Question about Frigidaire Dryers
How do I remove the top of a Frigidaire dryer - model GLEQ642AS2
  • Frigidaire Master
  • 7,482 Answers
I will include the instructions for replacing the belt, it will include the top removal and also a link that you can click on the see the belt routing.
http://www.applianceaid.com/images/belt-config.JPG
First, unplug the dryer. Lift the lint-screen cover and pull out the lint screen
If your dryer has a lint screen on the inside of the door, skip this step.
Then remove the two screws that are under the cover. To unlatch the dryer top,
insert a thin-blade putty knife between the top and front panel,
about 2 1/2 in. in from one corner. Push in on the knife to release the locking
clip, lift the corner, then release the clip on the other side. Swing the top
up and lean it against the wall.
Next, move to the lower toe panel. Slip the putty knife between the lower panel
and the door panel at one side and twist the knife to release the clip
Then release the opposite clip and lift the panel up and off the hinge springs.
To support the dryer drum while the belt is being replaced, place scrap wood
under the front of the drum.
Loosen the two screws at each side of the bottom of the front panel.
Move to the top of the panel and remove the screws from the inside of the
cabinet that hold the front panel to the sides.
Slide the old belt off the drum.
Installing the belt
Lean the front panel out slightly and allow the drum to rest on the scrap wood
support. Drop the new dryer belt between the front panel and the drum, and
loop it over the drum. Then, lift the drum slightly while pushing the front
panel back into position.
Replace the screws at the top inside of the front panel, tighten the lower panel
screws and remove the scrap wood from under the drum. Check to make sure that
the rear drum seal fits properly over the lip on the rear bulkhead.
Position the new belt where the old belt was, with the grooved side of the belt
facing down.
Now, move to the motor area and pull out the old belt. To route the new belt
around the idler and drive pulley, first pass the entire belt, doubled up,
under the idler pulley. Then, push the idler belt toward the motor, slip the
belt around the motor pulley and release the tension on the idler pulley.
Open the dryer door and rotate the drum counterclockwise a few times to make
sure the belt is tracking properly. Lower the top and press down at each
corner to engage the clips. Lift the lint-screen cover, replace the two screws
and reinstall the lint screen. Finally, secure the lower front panel and turn
on the dryer for a test.
This is a FREE answer
Please RATE me
Posted on Jan 02, 2011
The dryer works but makes a loud thumping noise model#GLEQ642AS2
All dryers have some type of roller system that supports the drum as it turns. It sounds like one of the rollers or roller bearings has worn and is making that thumping noise. If you have some basic skills and good general mechanical sense you could fix it yourself. Make sure the dryer is unplugged before you attempt anything.
Feb 25, 2011 | Frigidaire Dryers
Replacing Control Board on Frigidaire model LEQ1442ES0 Dryer
There should be screws on the back side of the top panel that come out. Then the panel will slide out so that you can access the front controls.
Aug 18, 2009 | Frigidaire FEQ1442ES Electric Dryer
Model#GLEQ642AS2
If the drum is not turning and the hum is a nice quiet hum, then the belt on the drum has broken. The hum you hear is the motor turning without the belt.
If this helps you, please select YES to one of the first two ratings questions. Thank you, and Good Luck.
Aug 17, 2009 | Frigidaire GLER341A Electric Dryer
No heat
You gotta pop the top and remove the front which is very easy. Access the idler and remove the belt and get the tub out.. Here is a quick guide
Apr 04, 2009 | Frigidaire GLER642A Electric Dryer
My frigidaire dryer had burning rubber smell now wont turn on
soulds like the fuse in the unit overloaded, fluff or oter items may have fallen onto the element, or the unit was overloaded, and the belt was slipping on the motor drive pulley. check for rubber drive belt debri. replace damaged items as required.
Jan 25, 2009 | Frigidaire GLER642A Electric Dryer
Stacking a frigidaire washer and dryer
This stacking part is all you need. It is a white plastic bracket that attaches from the rear of the two appliances. And it should have come with instruction too.
Dec 05, 2008 | Frigidaire GLTF1670A Front Load Washer
Frigidaire dryer model #GLER341AS2
along back edge are 4 screws remove and slide top forward
May 10, 2008 | Frigidaire FEQ1442ES Electric Dryer
Frigidaire GLEQ642AS2
Sounds like a wire problem. Frist unplug the unit. Then take the cover off where the wires go in the back to check for a burnt wire. If that is ok you need an amp meter to check for the heater amp draw. You could have a weak breaker.
Apr 24, 2008 | Frigidaire GLEQ642A Electric Dryer
How to stack w/d gas Frigidaire Gallery dryer
You are supposed to remove the top of the washer, and the dryer feet lock into brackets...but being lazy I just bolted the dryer to the washer using some metal straps (1/16" x 8 x 4 ") with some machine screws, and it's been fine for years. Not pretty, but I had the same question and no handy internet to help me at the time ;P
Apr 08, 2008 | Frigidaire GLGQ642A Gas Dryer
Dryers Logo
478 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
