Question about Nikon D90 Digital Camera with 18-105mm lens
My Nikon D90 has started to shoot images with what appears to be hair in lens, Switched lense to Macro and hair is still there It is always in varying shapes, so to speak But is ruining my images It is most prevalent with Blue sky background/ Really then you can see it Also trid taking it out of manual Mode to Auto still was not shooting Clear Images??? Thank you
    Novelist:
  • 88 Answers
If you switch lenses and the hair is still appearing on your pictures, it is quite possible you have an actual hair or thread or something located in the camera body in the way of the sensor. Remove your lens and visually examine the inside of the body for debris. Stay clear of the sensor and the mirror, but you can use tweezers to remove an obvious foreign object. You can also command your mirror to stay up and out of the way (see the camera setup menu "mirror lock up") for closer examination. It's best to use a bulb type squeeze blower to blow out debris from inside the camera. Do an internet search on "rocket air blower" and you'll see what I mean. Blowing air from your mouth can introduce moisture.
Posted on Jan 03, 2011
D90 wont shoot in auto mode. gives me r21 error. Manual mode works fine
Did you switch the Focus-mode selector to MF?
It is the switch with number 8. Perhaps you are used to switching on the lens, but on the body is also a switch. Normaly used for the older AF lenses.
Apr 22, 2014 | Nikon D90 Digital Camera with 18-105mm...
Toyo 500mm lens to nikon d90 mount
At the risk of being obvious, you need a Nikon mount.
The lens comes with a T-mount. This is a "universal" mount with adapters for almost any camera mount, including the Nikon F mount. If the lens doesn't come with one, get a Nikon T-mount adapter.
The lens doesn't have any electronics, so you'll be shooting completely manual. No autofocus, no autoexposure, not even any exposure help from the camera's light meter.
Feb 23, 2013 | Konica Minolta Minolta Telephoto Camera...
I have new Nikon D90 with 18-105 Nikon lens. The only problem with the camera, when shooting potraits in dim light without flash, the pictures get black artefacts throughout the faces and skins. I used...
iv seen this on canon, are you sure it is on final image or only on view of image on camera?
view image out of camera it could be that it is not effected.
I hope this was useful.
Jan 24, 2011 | Nikon D90 Digital Camera with 18-105mm...
I have a Soligor C/D 28 - 200 mm, f3.5 - 5.3 Macro lens used quiet well on a Minolta XG1 and want to know whether I can use it on a Nikon D90 DSLR and if so, where can I source an adapter. Is it worth the...
The lense will probably work with an adapter. try ebay. i purchased one for my canon lenses for macro work. note that the focal length of the nikon is 46.5 and the minolta is 43.5 and infinity will not work with out an adapter with a correcting lense. you will find a adapter with out a lense will work fine for macro.
Jul 19, 2010 | Cameras
WILL THIS MODEL JELL WELL WITH THE NIKON 50mm LENSES (NORMAL) & OTHER BRANDS OF 50mm LENSES (NORMAL) THAT IS WITH NIKON D90 DSLR
The Nikon D90 works well with the Nikon AF 50mm lenses and most other brand Nikon fit AF lenses. If they are not AF you will lose autofocus and metering.
Do you know that on the D90 the lens becomes a 75mm but the aperture stays the same, so for instance the 50mm f/1.8 is a 75mm f/1.8.
Jul 16, 2009 | Nikon D90 Digital Camera with 18-105mm...
I'd like to purchase a micro lens for my Nikon camera. My question is: Does the Phoenix AF 100mm f/3 5 Macro Telephoto Lens used with Nikon D 90''
If the Phoenix lens is autofocus (AF) in Nikon mount, it will work with the D90. You may find that you want to switch to manual focus when you are using it for macro shots for better control of focus. It will still set exposure properly when set to manual focus.
Apr 03, 2009 | Cameras
Lense will not work with SLR Nikon D90
This lens is too old for the D90, it has not got the electronics for metering and autofocus.
You can use it manually in M mode but you will have to set the aperture and shutter yourself.
The D90 manual has a section on compatible lenses, page 228 in my version.
This recommends CPU lenses for the D90, type G and D.
Dec 25, 2008 | Nikon Zoom 80-200mm f/4.0 AIS Lens
Lens for Nikon D60
I will try to help you, but please understand that my experience is with Nikon film cameras. Assuming that the D60 works in a manner similar to a Nikon 35 mm body and that Sigma macro lens work like Nikon macro lens, you should be able to determine the usable subject to lens distance by experimentation. First, make sure the lens is in the macro mode. To do this you must set the auto-focus mode control to the manual focus mode (see your manual). On Nikon lenses, you must first set the focus ring to infinity, then move slider switch, which has two positions marked; "normal" and "macro., to the macro position. You should now be able to rotate the focus ring to the macro range. Use the zoom ring to zoom in and out and focus with the focus ring. The the range over which the lens to subject to lens distance will yield an in focus image will be rather limited and in the range of an inch or so to 6 or 8 inches.
Dec 09, 2008 | Cameras
Problems using camera
Hey PopPop1,
The N2000/F301 should be a manual focus only camera. The autofocus version of this camera was called the N2020/F501. The lens you have should still work on the camera, but you should have to focus the camera manually. I have an autofocus camera and whenever I shoot macro images I would much prefer manually focusing anyway.
Sincerely,
Allan
Go Ahead. Use Us.
May 15, 2008 | Cameras
Nikon D90 Digital Camera with 18-105mm lens Logo
65 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
