Question about Fuji FinePix Z5fd Digital Camera
My flash won't trigger on my Fuji Finepix AV Digital Camera? Even when I set it to trigger in all conditions..
I had same problem. Went to settings....reset. flash worked again. Don't ask me how it was a last resort and hey, it worked!
Posted on May 28, 2013
  • 198 Answers
SOURCE: can't download pictures from camera
perhaps your Fuji download program is corrupted, or your cable has been broken. Most computers now have a direct plug-in for your memory card, as well as plenty of built-in programs to download your pictures. I like the Vista Photo Gallery (come to think of it, it is the ONLY thing I like about Vista. At any rate, unplug your xD chip from the battery compartment (you can just pull it out, or push it and it pops up), (and close the battery compartment, or you will have to reset the date and time), plug it into your computer, and wait for a bunch of programs to pop up eager to download your photos. If that doesn't work, you may have a bad chip--but if you had a bad chip, you couldn't view your pictures on your camera. If you have XP, you should be able to see the xD as a new drive if you plug it in--not sure which programs will pop up, but you may be able to move the pix just like any files from one drive to another. Good luck. Incidentally, if you need a new cable, internet charges range from 3 to $25.
Posted on Jan 21, 2008
robmcd27
  • 423 Answers
SOURCE: memory card not working? ( fuji finepix Z20fd Digital Camera)
Hi there.
When you start using a memory card, you must format the card in the camera first...using the camera menu. If you don't the camera won't read the card properly. Try that and I bet it will work for you.
Rob
Posted on Mar 09, 2009
  • 109 Answers
SOURCE: flash not popping up or
The S700 does NOT have a manual release for the flash to pop up, but it DOES have a spring already. DO NOT try to force it! Set the flash to "FORCE", leave your lens cap on and waste a shot to allow the flash hood to pop up. Reset your flash to the desired setting and now the flash is already open and ready for use without the delay and the startling effect it has when your concentrating on framing your shot. As for the other problem of no flash in any setting: Check your menus to see if you have the flash totally disabled, check your batteries, does the "charge indicating light" come on at all between shots? In RARE cases, the actual bulb that flashes may be burned out, or a component in the flash circuit itself,such as the capacitor, may have gone bad. Did the flash ever work? If under warranty, return for repair or replacement. There are NO user serviceable parts in these tiny cameras
Posted on Jul 16, 2009
sardanadixit
  • 813 Answers
SOURCE: what does write error mean in my fuji finepix A340
When does this error message come? Does it come while clicking the pictures? Try replacing the memory card of your camera and then check, as usually it is a memory card related problem.
Please rate this solution in case it works for you, it helps us in assisting users like you. In case the problem is still not resolved, do not rate thesolution, leave a comment instead and we shall assist you further.
Posted on Nov 11, 2009
SAFFOTO
  • 77 Answers
SOURCE: Finepix J20 Digital Camera- says:PROTECTED CARD!
My bet is that the little switch on the SD card is in the "lock" position. Switch it off and try again...
Posted on Jan 29, 2010
Testimonial: "Hi I left the comment about the Fine Pix Fuji J20 camera, and I am not sure where the sd switch is on the camera. please if you can let me know.Thanks"
Not opening
your plastic part near flash got puffed due to burn spark, serv. req
Jan 10, 2013 | Fuji FinePix S2000hd Digital Camera
My fuji finepix s5000 has lost power
see this causes and proceed . God bless you
If the camera won't turn on, check the batteries, or connect the camera to an AC adapter. If that doesn't work, remove all batteries, disconnect the AC adapter, wait a minute, reinsert batteries and reconnect the adapter.
If the flash doesn't work, the camera won't take pictures, or the screen keeps turning off, check that the batteries are strong.
Oct 16, 2012 | Fuji FinePix S5000 Digital Camera
Shaking icon always displays on fuji camera
On a Fuji camera, the little "camera icon" looks like it is "shaking" with an "apostrophe" next to is to signify a low light condition and shows up when the flash is turned off. A bad symbol choice in my mind but so be it.
Aug 04, 2012 | Fuji FinePix S2000hd Digital Camera
I have a fuji finepix s1500 and the flash wont turn on or even register ? could it be a connection issue inside the camera?
i have fujifilm s1500 and the flash appear disable on screen , i tray to change it to enable but i cant also there is a yellow camera sign on screen what i can do to make the flash enable
Jan 16, 2011 | Fuji FinePix 3800 Digital Camera
My camera is fuji finepix S9500 and i like it very much, pls some one help me to resolve one problem i'm facing is how to activate flash(built-in) while we photograph images opposite to sunlight?
Don`t own this model Fuji but on my F30 you find the flash symbol (lightning bolt) on rear buttons or internal menu & choose forced flash & then flash fires everytime even in daylight
Aug 12, 2010 | Fuji FinePix S5000 Digital Camera
My flash does not work on my fuji finepix f50fd , i have fully charged my camera and still does not work, i have had camera for about 6 months, and flash was working fine up till now?
Are you sure you don't have the flash suppressed? Somewhere on the menu it should have a flash setting. It can get set to suppress so that it does not flash even in flash conditions.
Aug 11, 2009 | Fuji Finepix F50FD Digital Camera
I have a brand new Finepix S8100fd camera and the majority of the photos are speckled no matter what setting I use. However the super macro setting rocks and pictures are super clear! My Fuji 7.1 mega
Common issue with the A8100fd. The most likely problem you are having is not enough light. Try shooting in bright sunlight to test the "graininess". Make sure you use the flash anytime the light is not bright. Even though the camera will shoot in low light (without flash), because it defaults to a high ISO setting, which (just like film) accentuates the "grain", or more properly termed in digital photography, "noise". Set the camera for a low ISO setting and use the flash whenever you see the "red hand" symbol on the screen.
Apr 22, 2009 | Fuji FinePix S1000FD Digital Camera
Camera and flash gun trigger voltage
Hi Syd,
Vivitar 2800 and 2800D are two different flashes. The first is an old flash, having high trigger voltage, which, as you will see, still can be used with your Fuji. The second is a member of modern flashes, having a low-voltage release. Manufacturers specify the highest applicable voltage at the trigger (hotshoe or PC) terminal; at most digital cameras it reaches several hundred volts.I believe, this is, what your seller was asking. As far as I know, Fuji doesn't mention this value in the user manual of the Finepix 9500, but I met reports of people, who called Fuji and asked that and the answer was 400 volts!
So the short answer is: buy any wireless trigger if you have the 2800D, and tell the seller the flash has about 200 volts if your flash is an older 2800.
I wonder if you did already use your flash with your Fuji?
Laszlo
Nov 27, 2008 | Cameras
Vivitar trigger voltage
Yes, you can. The flash has a low-voltage trigger circuit.
Laszlo
Nov 14, 2008 | Cameras
Finepix Z5 Troubleshoot
The problem is with either the flash unit, or the flash transformer. Unfortunately the only way to fix this, is to take it to a service center.
Bob
Oct 11, 2007 | Fuji FinePix S3500 Digital Camera
Fuji FinePix Z5fd Digital Camera Logo
96 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
