Question about Brother MFC-465CN InkJet Printer
Where are the printer ink cartridges located?
  • 23 Answers
Hope that helps.
Posted on Jan 01, 2011
Testimonial: "Problem solved immediately. Thank you so much!"
How do you remove ink cart.
To replace an ink cartridge on a Kodak ESP C310 follow these steps:
1) Make sure your printer is on.
2) Lift the printer access door, and wait for the carriage to move to a position where you can access it. The ink cartridges are located in the printhead.
3) Pinch the tab on the ink cartridge.
4) Lift the ink cartridge out of the printhead.
5) Remove the new ink cartridge from its bag.
IMPORTANT:To prevent the printhead from drying out, insert the ink cartridge into the printhead immediately.
6) Remove the protective cap from the cartridge.
7) Insert the ink cartridge into the printhead.
8) Press down on the ink cartridge tab until you hear a click.
9) Close the printer access door.
That completes changing the ink cartridges.
Thank
Mark
Aug 25, 2014 | Kodak EasyShare Office Equipment &...
Cartridge error,refer to devise documentation to troubleshoot
Hello
Turn on the printer and open the cover where the ink cartridge is located. Remove the cartridge.
Place the ink cartridge back in the carriage. Close the cover. Turn the printer off for a minute.
Turn the HP printer on. Use the printer to print a test page. If this does not correct the problem, move on
Remove the cartridge and use a clean, lint-free, dry cloth to gently wipe the contacts.
Wipe from the top of the contact to the bottom. Do this for each contact.
Place the HP ink cartridge back in the carriage. Turn the printer off for a minute.
Turn on the HP printer, open the cover and remove both the black and color cartridge. Close the cover.
Remove the power cord from the outlet and disconnect the cables running to the computer and/or router. Wait one minute, and then plug in the power cord and then the cables.
Open the cover and install the black and color ink cartridges. Turn the printer on.
Turn the HP printer on. Use the printer to print a test page. If this does not correct the problem, you will need to buy new ink cartridges. Office Max or Wal-Mart have ink cartridges for almost every model of HP Deskjet, Photosmart and Officejet printers.
Jun 10, 2011 | HP Officejet 5610 All-In-One InkJet...
Colour ink cartridge not reconise. replace colour ink cartridge.cod 3603
To resolve the issue:
  1. Make sure you install the correct type of KODAK Ink Cartridge for your printer. Currently we offer two types of ink cartridges (10 Series and 30 Series). Installing the wrong type of ink cartridge may result in this error. You will need to install a new, correct type of KODAK Ink Cartridge.
    NOTE: For more information, see Which ink cartridges to buy for all-in-one printer.
  2. If you are using the correct type of KODAK Ink Cartridge, reinstall the color ink cartridge.
    1. Open the printer access door.
      NOTE: If the ink cartridges don't move to the center, see Printhead and ink cartridges don't move to center with access door open.
    2. Wait until the printhead is idle and silent, then pinch the latch on the color ink cartridge with your thumb and forefinger and lift it out of the printhead.
    3. Install the color ink cartridge back into the printer, making sure to press down on the thumb tab until it clicks into place.
    4. Close the printer access door. For printers with LCDs, follow the instructions on the LCD screen.
      For more information on installing ink cartridges, see the Extended User Guide for your printer. Review Maintaining Your Printer - Replacing ink cartridges.
  3. If the error continues, restart your printer:
    1. Turn off the printer by pressing the power button.
    2. Wait five seconds.
    3. Turn on the printer.
  4. If the error continues, and you have extra, new KODAK Ink Cartridges on-hand, try to install a new ink cartridge (or a set of new ink cartridges).
  5. If the error continues, contact us.
When the issue is resolved, we highly recommend that you upgrade the firmware for your printer for optimum performance:
  1. Locate and select the firmware for your printer.
  2. Follow the instructions to install the firmware.
Source: http://support.en.kodak.co.uk/app/answers/detail/a_id/39315/selected/true
Jun 07, 2011 | Office Equipment & Supplies
Cartridse error
If you see a message saying that you have an incorrect ink cartridge, a flashing cartridge light meaning a bad color cartridge or you are told to remove the color cartridge, you should follow these steps to correct the problem if you are sure you have installed the correct color ink cartridge.
Instructions
Reinstall the ink cartridge
1. Turn on the printer and open the cover where the ink cartridge is located. Remove the cartridge.
2. Place the ink cartridge back in the carriage. Close the cover. Turn the printer off for a minute.
3. Turn the HP printer on. Use the printer to print a test page. If this does not correct the problem, continue reading.
Wipe down the cartridge contacts
2. Remove the cartridge an use a clean, lint-free, dry cloth to gently wipe the contacts.
3. Wipe from the top of the contact to the bottom. Do this for each contact.
4. Place the HP ink cartridge back in the carriage. Turn the printer off for a minute.
5. Turn the HP printer on. Use the printer to print a test page. If this does not correct the problem, continue reading.
Reset the Officejet printer
1. Turn on the HP printer.
2. Unplug the power cord from the back of the printer and wait one minute.
3. Plug the power cord back into the printer. Press the on button and hold until printer turns on.
4. Print a test page to see if this has fixed the problem. If not, you will need to buy a new color ink unit.
Jun 04, 2011 | HP Officejet 5610 All-In-One InkJet...
How do I change the ink cartridge in a Lexmark x2330
  • Turn the Lexmark printer on by pressing the power button. Usually, the power button is located on top of the Lexmark printer. If the Lexmark printer does not power on immediately, then hold the button down for a few seconds before releasing it. Once the Lexmark printer has powered on, the installed cartridges will begin to move back and forth for a few minutes.
  • 2
    Raise the Lexmark printer cover up towards you. Doing this will give you instant access to the inside components of the Lexmark printer. Lift the cartridge release lever and remove any installed ink cartridges. Be careful when doing this because the ink may leak out. It's best to have a disposable bag or paper towel near you when performing these steps.
  • 3
    Remove the plastic from the brand new cartridges by carefully cutting them open with scissors or tearing along the perforated edges. Once you have removed the plastic, there's a yellow tag located near the bottom of the ink cartridge. Take this tag off only when you're ready to insert the ink cartridges into the slots.
  • 4
    Tear the yellow tag from the ink cartridges and place them into their corresponding slots. Each one will be easily identified by its color. The cartridge release lever will have the same color as the ink cartridge. If you mistakenly place the cartridges in the wrong slot, then you'll risk having your Lexmark printer stop working properly.
  • 5
    Press the ink cartridges into the slots and listen for a clicking noise after the insertion. Although you will need to firmly place the ink cartridges into the available slots, it still needs to be done gently. Close the Lexmark printer cover when you've completed the previous steps. Wait a few minutes for the Lexmark printer to recognize that you have inserted brand new ink cartridges. After a few seconds, it will go through some diagnostic steps to make sure the ink cartridges were correctly inserted.
  • 6
    Print a test page on your Lexmark printer. This will help you to determine if the ink cartridges are properly working. You can view the newly printed images and text after the Lexmark printer has finished printing. Get rid of your used ink cartridges by throwing them away or sending them to an online store that accepts empty ink cartridges.
  • Jan 17, 2011 | Lexmark X2330 Printer
    I whant to refill pixma canon ip2700 with black ink but dond now how
    Color Cartridge 1. Place the cartridge over somepaper towels in case there are any spills.Remove the label sticker from the topof the color cartridge. 2. Drill into the three small holeson the top of the cartridge to widen them so they will allow syringe needles. 3. Fill a syringe with 6 mL ofmagenta ink. Insert the needle into the refill hole that is located below thetwo protruding rectangles on the top of the cartridge. Slowly inject the ink. 4. Fill a syringe with 6 mL of cyanink. Insert the needle into the refill hole located below the large rectangleon the top of the cartridge. Slowly inject the ink into the cartridge. 5. Fill a syringe with 6 mL of yellowink. Insert the needle into the refill hole located below the small rectangleon the top of the cartridge. Slowly inject the ink into the ink chamber. 6. Replace the cartridge into theMX310 printer. Black Cartridge 1. Set the cartridge on some paper towels. 2. Drill a hole into the dimplelocated directly above the semicircle on the top of the cartridge.Fill asyringe with 20 mL of black ink. Insert the needle into the hole and slowlyinject the ink. 3. Replace the cartridge into theCanon MX310.
    Nov 28, 2010 | Canon PIXMA MX310 All-In-One Printer
    Where is ink cartridge located on mp 620
    Look at the front, the ink cartridge cover is at the bottom right corner. Need to flip open to remove the cartridge
    Apr 18, 2010 | Office Equipment & Supplies
    "Print carrier stall"?
    Error 0502-Carrier Stall indicates a physically blocked carrier. This condition can occur for many possible reasons. Most often, the carrier is blocked because the ink cartridge lids are open while the printer is on (Figure 1).
    Figure 1: Open Ink Cartridge Lids
    Reseat the Ink Cartridges and Make Sure the Lids Are in Place
    1. Make sure the printer is turned on.
    2. Lift the printer's front cover.
      new_note.jpg Note: The ink cartridge should be in the up/loading position unless the printer is busy.
    1. Squeeze the tabs on the cartridge lids and lift the cartridge lids up. The cartridge pops up when the lid is fully lifted.
    2. Remove the cartridges.
    3. Make sure that all of the protective tape has been removed from the contacts on the ink cartridge.
    4. Replace the cartridges.
    5. Snap the lids closed.
    6. Close the printer's front cover.
    7. When prompted on the printer's LCD to choose New or Old, choose Old.
    8. Press Select.
    new_note.jpg Note: For more information about reseating ink cartridges, refer to the Maintenance or Ink Cartridge Maintenance section in the Online User's Guide.
    Back to Top
    » Reposition the Encoder Strip
    1. Remove the power cord from the printer.
    2. Lift the scanner unit to expose the inside, where the printer cartridges are located.
    3. Gently slide the ink cartridge carrier to the middle of the printer.
    4. Gently move the top part of the printer belt to the right.
    5. Using an index finger, gently push encoder strip (Figure 1) down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
      Figure 1: Inkjet Printer Encoder Strip
    6. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
    7. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
    8. Once the encoder strip has been re-seated, close the scanner lid.
    9. Re-connect the power cord to the printer.
    Jul 18, 2009 | Dell 922 All-In-One InkJet Printer
    Dell Printer A940 Hardware error
    Back to Top
    » Reseat the Ink Cartridges and Make Sure the Lids Are in Place
    8. Press Select.
    Back to Top
    Jul 03, 2009 | Lexmark X5150 All-In-One InkJet Printer
    Where do i replace the the ink cartridge on a 3700dn printer
    Although I can't find the specifics on your model, most HP allow access to the ink cartridges by lifting the front cover. The cartridges then move from their parked location. Note: the printer must be on when you do this. Perhaps you provided the wrong model number, here's a link to HP Support
    Dec 07, 2008 | HP Printer Cartridges (Complete List): ,...
    Brother MFC-465CN InkJet Printer Logo
    112 people viewed this question
    James Cagle
    James Cagle
    Samyfam
    Samyfam
    Victorman
    Victorman
