Question about Dacor ER48DSCH Dual Fuel Range
My digital display on my dacor er48sd will not display anything and it keeps beeping. I changed out he digetal contol panel no help. Can you help me
3 Suggested Answers
Krazytech
  • 725 Answers
SOURCE: Dacor duel fuel range
F1 is a Relay circuit failure . you have a bad relay PCB or wire connection.
92028 RELAY PCB, 105 C
Posted on Aug 25, 2008
mastatech
  • 478 Answers
SOURCE: Dacor RSD30 beeps and displays F1 warning... do I
You need a control board replacement. This will require taking the panel off, just be sure to kill the power and replace wire for wire. Its fairly easy once you have the panel off. Just reassemble in reverse order.
Posted on Oct 27, 2010
Testimonial: "Thanks. that's what I figured."
My Dacor oven keeps beeping and flashing PRB. How do I stop the beeping?
Most unwanted beeping on Dacor products are due to a bad touchpad... Use your model # and start looking for a replacement , by touchpad I mean a part something like this one: Dacor Touchpad 62678B
Jul 12, 2016 | Dacor Epicure 30" Double Wall Oven,...
Dacor DM02420S Micrwave Display Screen - Can't see anything
can you see any thing like a circuit in that pannel.check for the soldering joints in that pannel.
Oct 12, 2008 | Dacor DCM24 Convection/Microwave Oven
Dacor wall oven MORD230 cont'd beeping,disconnecting power to unit did't work,error code 01 appear on display
Hello. The error means there is a shorted key on the keypad. The part number you will need is 701044-02, called "membrane panel assembly, black". The main board, if needed, is 101991, called LED display module. Hope I helped you!
Aug 21, 2015 | Dacor Ovens
F1 error relay circuit failure
Hi This is the Alarm system watchdog circuit :
The system has detected a failure in the internal watchdog element , relay circuits and will atcivate a cancel feature. F1 will be displayed in the time digets and will beep until the cancel button or another funtion is selected. An F1 failure could be detected in cook or time of day mode. With an F1 failure the ERC is picking up a comand to supply heat without receiving an input from the membrain. The watchdog circuit is designed to prevent this.
If the beep continues after pressing cancel check the main control ERC board.
Dec 09, 2011 | Dacor MCS130 Millennia Electric Single...
Dacor RSD30 beeps and displays F1 warning... do I need a replacement panel?
Oct 27, 2010 | Dacor Preference RSD30 Gas Kitchen Range
Dacor oven beeps and shows F1 code
-F1- Alarm “System Watchdog Circuit”
The system will detect a failure in the internal watchdog element relay circuits and will activate a
cancel feature. F1 will be displayed in the time digits and will beep until the cancel button or another
function is selected. An F1 failure could be detected in cook or time of day mode. With an F1 failure
the ERC is picking up a command to supply heat without receiving an input from the membrane. The
watch dog circuit is designed to prevent this.
If the beep continues after pressing cancel check the main control (ERC)
Dacor
Aug 20, 2009 | Dacor ECS130 Epicure Electric Single Oven
Timer tone goes off with F1 display
Hi arl3933,
The "F1" error code description is a System Watchdog Circuit. Please press "CANCEL", if beeping continues after 30 seconds, please check the main control board(ERC). Here are basic test that will help you to determine if the ERC or touchpad is defective.
1. Unplug the range power cord or turn the power off to the range at the circuit breaker.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the code comes back.
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Hope it helps.
Thank you for using FixYa.
May 14, 2009 | Dacor Preference RSD30 Gas Kitchen Range
Dacor ECS136 Control panel just beeps but does not work
i am having that problem with my maytag one. the only thing i can do is unplug it and quickly press bake and set the temp and time length. mine says its locked though. i am trying to figure out how to unlock mine.
Oct 30, 2008 | Dacor ECS136 Epicure Stainless Steel...
Aug 19, 2008 | Dacor Preference RSD30 Gas Kitchen Range
PCS 130 Keypad
Dacor probably won't cover anything. F1 is either the touch pad or ERC (clock). If it stops beeping when the touch pad is uplugged from the ERC then the touch pad is the problem if not it is the ERC. Call Dacor Customer service to get a price on the parts and to voice your displeasure.
May 22, 2008 | Dacor PCS130 Preference Electric Single...
Dacor ER48DSCH Dual Fuel  Range Logo
22 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
240cpa
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
