Question about Lexmark X7350 All-In-One InkJet Printer
Scan images file size seems very large
When I scanned 7 pages they show up as 12MB, does this sound right?
  • 39 Answers
That entirely depends on your scan settings. The resolution has a huge impact on file size - doubling the resolution from, say. 150dpi to 300dpi actually quadruples your file size. That being said, your scans are probably saved as BMPs. If you scan to Paint or a proprietary image editor (like Photoshop), then you can save in a compressed format like JPG or PNG and reduce the file size some more.
Bottom line - if you're scanning a full size (8.5x11) page, then less than 2MB per page is pretty decent, especially if the file is a BMP. If these are 4x6 photos, then it's still not bad if you're using a resolution like 300dpi. My digital camera takes photos at 5megapixels and the files are often 1-2MB each, and those are just photos.
Posted on Aug 06, 2008
How do I reduce scan file size when the resolution is already 200 dpi?
An 8.5 inch wide document scanned at 200 dpi gives you an image that is 1700 pixels wide. This is almost enough to fill a fullHD TV screen at native resolution (1920 pixels wide) which is unnecessary detail. I would use any picture editing programme (many free ones available) to reduce the overall pixel width of your already scanned images by 50 percent. This will automatically reduce the 1MB image to 250k. If you can scan again, use 100 dpi to scan - the result is same; image will be half as wide (and long), and picture file size one quarter of the 200 dpi scan.
Sep 12, 2017 | Samsung CLX6220FX AllInOne Laser Printer
How do I scan multiple documents and email them as one attachment
1. Click PDF on the Custom Scan with One-click tab or click PDF in the one-click mode screen to open the PDF dialog box.
* If you wish to convert the text in a document to editable text data, scan the item with the OCR. The precision of OCR is affected by the nature of the scanned original
2. Select the type of document to be scanned.
Important
To scan correctly, select a document type that matches the document to be scanned.
3. Select a file type to save the scanned image.
Select PDF, PDF(Multiple Pages) or PDF(Add Page)
Important
Click Set... to open a dialog box and specify the PDF compression type and other advanced settings for creating PDF files.
4. Place the first original on the scanner and click the [Scan] button at the right bottom corner of the PDF window.
5. When scanning is completed, place the next original and click the [Scan] button.
6. Repeat scanning by clicking the [Scan] button until you finish all the originals.
7. When all the original is finished, click the [Exit] button.
8. When the scan is complete, it automatically starts the application program that displays PDF files and opens the scanned image file in it.
To scan a text document or black and white document, you are recommended to set the Scan Mode to Black and White or Grayscale.
You are recommended to limit the number of pages in any one multiple PDF file to 20 or less if you are scanning a color document with the Image Quality set to 300 dpi and the size to a setting equivalent to Letter size.
Aug 07, 2013 | Canon MP Navigator EX for Windows
Scans are too large...
while scanning try reducing the DPI of the scans. this will make the image smaller in size but it will effect the picture quality very little. but do keep in mind that the dpi must be atleast 70 for better picturization
Feb 01, 2010 | HP Officejet Pro 850 InkJet Printer
When I save a scanned document you increase the file size. Please. Thanks.
Document size can be set before you scan.
Your scanner software should give you options for type of document and resolution settings. If your documents are to large, set resolution lower.
Example, Black and white or greyscale scans are much smaller in size than color documents.
Saving files as jpg will compress the file for storage.
If you have an image editing program you can decrease the size of the file after the scan.
Dec 09, 2009 | Kodak Office Equipment & Supplies
SCANS PAGE IN TOO LARGE
Uncompressed TIFF files are large in size. If you want Black & white and also small size save in TIFF G4 format. JPG files are small, but only color and grey files can be stored in JPG format.
S. Mohan
Oct 01, 2009 | Fujitsu fi-5120C
Can't save multiple page scan to multiple page pdf document
that should be because you scanned the pages separately, did you notice if the PDF document converted was the very last page of the 13paged document which you wanted to make a document from? if that's right, then you just only converted the last scanned page into PDF, to stick all the pages together, i recoment you treating them as images and using word to stick them all together with the "insert>image> from archive" adjusting the size of the image at 1 page and with each 13 pages do the same until you have a full document of 13 images in 13 pages then you can convert it into PDF
Sep 14, 2009 | Brother Multi-Function Center MFC-240C...
Scanning docs & size of pdf files on Mac w/HP l7680 All-in-one
The scanner produces a "picture" of the document, much as if you laid it flat on a table and took a picture of it with your digital camera. If you did this, your .jpg from the camera would be several hundred K at a minimum - comparable to the file size off the scanner. That's why the file is so big, it contains a picture and not text data - even though it's still a .jpg file.
If you reduce the scan resolution you will save space, but at the expense of legibility of the document image. To get it down to the smallest possible size, you will need to run the scanned image through OCR ( Optical Character Recognition ) into a Word document for example, and then print it out to a .pdf file. If you have a clean source document with few graphics this isn't as difficult as it may seem. Microsoft Office has an excellent OCR process known as Document Imaging. You need to carefully proof read the result but with a clean input Document Imaging is amazingly accurate in Office 2007.
In short, there is no easy solution to your problem.
Dec 30, 2008 | HP Officejet Pro L7680 All-In-One Printer
Scanning problem!
First Scan only a single page and note file size. Now scan 3 or 4 pages ad check the file size. If it is more, then the scanner is clubbing/collating all the images into a single file. Check your software settings and disable this feature if you want individual files.
S. Mohan
Mar 12, 2008 | Fujitsu fi-5750C Flatbed Scanner
Photos
Does this help? You obviously have to insert the media type into the media slot on the far right.(omoademola) Using the top control panel Printing tasks Scanning/Copying/Faxing tasks Troubleshooting
The top control panel lets you print an image from a photo card, scan a document or image, and copy a document or image with the press of a button.
Button/Light: Function: 1 Power : Turns the All-In-One on or off. 2 Copy: light Illuminates when Copy Mode is selected. 3 Mode: Changes the copy, scan, or photo card mode. 4 Scan: light Illuminates when Scan Mode is selected. 5 Photo Card: light Illuminates when Photo Card Mode is selected. 6 Rotate: Rotates the image 90 degrees. 7 LCD Panel: Number of Copies- this changes the copy count. Note: This feature is not active in Scan Mode. 8 Display: Shows copy, scan, and photo card selections. 9 Resize: Enlarges or reduces the size of the image. 10 Page Preview: Shows a preview of the output. 11 Select: Secures an option. 12 Menu: Provides options for image. 13 Arrow : Scrolls left, right, up, or down. 14 Stop/Clear: Cancels a print job or clears a selection. 15 Color Start: Initiates color copy, scan, or photo card output. 16 Black Start: Initiates black copy, scan, or photo card output.
Jan 10, 2008 | Lexmark P4350 All-In-One InkJet Printer
Lexmark X7350 All-In-One InkJet Printer Logo
145 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
