Question about Panasonic TH-50PX77U 50 in. Plasma HDTV
Plugged in XBOX and now have no red color in my picture
  • 1 more comment
  • timothycl804 Jan 02, 2011
    Do HDMI cables just go bad? Would have likely gone bad when I plugged in the XBOX?
    What do you mean locked up?
    I'm curious why there is no color red on my tv. Is it possible a bulb is blown?
  • Panasonic Master
  • 11,800 Answers
There has been a static spark when you plugged the cable from the Xbox and it has fried something. Simple test to locate the origin of the fault: disconnect the Xbox and everything else from the tv, put a simple antenna in the back and turn on the tv in TV mode - if the image is still wrong then the image processor has failed, if the image is good then something is wrong either in the AV switcher on the tv or with the Xbox.
Another simple test for the tv: plug in the tv another device - a dvd player - with the HDMI (new cable) and then using the Composite connection - if the image is bad in both cases then the AV switcher is defective and the mainboard of the tv has been damaged: you will have to replace it. If the image is bad only in the HDMI then the corresponding channel in the AV switcher has failed and from now on you will be able to use only the analogue connections.
Last simple test: plug the Xbox using the standard AV (analog) cable in another tv - if the image is faulty then the Xbox is effectively dead , it can't be fixed. If the image is good then try to use the HDMI using a different cable - if it's ok then the original cable is dead, it happens.
Posted on Jan 02, 2011
    Genius:
  • 1,126 Answers
It sounds like you have a bad HDMI cable.
  • 1 more comment
  • Veril Gillette
    Veril Gillette Jan 02, 2011
    The viedo processor could be locked up too. Unplug both units from the wall for 40MIN. and it should work.
  • Veril Gillette
    You should never plug connectors into anything without shutting of the units first. They might just be locked up.
  • Veril Gillette
    Also the processor might be locked up and if you unplug both units from the wall for 40MIN, it should reset back to normal.
I have the new black xbox. We just changed tvs to a new plasma samsung and when i plug all of the cords in and turn on the xbox it works, except that the colors are bloack and white. It gives a good...
make sure that if you have the hd cords plugged in the switch is on hdtv and if the regular cords are plugged in the switch on the a/v cords says tv. make sure the red cord is in the correct socket. if you are using hdmi cord then it needs replacing. also you may find some sucess by changing the output in the xbox settings.
Jul 31, 2011 | Microsoft Xbox 360 Console
How should I hook up my xbox to the back of the television using the red, white, and yellow wires? It is hooked up but I am not getting any audio. Thank you.
First make sure your video cable is set to TV not HDTV
Then plug the 3 RCA cables into the color coded slots on the TV. Make sure you aren't using the red cable from the component RGB but are using the red cable for sound (next to the white one).
Then, if you still have no picture, start the console using the controllers Xbox button and hold "Y" and "RT" until the console restarts. this will reset the video settings on the 360 to default.
Follow this guide if you get confused:
http://support.xbox.com/en-us/pages/xbox-360/how-to/audio-video-devices/connect-xbox-360-console-tv.aspx
and for the video reset about halfway down the page:
http://support.xbox.com/en-us/Pages/xbox-360/troubleshoot/xbox-360-top-issues/tv-or-monitor-screen-is-blank-while-connected.aspx
Mar 30, 2011 | Video Game Consoles & Games
How do I hook up Wii, regular xbox to led hd samsung television The wires are red, white, yellow. Got the sound and picture for the xbox but still no colour. Is there a way to hook it up without buying...
you may have a bad yelllow rca cable for color make sure its plugged in right. or try plugging them into a different input. make sure all the right colors are matched up and pressed ALL THE WAY IN. if not you will need to upgrade your cables to svideo cable, hdmi, or component cable (the red blue and green cable)
Mar 16, 2011 | Televison & Video
There isn't a picture. I have tried to plug in the wire three separate colored plugs. The problem is I have a port for the white and red wires. I do not have a yellow port. I have tried to plug that...
Hello
White and Red ports are for Left/Right Audio. Yellow is for video. On the TV usually it would be a range of colors from Yellow-Green. Try looking for another port just for the video.
Good luck and please rate my answer.
Dec 17, 2010 | Microsoft Xbox 360 Console
No Picture
Hi And Welcome to Fixyah,
Step 1: Install the Pinnacle Dazzle Video Creator Platinum software and make sure it works with the Dazzle DVC 100. Sometimes this is easy, other times, this is a very difficult task.
Step 2: Buy 3 RCA type Y cables. One male end, 2 female ends.
Step 3: Plug the male ends of the RCA y-connectors to the Dazzle DVC 100.
Step 4: Plug the Yellow, Red and White RCA connectors from the XBox 360 to the color matched female RCA y-connectors on the Dazzle DVC 100.
Step 5: Plug a second triple RCA connector into the other end of the color matched RCA Y Connectors.
Step 6: Plug the other end of the triple RCA connector into the TV.
May 14, 2010 | Pinnacle Dazzle DVD Recorder
If the hd inputs on my tv are red and white and the hd plugs on xbox are red blue and green,what goes where?
match the colored wires from your HD plugs to the ports on your tv then take th red and white audio wires and plug the into the red and white audio ports.
Oct 15, 2009 | Microsoft Xbox 360 Console
Dont know what color to stick where
X-box can be hooked up to component video. This is for better picture quality. Not all tvs have this option. Most newer tvs do. It uses green, red, blue. Those will give you the video. Then a red and a white give you the audio. Just match up the colors.
Apr 08, 2009 | Sony KP-61HS10 61" Rear Projection...
Sound but no pic
check the back of your xbox to make sure all output cords are plugged in then look at your input cords (red, white, and yellow cords) are plugged into the corresponding color on your tv.
Sep 29, 2008 | Microsoft Xbox 360 Console
No picture
What do the plugs on the cable look like? Are they just Yellow, Red, and White... or are there five different colors?
Do you have a high-def television or a regular old one?
Jan 09, 2008 | Microsoft Xbox 360 Console
No color on Sony TV, all other tvs are great
check the av cables in back of your tv and also check the wires connected up to the xbox 60 it's self
Sep 01, 2007 | Microsoft Xbox 360 Console
Panasonic TH-50PX77U 50 in. Plasma HDTV Logo
127 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
