Question about Bosch Washing Machines
Bosch classixx 1000 Washing Machine not Spinning?
  • 95 Answers
If it is wahing and not spinning, many times the door switch may be damaged. Check switch, to make sure the wires are not torn out.
Posted on Jul 08, 2008
barkencoa
  • 3463 Answers
SOURCE: filter
If` there is a removable panel at bottom front of washer, remove it, and you should find the filter located there.
Please rate my solution.
Thanks.
Posted on Jul 19, 2009
  • 662 Answers
SOURCE: Got the Bosch Classixx 6 Express 1400 washing machine cant
Power on, press the start button for 5 or 6 seconds, the sign will go off. Try the door gently. Means the machine is locked, for children. I think if you do it again it locks.
Pl rate me 'very helpful' for the free help, thanks
Posted on Jun 17, 2010
  • 662 Answers
SOURCE: Got the Bosch Classixx 6 1400 Expresswashing
Pl rate me 'very helpful' for the free help, thanks!
  • 662 Answers
SOURCE: my bosch classixx 1000 washing machine is not
Remove belt, unscrew 2 bolts that hold the motor, unplug the motor connector, lever the motor back with a screwdriver. Check the motor brushes, if they are any shorter than 1 cm replace brushes.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Sites for spares:
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
mcminone.com
Pl vote me 'very helpful' for the free help, thnks!
SOURCE: Bosch Classixx 1000 Express washing machine won't fill with water
my washing machine bosch clasixx all in one does not rinse clothe properly. there is a residue of washing powder. Where is an extra rinse button
Posted on Jun 18, 2010
WHAT CAUSES GROANING NOISE WHEN SPINNING?
Did you check the manual for further instructions? You can find a PDF copy here: Bosch Classixx 5 Manual
Jul 11, 2014 | Bosch Washing Machines
Bosch classixx 1000. Impeller loose.
You are best fitting a new pump asa temp repair impeller can be reglued but a new pump is bet fitted.
Apr 20, 2010 | Washing Machines
My bosch classixx 1000 washing machine is not spinning at the end of the wash cycle, and when set to spin it does not spin, what can i do?
espares.co.uk
mcminone.com
Apr 03, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Softener won't empty in Bosch Classixx 1000
take out the soap drawer clean in hot water inside the machine where you took the soap drawer out at the top look for the hole where the water runs out it may be blocked with mildew dettox mildew spray is very good at breaking all that down spray in leave for a while put soap draw back in and do a wash without clothing as spray contains bleach
Mar 30, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Bosch 1200 classixx not spinning
bosch 1200 classixx not working properly. On 12 min spin cycle it starts then after 1 min timer reads 0:01 and it stops. washing cycles run but doesn't seem to be any spin action
Oct 12, 2009 | Bosch Washing Machines
Filter
Thanks.
Jul 19, 2009 | Bosch Classixx WFL 2066 Front Load Washer
cheak the filter witch is at the intake and if when it is going to fill does it buzz if dose that means the vale is working if not call a repaire man out hope this helps
Jan 22, 2009 | Bosch Classixx WVF 2402 Front Load...
Washing Machines Logo
345 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
