Question about Tecumseh 5hp Engine Snow King Mtd Blowers Lh195sp67517
Model 31A-3AAD700 engine won't start. Engine dosn't seem to get gas even though I pump the chock several times. ****
My TB575EC weed eater will not start. It seems oil is some how getting into the air filter
The rings on the piston are passing too much oil/gas mixture due to the lost compression. Or, you have incorrectly mixed the oil and gas, if it uses a mixed fuel.
Sep 02, 2016 | Troy-Bilt 29cc 4-Cycle Straight-Shaft Gas...
Outboard troubleshooting. I have a 75 hp Mercury with 2 carbuerators. Serial # 6559142 it's around a 1989 model.. Problem= tank bubble pumps up tight...sits for a minute and gets soft...when I pump it up...
Sounds like the fuel pump isn't working, you can buy service kits though quite often corrosion will prevent you from removing the valves.. or it could simply be the fuel cap isn't venting, remove fuel cap and see if the engine continues to run!
Mar 18, 2017 | Boating
Engine won't start, doesn't seen to be getting gas.
Potential 'air lock' - try running with out fuel tank cap on
Cap should have a fine breather hole in it
May 03, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
2002 Pontiac Firebird acts like it ran out of gas and now won't even start. Could it be fuel pump or something else. Service engine soon light also comes on occasionally due to emmisions sensor fr
with the key on engine off listen to fuel pump,if you can not hear the pump winning ,the pump is bad
if you can hear it,it might be working but create enough pressure
you can rent a fuel pressure gauge from auto store and check the fuel pressure
Apr 19, 2013 | 2002 Pontiac Firebird
2000 GMC Sonoma will not start after standing serveral hours
Check the fuel pressure at the shredder valve, you should have 62 to 65 PSI when the fuel system is primed. (engine not running) With the engine started and running the pressure should drop by 5 PSI, anything less then 62 PSI in your fuel system when trying to start the engine will cause a no start. Note; that try to start a the engine by pouring gas through the throttle body may cause an internal fire in the intake ports and will cause the fuel injectors to melt creating a more expensive problem. As for the fuel pump in the gas tank, it''s held on by and snap ring which you can remove with a simple screw driver. Good luck and keep me posted, and don't for get to replace the wire harness from the frame to the gas tank. It's a $12.00 investment that's worth more then it's cost.
Nov 15, 2009 | 2000 GMC Sonoma Extended Cab
How can i tell if my ignition is going bad i can crank it over but as soon as i start to drive it shuts it self off
First, make sure all your ignition components test out good; ignition coil, spark plugs, plug wires, power transformer, and even your alternator and battery.
Next, check your fuel system; fuel pump, fuel filter, fuel pressure regulator, and even your fuel injectors. Many times a clogged fuel filter can cause idling and hesitation problems. Also check for any restricted air passages starting from your air filter, all the way to your throttle body and EGR valve.ry checking the tps sensor (throtle positioning sensor). if the tps sensor is not working right when the engine warms up the tps sensor will not allow the fuel pump to pump as much as it needs to keep the engine running. The reason it only happens when the engine warms up is because the throttle is chocked when the engine is cold so it does not take as much gas to run it.
Aug 21, 2009 | 1985 Ford Ranger
Unable to start gas engine on a NorthStar pressure washer
Disassemble and clean the carb. If it ran briefly with the starer fluid then gasoline is not coming through the carb.
Dec 30, 2008 | Northstar Garden
F250 superduty a/c problem
Sounds like a vacuum problem, you didnt specify gas or diesel, on gas engines the hvac doors work off of engine vacuum, on diesels they have a seperate vacuum pump on the passenger side fenderwell, another place damage to the vacuum line can occur is under the glove box near the passenger kick panel, it could also be a control head problem. -Jared
Nov 14, 2008 | 2007 Ford F-250 Super Duty Lariat
Van dosn"t have pick up and go ?
hi you need to get the codes read it will tell you where to look its expensive if you start guessing yates210456
Oct 13, 2008 | 2003 Ford Windstar
Tecumseh 5hp  Engine Snow King Mtd Blowers Lh195sp67517 Logo
82 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
lnbn1975
itsman
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
