Question about Whirlpool LSR7333 Top Load Washer
I have a whirlpool washer mod # LSR7233E. First it wouldn't put water in. Husband took tube off fill pressure part, water started. Blew through tube, water is still working. Then the water wouldn't drain. Have to mess with dial to get through cycle. The timing seems to be off. any suggestions?
gwshaw71
  • 83 Answers
SOURCE: WHIRLPOOL ULTIMATE CARE II
check your lid switch
Posted on Dec 07, 2007
  • 1294 Answers
SOURCE: Whirlpool Duet Error code F 32
Plug off the wall. Open up behind, you will see a thin tube coming down from the control panel (pressure switch to be precise) to the waste area below. Disconnect this carefully from the top, blow into it, air should pass thru, it shd not be clogged; refit carefully. Before refitting, fit a similar tube to the pressure switch & blow - you should hear a click; if not there shd be a problem with your pressure switch. Anyway refit your old tube & try the machine.
Dont forget to refit the main exit hose at the position you found it. All you guys are going to rate me....................
Posted on Jun 16, 2008
michiganfan9
  • 179 Answers
SOURCE: Whirlpool Washer - Imperial Series Quiet Wash 2
your washers drain hose is too far down the drain pipe which is causing a siphoning action pull the washers drain hose out pipe some you should be able to hear water dropping into the pipe the reason it only happens in the rinse cycle is because the water from wash is being drained and before the water vacuum is broken the rinse water comes in causing it to keep draining
Posted on Dec 30, 2008
rylee_smith
  • 8619 Answers
SOURCE: F20 CODE Whirlpool Duet Sport Washer wfw8300sw00
Hi!
“F20” on display
(Water Inlet Problem—no water or insufficient
water supply) Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power. Check the following: Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked? Are water inlet hoses frozen?
Do rate the solution.
Thanks
Rylee
Posted on Feb 08, 2009
TheMobilian
  • 8220 Answers
SOURCE: OVERFILLS
Drain hose is either too low(must be 30 inches above the floor) or the water level switch is not detecting water pressure. Remove the hose from the switch and blow the sand out of the line. Empty the water and retry.51856c5.jpg
Posted on May 16, 2009
Whirlpool utlra care II clothes washer shuts off when filling - push knob in and pull out it starts again - once full it completes remaings cycles
Hi, the water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Nov 17, 2010 | Whirlpool Washing Machines
The wash cycle puts in too little water and ends up with an oL signal
there is an over fill switch in the washer,,there is a pipe leading up to it when water go.s into the tub the water presher fills the tube up and when the presher is right it turns off the flow,,, if it "times out" becouse it took to long to fill up it shuts off the water flow if this tube is blocked up with gunk??? it wont work very well,,,if its gone fulty it also stops the flow of water ,,,hope this help you out?
Jun 29, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing machine won't stop filling up
PRESSURE SWITCH
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tub. As the water level increases the air in the tube is compressed until there is enough pressure to make the switch stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
Water inlet valve
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Apr 26, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Error Code F8E1 on Whirlpool Duet
f8 is shown when the heater circuit is on with no water in.. it doesnt do it when you unplug the pressure switch because your disabling the heat protect circuit
THE BOARD IS PROBABLY FAULTY
F08 indicates pressure switch stuck on full.
Unplug the appliance from the wall socket.
Take the top off the machine.
Locate the pressure switch, you can identify it by the thin tube attached to it.
Take the tube off, blow down this tube as hard as you can to shift any blockage or restriction in the pressure chamber. Give the pressure switch a couple of good taps with the screwdriver handle.
Refit the tube and try the machine again.
If still doing it, unplug again and follow the tube down.
This end will be attached to the pressure chamber.
Take this chamber off and thoroughly clean it out, clean out the port into the tub too.
Reassemble and try again.
If after this it's still faulty you'll need to start replacing parts.
I'd suggest trying a new pressure switch first.
Failing this, if all of the above fails to resolve the problem you're possibly looking at a faulty main control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Ken more wot stop filling but think i got it want to make sure
A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Mar 08, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
LST8244BQ0 Should I just get a new washer? Overflows with water, keeps on filling. Stops filling when you switch to rinse cycle from wash cycle though. Drains well. I may have overloaded when I was washing...
Simple fix. But you might need a tech. Sounds like your water level switch needs fixed or replaced. Most work on air pressure. (Huh? your saying? :) A tube (you can't see) runs down the verticle length of the tub. As the tub fills with water the air in the tube increases the air pressure within it. There is an air pressure switch on top of the tube and the "Washer Load Size" switch adjusts so that when the air pressure is correct (water level in the tub) meets the requirements of what you set it to, then it turns off the water inlet valve and starts the washing cycle.
If this "water level tube" gets disconected, it will not work. Also if it gets cracked (it is plastic) or gets plugged somehow, or if the switch fails, you wil have water, water everywhere.
Here is the manual online -
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=LST8244BQ0&siteCd=WHRCOM
Whirlpool's Toll Free number is number is: 866-698-2538
and thier customer service Web site is: http://www.whirlpool.com/custserv/index.jsp
Hope this helps - If so - Check "Fixya" below!
Len
Jul 26, 2009 | Whirlpool Washing Machines
Water will not shut off to begin cycle
Does the washer leak water into the tub even when it is not on. If so, your fill valve is leaking or sticking.
I would also check the following components for problems:
-Air pressure switch. This is usually located inside the control area and likely is attached to the water level control. Try attaching a small piece of tubing to the pressure switch and gently blow into it. If it turns off, the problem likely lies elsewhere.
-Air tube. This clear tube can get crimped or worn from the vibration of the washer's normal operation. Any holes, cracks or crimps will prevent the air pressure created by the water in the tub from getting to the pressure switch.
-Soap residue in the air dome. The airdome is the piece attached to the side of the washtub that allows water in the tub to exert air pressure into the tube and the pressure switch. Soap residue can create an obstruction that prevents the pressure from being transmitted up the tube. Try cleaning with vinegar or ammonia. (Remember: Clean the tub and tubing thoroughly with water after cleaning. Ammonia and Vinegar are both corrosive to electrical parts.)
Hope this helps!
May 28, 2009 | Kenmore 23822 Top Load Washer
Washer won't aggitate or spin.
your water pressure tube is clogged at the tub. Take the back of the control panel off and blow or a small balst of compressed air down this tube and try the washer again. Powder detergent clogs this tube at the bottom of the tub and does not tell your pressure switch to shut the water off at the proper level thus overflowing your tub.
Feb 01, 2009 | Whirlpool LSR5132PQ Top Load Washer
GE Washer-Doesn't Fill When it Supposed to.
It is most likely a pressure switch. This is the water level switch. As water fills the tub, air pressure builds up in the rubber hose going to the switch. When the pressure is high enough for the water level setting, it trips the switch and puts the unit in wash cycle. Remove the control and start the machine. While it is agitating, remove the hose from the switch and see if the washer starts filling. If so, blow through the hose and see if something has clogged it. If you have a volt/ohm meter you can check across the terminals while you blow into the switch to see if it is working. Let me know what you find out.
Oct 18, 2007 | GE WDSR2080D Top Load Washer
Won't fill with water
First eliminate the pressure switch. Remove the two screws in back of the consol and flip it up. On the left you will see the pressure switch with a 1/4 inch rubber tubing going to it. Pull the tubing off the switch and see if the washer starts filling. Blow through the hose to see if it is clear. Don't leave the hose off because the washer will over fill. Catriver..post back.
Dec 02, 2006 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool LSR7333 Top Load Washer Logo
55 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
