Question about Philips 27PT9007D 27" TV
After the tv is tuned to a new channel, a black square appears over the majority of the screen. The Direct TV tech said that it was a parental control feature that needed to be reset
    President:
  • 2,992 Answers
Actually, your TV's closed-captioning is turned on and it's set to "text" mode. This causes the set to blank out the area where the text would go if there was any. Most remote controls have a single button to turn captioning on, so it's easy to get into this mode without knowing it. Press that button or use the TV menu to go through the caption settings to turn them off, and the box should go away. (Parental controls don't just blank out a part of the screen; they disable the channel completely. I hate it when a technician won't say "I don't know" and then gives out wrong information.)
Posted on Jan 01, 2011
A BLACK SQUARE APPEARS IN THE MIDDLE OF THE SCREEN HOW DO I GET RID OF IT
Hi Tony
You`ve mentioned that ON CERTAIN CHANNELS THE TV WORKS FINE, so your trying to say that not all channels THE BLACK SQUARE APPEARS IN THE MIDDLE O THE SCREEN... my be that black square is generated from the broadcast center. may be your unit is good. let me ask you how many channels that your tv works fine..?
Jan 16, 2014 | Panasonic CT-34WX52 34" TV
Black Box appearing on my screen
go into your menu and access the closed caption modes. someone has accidently put your tv in the "text" mode. turning off the closed caption feature will correct this.
Apr 01, 2009 | Televison & Video
My apex gb43hd10 has a black screen square only on cbs.
it is your captions turn captions off how old is you tv is it analog or digital tuner
Jan 19, 2009 | Televison & Video
unplug the set for a while , but this problem will return because of a malfunction in the EPROM CHIP , this controls the menu and a few other functions
Oct 17, 2008 | Philips Magnavox 27MS343S 27" TV
Black box appears on tv screen
Check to see that you don't have any channel locks or parental parental permission measures deployed. If so remove them, this includes V-Chip, and Parental lock out on the remote, and check your TVs menu items. What channel are being affected by this problem? Give channel number and channel type.
Thank you,
Shuttle83
Aug 17, 2008 | Orion1934 19" TV
Parental lock
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Mar 26, 2008 | RCA TruFlat 27F520T 27" TV
Black out screen
I had the same problem once with my RCA television. It only happened on certain channels and didn't happen during commercial breaks. If I adjusted the volume on the tv the box went away, but came back shortly after. The problem ended up being some malfunction in the closed captioning. I turned it all off and changed the CC settings and never had the problem again.
Oct 05, 2007 | Westinghouse W33001 30 in. HD-Ready LCD...
Black Square Covers 80% of screen on most channels on TV
have your tv checked by a tech.probably your chip the eprom needs to be reset by lifting it up from the board and resolder back.some one could have put in a code for those channel.good luck.
Dec 27, 2006 | Toshiba CF35E50 35" TV
Philips 27PT9007D 27" TV Logo
112 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
