Question about Weber Gas Go-Anywhere Grill
I have a Weber Gas Go-Anywhere Grill that I want to connect to a propane tap on my travel trailer. The problem is that the tap is low pressure, it's located after the regulator. the Go-Anywhere has a combined high pressure regulator and controll knob that won't let gas flow. does anyone know of a low pressure controller or a way around this other than to disconnect the bottle from the trailer
  • 332 Answers
You can buy a "T" fitting that connects to the LP tank with a valve allowing you to pull LP gas off for your BBQ before the RV regulator
Most any RV shop can get them from NTP Distirbution
Posted on Mar 10, 2010
I have a weber s 620 made for propane but it was converted to natural gas. i had to replace the manifold and it is made for a propane so the grill is not getting hot what can i do?
You need have the orifices that match the fuel you're using - either propane or NatGas. Once you have the correct orifices installed, you should get the proper fuel flow. The propane is at a higher pressure, so the orifice for it is smaller than the ones needed for the lower pressure NatGas. Contact Weber for the kit needed for your model grill.
May 21, 2014 | Kenmore Elite 644 sq. in. Cooking Area Gas...
Low gas pressure
Spiders like to overwinter inside the nozzle attachment. A blast of canned air should clear it out.
Apr 14, 2008 | Weber Q Grill
We converted our weber Q q120 so it would work off our RV propane tank. It has a very low flame. We took the regulator off the grill and are using quick connect and a 15 ft hose to the grill. Help?
Your RV Propane System works on a different pressure than your, gas grill. Reinstalling the regulator may correct the pressure difference. Then install a short pipe nipple into the regulator and install a shutoff valve. After the shutoff valve, reinstall your quick disconnect hose. from here on after, each time you connect the hose to the grill, be sure the shutoff valve is OFF before making the connection. Then open the shutoff valve very, very, slowly, so as not to lock up the regulator.
Hope this helped you. Please let me know. Happy Grilling!!
Jun 24, 2011 | Weber Q Grill
How to change a weber natural gas grill to propane
According to Weber, "There is no conversion kit available to convert any Weber gas grill from one gas type to another. Any attempts to do it will void your warranty."
Sorry, but if it's any consolation, Propane Gas burns cleaner and hotter that Natural Gas in an outdoor environment. Which translates into faster preheating and hotter searing temperatures.
Hop e this helps and happy Grilling!!
Mar 19, 2011 | Weber SUMMIT S-620 Propane Grill
I have a Weber Q grill, propane tank is full but propane is not getting to burners. I do have a spark when I press the ignition. Where is it likely to be plugged up?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
Aug 20, 2010 | Weber Q300 Grill
New Tank won't light Weber Grill
Try checking the regulator, this is the round metal piece connected to the gas line. If this is not level flat the valve inside will not let propane flow through.
Apr 15, 2010 | Weber Spirit? E-310 Propane Grill
I have low flame on a weber gas grill. What are most likely causes and how to fix? Thanks.
Well it coulbe caused by these newer type propane tanks with the anti tip safety device installed inside them. To rectify you simply remove the tank to clear the pressure in the line and open all valve son the grill. Then close all valves on the grill and reconnect the tank. Then open the valve only just enough to allow gas into the grill, just crack it open a hair. Retry.
Oct 13, 2009 | Weber Grilling
Low flame
This problem most likely is with your regulator. if you decide to replace it please make sure you get the right size replacement. Some salespeople dont know the difference there are four common sizes from class 1 to class 4. If you take the old one with you make sure you match the numbers up with a new one.
Hope this helps You
please rate me.
Jul 18, 2008 | Weber Gas Go-Anywhere Grill
Weber Gas Go-Anywhere Grill Logo
266 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
