Question about Refrigerators
Kenmore model 65002 bottom freezer refrigerator is not freezing and the top part of the refrigerator is not keeping food as cold as it should be.
  • 50 Answers
Try taking the back off the fridge and vacuuming off the coils. Give it a good cleaning. If that doesn't work you probably need a new compressor which is usually cost prohibitive.
Posted on Jan 01, 2011
Why does freezer keep cold and not bottom on a frt16crh
Maybe too much food jammed in to allow cold air to get to the bottom.
Oct 04, 2014 | Refrigerators
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
Kenmore refrigerator with top freezer purchased about 8 years ago. The freezer isn't freezing food thoroughly and now the refridgerator is not keeping the food cold enough. What could be the problem? ...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 05, 2011 | Kenmore 20.6 cu. ft. Top Freezer...
Refrigerator not getting cold at bottom, freezer works fine
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Sep 13, 2010 | Kenmore 64802 Top Freezer Refrigerator
Food at bottom of fridge freezes
Bad cold control switch.
The cold control switch should open when the set temperature has been reached. If the control does not open and turn the compressor off, it will continue to run and freeze items in the refrigerator section.
If the control is not closing, the compressor and all fans will stop operating. Check the control for continuity. If you don't feel comfortable checking this yourself, get a repair person out to check it out.
Hope this helps.
Aug 07, 2009 | Kenmore Refrigerators
M# 596.72219200 Kenmore with bottom drawer refrig keeps freezing
That is a broken thermostat control part number 67003000 when they stop they can break while on or off. Sea Breeze
PART NUMBER AND MODEL SEARCH FEATURE
Jul 23, 2009 | LG LSC26905TT Side by Side Refrigerator
Kenmore elite refrigerator. both compartments (bottom freezer and top refrigerator)are not keeping with the temperature setting. the food is cool but not cold as it should be. how can I test to see if...
Really most folks have to keep their setting on their fridge on about a 6-7 or-8 setting with the amount of food that is kept in the fridge now.
YOU CAN KEEP AN EYE ON THE RELATIVE temp if you like by placing a fridge thermometer in the appliance. Optimal fresh food should be around 40-43 degrees F on average to keep things on the cooler side without freezing.
Hope this helps
Nov 27, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Top freezer Freezes/ Bottom not cold
defrost problem. advance defrost timer to defrost (till it shuts off) . remove freezer panel, check voltage and amps to heater,if heater is hot, replace timer, if heater is cold and no voltage, replace defrost limit switch. defrost all ice, carefully! with hair dryer, no poking with screwdriver.
Oct 26, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
62 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
