Question about Bosch Axxis WFL 2060 Front Load Washer
My Bosch Axxis washing machine stinks of mildew. We just bought this home, I have no manual. I'm running a cycle with bleach and hot water, the "Sanitary" cycle. There is a drain hose at the bottom R. corner of the machine. Is there a filter in there? Should I be doing maintenance on it? Thanks, Val Moilliet
SOURCE: New Bosch water not draining
Always leave the washer door open after use to allow inside to dry completely. Any remaining moisture invites mildew.
Posted on Apr 04, 2008
  • 1462 Answers
SOURCE: Bosch Axxis front loader will not drain
check filter. check no foreign objects fouling pump impellor - bra wires are the favourite
Posted on Apr 25, 2007
SOURCE: My Bosch 2060 Front end loader will not drain/spin
Get the pennies or dimes out of the accordian style black hose at the bottom of the washer. You will need to lay the washer against something so you can get in from underneath. Take a plyers and squeeze the medal clamp so the hose can slip off. I found 3 dimes that acted like washers. The machine will drain.
Posted on Jul 19, 2008
sdmc73
  • 121 Answers
SOURCE: my frontload washer stinks. I
you need to run affresh tabs thew it that will take care of it there aer made by w.pool
Posted on Nov 29, 2008
barkencoa
  • 3463 Answers
SOURCE: Bosch Classixx WFL 2462 Front Load Washer
Remove plastic panel at front bottom of washer, there you will see the filter, unscrew it anti clockwise to remove and clean, replace and tighten up clockwise.
Plz rate my solution.
Thanks.
Posted on Jan 17, 2009
Mildew odor in the machine....can't get rid of it and makes clothes STINK!
If you have a smelly front loading clothes washing machine, toss in a Finish Geltabs (the ones that are all liquid) and run the machine on a hot wash cycle, medium to heavy load (to get more water in the tub) with no clothes in the machine. You don't need to use much of a spin cycle so set it on low. The washing machine will come clean and even the moldy spots on the rubber gaskets will disappear. A second treatment may be needed if the smell is not completely gone. We tried everything from vineger to bleach to baking soda to borax to commercially available odor removers from Whirlpool and Tide. Nothing worked until I hit on this idea. It's cheap, easy and can be done anytime your machine needs a refreshing. I used the orange Geltabs but any fragrance would be fine. Keep the door on your washer open a bit when possible to air out to help preclude those nasty smells.
Oct 21, 2012 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Softener won't empty in Bosch Classixx 1000
take out the soap drawer clean in hot water inside the machine where you took the soap drawer out at the top look for the hole where the water runs out it may be blocked with mildew dettox mildew spray is very good at breaking all that down spray in leave for a while put soap draw back in and do a wash without clothing as spray contains bleach
Mar 30, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Machine clogged and rust and stink
to help clean the unit, do a large load of whites, extra bleach, extra-super-heavy-duty wash, hot wash and hot rinse. many small loads sometimes cause the unit to "smell up"
Sep 04, 2009 | LG WM2077CW XL Front Load Stackable Washer...
Rid of Mildew Smell?
Make sure there are no leaks from the machine. look behind it and check the water inlet hose and connectors for any damage. Also look under the machine for any water as this may indicate a leak from the internal hose and pipe work and / or water pump. Also check that the outlet hose is completely clear of debris and soap scum build up and check that the filter is clean.
To keep the machine clean of waste build up and to keep any bad odours away
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
7. Repeat the cleaning procedure monthly
Aug 22, 2009 | Bosch Nexxt 500 Plus WFMC5301UC
My GE Adora front loader- our clothes stink!
Clothes washing rules for mildew stink: 1) never leave clothes in machine for more than a few hours 2) never add too many detergent or clothes 3) clean the machine itself. Also if your fabric softener port is gummy there is a good chance you got some funk from that so clean all places where you have fabric softener contact. After all that, if this doesn't help you may need to run an empty load of strong hot bleach water and follow it with a hot empty rinse then a load of whites
to becareful not to ruin your colored clothes
Aug 09, 2009 | GE WSXH208A Front Load Washer
I have sour mildew smell problem with my clothes
Look inside the door to the gray rubber ring gasket thingy. Pull apart the sides and look in. Betcha a dollar to a donut there's mold in there. It's a gross, nasty problem whirlpool customer service doesn't give a damn about.That's where water sets after wash cycles. There are tablets call "Affresh" which can be run with hot water for a cycle to attempt to clean out the mold/mildew. Not cheap, not fair, and probably will only be a start to a maintenance type cure if you've had the washer for awhile. May take some manual labor with bleach as well. NOT a sanitary washer. This is an unbelieveable problem with a washer. Piece of ****.
Aug 06, 2009 | Whirlpool LHW0050PQ Front Load Washer
Maytag Neptune FAV6800AW Top Load Washer stinks like mildew!
i understand exactly...never heard of cascade ..the slug is to much what you have to decide which is more cost effective,,having a technician come out and taking tub apart for a manuel cleaning and scrb break down or purchasing new one..but i always tell my customers bleach every other month with hot wash cold rinse,,now i do have one last tip..try CLR..
Jan 04, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Smelly clothes and machine!
Do you wash whites separately or with bleach? Sometimes changing up the loads to whites with bleach would kill the germs.
Jun 12, 2008 | Bosch WFMC2100UC Nexxt Essence Washer
This video will show you how to change a door seal on this Bosch front loader washing machine
we have all bosch repairs in our channel
Apr 01, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
627 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
