Question about Espresso RMI La Cimbali Espresso Machine
Pressure gauge tells us we have zero pressure.
    President:
  • 1,618 Answers
Which pressure water or steam. If it is steam make sure machine is turned to 2 on the switch, if it is then check the hi limit reset and make sure it did not trip.
Posted on Jan 05, 2011
What causes oil pressure to drop to zero but goes with accelleration
If your oil is full, it's most likely electrical. If it's not electrical, then it's most likely something like a crack in the pickup tube, sucking air if I had to guess.
Sep 11, 2014 | 2000 Jeep Grand Cherokee
No oil pressure 2000 silverado 4.8 eng
If the gauge is showing zero pressure, you would next check the pressure with a mechanical gauge to verify.
Make sure you use a tee fitting to keep the electric sensor in use while testing.
If the pressure really is zero, something has happened to the oil pump in the oil pan.
Feb 08, 2013 | Cars & Trucks
My check gauges light is on, oil hands goes over to zero, moves up, light goes off, when it drops back to zero, gauge light comes back on.
Well the warning light is supposed to come on if any of the gauges display a dangerous condition, such as no oil pressure.
You may have a faulty sending unit for the gauge, or a wiring problem, or the engine may actually be loosing oil pressure when the gauge drops.
You could replace the sending unit as a test, or have someone check the oil pressure with a mechanical gauge.
Dec 13, 2012 | 2001 Jeep Grand Cherokee
If pickup tube on the oil pan is bad will my oil pressure drop to zero at stops and at acceleration go back up
IT IS POSSIBLE ,BUT YOU SHOULD USE A MECHANICAL OIL PRESSURE GAUGE TOO COMFORM IT IS NOT A BAD OIL PRESSURE SENDER OR GAUGE
Jul 03, 2012 | 1995 Pontiac Bonneville
1991 jetta 1.8 manual. Oil pressure gauge works but as the car heats up after about 5 minutes the gauge drops to zero (no oil pressure), oil is pumping up to the cylinder head, drove the car for about...
you may have a faulty oil pressure sensor which needs replacing or a loose connection, check for any loose wires......hope this helps.....cheers.
Jun 20, 2011 | 1991 Volkswagen Jetta
Oil pressure gauge on 1997 jeep wrangler 4.0 is coming in. shows no pressure at zero. changed sending unit, and filled oil to full but still is coming in. also when at 55 or higher mph, pressure is below...
check it out manually with a pressure gauge ,could just be a high resistance or something ,but check with a manual dial gauge and if low check put the oil pump
Apr 19, 2011 | Jeep Wrangler Cars & Trucks
Low oil presure
perform a master oil pressure test. this is done by removing the oil pressure sending unit and installing a oil pressure gauge. if the reading on the test gauge is ok, the sending unit needs to be replaced. if the pressure reads low on the test gauge, there may be excessive bearing wear or you may have worn valve guides. good luck!
Apr 29, 2010 | 1997 Ford F150 Regular Cab
My oil gauge drops to zero, but everyhting appears to be working. could the oil pump be out? How can I tell?
you would need to remove the oil pressure sending unit beside the oil filter and hook up a gauge to verify it.
but if you had "0" it would be knocking really bad,so I think I would try replacing the oil sending unit,thats what tells the gauge on the dash to register.they are about $15.00 at Autozone
Jan 11, 2010 | 2004 Chevrolet Avalanche
Low oil pressure
You need to get a gauge hooked up to see what the actual pressure is. (a garage can do this if you can't get ahold of one.) This will tell you exactly what the oil pump is, or isn't doing. The gauge threads in where the sending unit goes.
Aug 09, 2009 | 1990 Pontiac Grand Prix
2002 2.5l no oil pressure on gauge. Runs fine...no
You better put a manual gauge on your engine and make sure you have oil pressure. Could just be a faulty gauge or sending unit but I sure as heck would be checking it with a manual gauge.
Aug 01, 2009 | 2002 Jeep Wrangler
Espresso RMI La Cimbali Espresso Machine Logo
Top Espresso RMI Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you an Espresso RMI Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
