not close air tight. They have replaced the hinges but you can actually stick a thumb between the top part of the oven and the door. They say it's supposed...
there's a door gasket that seals it not the metal part of the door so you might be able to stick your thumb in there as long as the seal on the door is closing tightly to the frame,when you open the door it should be on a 90 degree angle,before you had new hinges put on the door, most likely the door sagged lower to the floor and didn't close properly,if you think alot of heat is escaping you could have a bad door gasket.so open the door,look at it from the side,it should look like an L or at a 90 degree angle or even up a little,if it is the hinges aren't the problem if you think to much heat is escaping,call whoever did the work for you and have them check the door seal or gasket same thing.you didn't send the model number so i don't know what seal you need,go here and watch video should be similar and you can put your model number in to find correct part
http://www.appliancepartspros.com/whirlpool-gasket-oven-door-wpw10162384-ap6016005.html
hope this helps you out,if heat is coming out with door closed and you have new hinges this is most likely what's wrong
Jan 07, 2018 | Jenn-Air Ovens
Oven door not closing properly
If it is a drop down door with hinges on the bootom of the oven door, then it is likely to be weak door hinge springs, the usual solution is to replace both hinges.
If it is a swing open door, then the problem is related to a worn or broken door catch, or worn striker pin.
Apr 13, 2010 | Ovens
Oven door fails to close properly. Heat escapes when cooking. Seals appear to be ok. Please assist if free, as offered.
Probably mal-adjusted hinges. Open the door fully and there USUALLY are small holes in the hinges to insert a nail into to hold the hinges open while working on the door.
Nov 25, 2009 | Fisher Ovens
One of the oven doors does not close tight so heat escapes. It is a Jenn Aire electric double wall oven model number JJW9627DDS.
Sounds like the oven door hinges have worn. If door is not obstructed in any way and will fully close when pushed but open about half a inch when released then it will be the hinges. Not sure of cost of spairs. I believe this to be a John Lewis Model. If it has a Enr no inside the door or inbetween the door hinges then I could give you price on spares
Nov 15, 2009 | Jenn-Air JJW8230D Electric Double Oven
Jenn-air JJW9630CAS - double wall oven -door won't close, even after hinges replaced
On my double oven the bottom door was not closing by at least 21/2 inches the upper door would allow the light to stay on . Upon close examination this problem appeared to be the door was too low which did not allow the gasket to seat in the oven cavity, holding the door open. new hinges and receptors did not resolve this condition.This is how I corrected this condition. 1 open the doors one at a time and lock the hinges.2 remove the doors from the receptors (be careful they are heavy) and set aside. 3 remove mounting screws holding oven in cabinet. 4 slide oven forward enough to hold onto receptor sockets on left and right sides lower and upper 5 remove receptor sockets by removing the screws in front of oven(be careful to hold on to the receptor so it doesnt fall behind oven into cabinet)7 with a center punch punch a start point 1/8 inch above the existing screw holes and drill appropriate size hole for screw THE HOLES MUST MATCH UPPER AND LOWER RECEPTOR OR THE SCREWS ON THE LOWER DOOR WILL SCRATCH THE UPPER DOOR .8 attach receptors to oven in new holes 9 slide oven back into cabinet and replace screws removed in step three 10 attach doors into receptors and push locks forward into receptor cavity attach lower door first and check for operation then upper door open slowly and check enough clearance exists for the screws on the lower door miss the upper door . If more clearance is needed elongate the holes drilled earlier(repeat steps 1 through 5) and slide receptor up on upper door. NOTE The receptors are not in a sealed space in the oven cavity and are not exposed to any heat. Periodically check the screws for tightness. After performing this procedure Both doors close all the way and the light is no longer a problem Now 20 minutes cook time MEANS 20 MINUTES COOK TIME.
HOPE THIS RESOLVES YOUR PROBLEM !!!!!
Nov 06, 2008 | Ovens
Neff oven door (U1661)
The door is v heavy and the hinges being right at the bottom take a lot of strain, especially when the door is in 'half open' position. Once the springs start to wear the hinges are no longer strong enough to hold the top of the door firmly closed. Our U1661 is 8 years old and we've had the hinges replaced twice under extended warranty. The second time the hinges they supplied don't hold the door in this position and it will just drop straight down if you don't support it while you open it.
Oct 20, 2008 | Neff U1661 Double circotherm super...
Oven door stays open
Hi , the oven dorr needs ajustment , lose some attachement bolts ,then close the clearance will shut , so open gently and tightened the bolts.
Jan 06, 2008 | Whirlpool GBD307PDS Electric Double Oven
Ovens Logo
51 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
