Question about Janome Sewing Machines
It will turn on but i can not get it to stitch is there anything i can do at home to fix it
  • margarose Jan 02, 2011
    What machine do you have?
I am having the same issue with mine...brand new out of box and my thread is bunching and tangeling under the foot from the bobber thread...have yet to make one stitch...so if you get an answer...let me know please and I will do likewise...
Posted on Jan 02, 2011
Singer 4530- stitch length adjustment not working. How do I fix?
Since you indicated the machine has been cleaned and lubed, that is probably not the problem unless the stitch length lever is sticky or the feed dogs are hanging up somewhere. Suggest perhaps directing heated air from a handheld hair dryer into the internal mechanics (focus on the stitch selector lever and the feed dog mechanics) and see if that loosens anything.
Apr 04, 2016 | Singer Sewing Machines
Stitch length will not change
Setting Stitch Length: A Quick Look at How and Why ...
www.sew4home.com/.../sewing.../setting-stitch-length-quick-look-how-a...
Mar 3, 2015 - The majority of sewing machines indicate stitch length in millimeters. A 2.4 stitch length means each stitch will be 2.4 mm long. ... When you adjust the stitch length, it's not the needle that is changing, it's the feed dogs (those ...
How to Select Stitch Length ' Sewing Lessons - YouTube
? 2:40
https://www.youtube.com/watch?v=YqwHtYpKBzo
May 31, 2011 - Uploaded by HowcastArtsRec
Learn how to select stitch length when using your sewing machine for ... also not so small that it will take forever to get through your machine.
How Do I Fix My Sewing Machine: Troubleshooting Your ...
www.craftsy.com > Blog Home > Sewing Blog
Jan 24, 2016 | Sewing Machines
Singer futura xl-400 machine software is corrupt how do I fix it.
Is this when you're sewing, rather than doing embroidery? If that's the case, you might have a motherboard problem. You should make arrangements to get it serviced.
Aug 14, 2014 | Singer Sewing Machines
Janome sewing machine dial moves
I have exactly the same problem. Did you find a solution? If so I'd be really grateful to hear it ... Thank you.
Oct 23, 2012 | Janome Sewing Machines
My New Home HF-1012 buttonhole stitches don't work.
Take it back... and have him fix it again... this time ask him to tell you exactly what he did to get it to work.
Aug 29, 2012 | New Home HF-1012 Mechanical Sewing Machine
HOW DO YOU FIX THE STITCH WIDTH POSITION CONTROLL BAR, WHEN IT WONT MOVE AND IT IS STUCK AT ZERO?
it would be a good idea to have the machine checked to see
if the stitch width control bar is damaged or some other part is
Jun 09, 2012 | New Home MX-3123 Computerized Sewing...
My stitch length varies whilst I'm sewing. Why does this happen and what can I do to prevent this from happening?
Is the stitch selector set to a straight stitch or is it possibily in another stitch pattern but with the width turned down to zero?
If machine is set on a straight stitch but is giving varying stitch length for no reason then it could be that the feed dogs are not functioning correctly, could be out of time with the needle or very worn. Or are you pulling the fabric through rather than letting it feed through. Also check the pressure being delivered by the foot pressure if the machine has a variable adjustment for this. It may have just been turned down for very heavy fabric feeding and needs to be turned up to normal setting again.
Feed dogs can wear - replacement parts may be available. Just remember to search under either Janome or New Home as I believe New Home was bought out by Janome some years ago. Certainly New Home was a common brand in UK in the 80's.
You might find parts on www.sewingpartsonline.com or http://www.sewingparts.co.uk/
I hope that this helps you out.
Apr 25, 2011 | New Home Sewing Machines
Loose bottom stitch
If you feel adventureous you can take the bobbin case apart and make sure that it is clean and thread runs smooth thruugh it. This is delecate to do and takes younger eye's than mine and do this on a clean table covered in a plain cloth so you don't loose parts and don't force anything when putting back together it is stanliss steel but will break and screws can strip. If you have been sewing any thing that has any glue or is dirty you could have a build up that is draging the thread. Sometimes just a good cleaning in warm mildely soapy water will fix this.If tightening your upper tention helps some this is a good indacator that this is the problem.
Aug 21, 2009 | New Home L-372 Mechanical Sewing Machine
Sewing Machines Logo
21 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
