Question about Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White
How do you get the glass cover off to change the light bulb in the oven?
  • 50 Answers
There is usually a snap on wire over the top of the light lens. Gently push down on that wire.
Posted on Jan 01, 2011
4 Suggested Answers
SOURCE: kenmore oven: glass dome for interior light removal
Hopefully someone answered your question by now. If not, the glass bulb cover sticks sometimes, but it does turn counterclockwise. Be firm with it, let it know who's boss. Once you've removed it, you can replace the 40 watt appliance bulb. (The manual suggests you unplug the range or disconnect power for your safety). Good luck.
Posted on Nov 25, 2007
protek480
  • 1723 Answers
SOURCE: how to change the oven light bulb in a candy f245
The glass cover does come off. Use some latex gloves or non skid material and grasp the lens firmly and turn counter clockwise.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 15, 2009
Testimonial: "Spot on - I actually used insulating tape and water pump pliers- but I needed to know it would be ok."
SOURCE: unable to remove the glass cover to change the light bulb in oven
I went out and bought a 4 inch strap wrench from LOWE's. I had never heard of one before. After figuring out from the diagram how to use it, I wrapped it around the glass bulb cover and did a counterclockwise twist and off it came. P.S. I'm a girl so I feel pretty good about that project
Posted on Feb 28, 2010
How do I change the bulb inside the cooker of the B5741 cooker
Oven Lighting
Warning: There is a danger of electric shock! Prior to changing
the oven light bulb:
  • Switch off the oven!
  • Disconnect from the electricity supply.
Place a cloth on the oven floor to protect the oven light and glass cover.
Replacing the oven light bulb/cleaning the glass cover
  1. Remove the glass cover by turning it anticlockwise and then clean it.
  2. If necessary:
Replace bulb with a 40 watt, 230 V, 300 °C heat-resistant
oven light bulb.
3. Refit the glass cover.
Dado
Apr 15, 2015 | AEG Ovens
Where is the lightbulb In the oven and how do I change it?
Hard to give you exact location with brand or model number but here is what you look for. Open the oven door and with a flashlight look over the top and back wall of the inside liner. The light bulb is usually located behind a clear glass round cover. The cover may have a wire retainer across the middle of it to hold the glass. If it does, just flip or push the wire to the side and the glass cover will come loose. Unscrew bulb to replace. If no wire retainer, then there could be a metal plate with screws holding the glass in place. last type would be that the glass itself unscrews to get to the bulb.
Apr 02, 2015 | Ovens
HOW TO REPLACE THE LIGHT BULB IN MY OVEN
Oven Lighting
Warning: Risk of electric shock! Prior to changing the oven light bulb:
- Switch off the oven!
- Disconnect from the electricity supply.
Changing the oven light bulb/cleaning the glass cover
1.Remove the glass cover by turning it anti-clockwise and then clean it.
2.If necessary: replace with 25 watt, 230 V, 300 °C heat-resistant oven lighting.
3.Refit the glass cover.
24472822-skr3uzd4ii43xzwyhmpsswym-3-0.jpg Dado
May 21, 2014 | Electrolux EOB5665G Ultrafan Electric...
How do i change the oven light
Hi your light bulb is at the back of your oven behind a glass cover just twist this glass antyclockwise to get access to bulb.
Apr 08, 2014 | Ovens
How do I change the bulb in an Inglis oven. Can't
Normally the cover will have an anticlockwise turn thread. Twist the glass cover anti clockwise and it should unscrew.
Jan 04, 2010 | Ovens
How to replace oven light bulb for beko DC543 electric cooker
hi
You may need to remove the glass cover by turning it anti-clockwise.
On some models access to the bulb is from outside so the oven has to be slid out of it's housing and an access plate removed.
chek this following steps..
Step 1 Make sure the bulb is actually burned out. Confirm the oven is plugged in and that a circuit breaker is not tripped.
  • Step 2 Look for the manual to determine what size bulb is required. Most use a 40 watt appliance bulb. If you can not find the manual, then buy a bulb to replace it after you take out the old one.
  • Step 3 Confirm that the oven is not on. Allow it to cool to room temperature if it has recently been used.
  • Step 4 Open the door and use a flashlight to light the area where the bulb is located. Do not put weight on the door itself, but go in at an angle or sideways.
  • Step 5 Find the shield or cover over the bulb, gently pull or twist it off. Some glass covers are surrounded by a wire clip or a ring that is screwed in to the back.
  • Step 6 Gently remove either the wire clip or ring. Since the cover is most likely glass, be cautious. Unscrew the entire glass cover similar to a jar lid in older versions of ovens. Then repeat process if there is more than one bulb.
  • chek this usefull link
    http://www.espares.co.uk/advice/cookers-and-hobs/a/1/112/changing-your-oven-light-bulb.html
    hope u will b helpfull
    tnx for contactin fixya
    regards
    Jul 12, 2009 | Ovens
    How do I change the light bulb in the oven
    You can replace the light bulb(s) in your range/oven, though you may need to remove a glass covering or dome to reach it. Most interior oven lights use a universal 40 watt appliance bulb.
    Apr 24, 2009 | Philips Ovens
    Unable to remove the glass cover to change the light bulb in oven
    Jan 12, 2009 | Ovens
    Oven
    Pry back the bulb glass cover wire spring and remove glass cover. Use heavy rubber gloves or a plastic bottle opener(piece of serrated soft plastic/rubber) and unscrew counterclockwise.
    Mar 05, 2007 | Whirlpool GBS277PR Electric Single Oven
    Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
    142 people viewed this question
    Top Whirlpool Ovens Experts
    Sal De
    Oloyede Monsuru
    Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
