Question about Dishwashers
My dishwasher leaves black specks all over the glasses inside and out. They are better if left on the bottom rack but this wastes a lot of space. Dishes placed on the top rack will come out fine if the opening is big like a bowl but glasses placed on top rack will be dirty. I could put them in the dishwasher clean and they will come out with these black specks. Dried on at end of cycle and extremely difficult to get off. Have to soak glasses. Also I took the bottom "washer blade" off it turns off easily by hand. Underneath this there are two white parts look like big washers. One is split in half. Is this suppose to be like this?
    New Friend:
  • 32 Answers
After you load up your dishwasher check that the top arm spins freely. Something might be stopping it. eg Big plates like I have. I can only put them on the sides.
As for the white parts , hard to tell without a picture.
Posted on Apr 07, 2017
  • Louise McElheron
    Louise McElheron Sep 18, 2017
    I had the same thing and found out that the jet holes on the arm were clogged. Everyday, I had to check those jet holes if I wanted to have clean dishes. And I rinsed the dishes before loading them in the dishwasher. Paid $1400 for a GE Profile. Next one was a Bosch at half the price and 100% better.
  • 161 Answers
SOURCE: upper rack dishes dirty
Is it filling with enough water. Look or if you don't know how much water is supposed to be there , Just add a gallon of hot water to the machine after it fills. If this solves the problem check the filter in the fill valve or replace the valve.
Posted on Jul 05, 2008
  • 338 Answers
SOURCE: kitchen aid dishwasher doesn't clean dishes in the top rack
Sounds like you have 1 of 2 problems. Either your pump is clogged or you need a bigger drain loop.
Posted on Nov 25, 2008
  • 291 Answers
replace the top spray arm and it should work ok again
Posted on Nov 27, 2008
  • 1214 Answers
SOURCE: Dishes not clean. Lower spray arm possibly not moving.
Remove the lower basket so you can access the lower arm.
Does it spin freely? If not, remove and clean the rotating point. Make sure the spray nozzles are not clogged and there as no chunks of stuff inside the spray arm.
Posted on Jan 24, 2009
  • 31 Answers
SOURCE: Maytag dishwasher quiet series 400. Dishes have hard stuck on grit and food particles after rinsed and dried.
Very common problem is soap build up in these machines. Try putting it into a wash cycle with no dishes, and no soap. Let it wash for about 5 minutes, and then open the door. If you see alot of soap suds, then soap build up is the problem. Try doing a couple loads with no soap, and no dishes, and throw a cup of vinegar into the machine halfway through the wash. Repeat as necessary. This should solve your problem.
Posted on Mar 14, 2009
Kenmore dishwasher ultrawash debris on glasses
Fill the soap cup with vinagar and run it while its empty.
Mar 09, 2012 | Kenmore Dishwashers
How to Stop the dishwasher from breaking my glasses
This shelving costs $16 plus $20 for powder coating.
Very easy to assemble taking about 2 hours.
It will stabilize your dishwasher trays so glasses wont fall over. Therefore wont break.
Buy 2 large Baking racks with 1 cm holes from Myers for $8 each.
Use your Angle Grinder to cut to size, making sure the cross wires running from left to right are on top of the long runs. This is because your glasses would slip all the way to the front, if you mounted the racks up the wrong way.
Basically I cut off only one side of the rack, using the cutoff piece for the middle hole.
Next flatten those legs that wont let the rack sit flat down, by using your vice and hammer.
See the diagram below how wide the framing supports wires are apart, that is why nothing stands up on them.
You may have to discard other supplied movable racking.
But the inserted racks, with a hole cut in the middle rack to allow a raised support wire some space, are very stable.
Now after cutting hammering and bending the racks loose some coating and will rust with little rust marks appearing on the edges of all your crockery and cups.
Therefore you will need to powder coat them any colour for years of protection.
Just find a powder coater in the yellow pages and give him the cutout racks.
To save money I told him to coat my Black racks to any colour in his machine, which turned out white.
Note the glass which now stands up stable and straight.
on Feb 06, 2015 | Dishwashers
Hello, Recently my dishwasher has been leaving particles of food residue in glasses or other glass items. This is a particular problem when using the top rack, but the problem sometimes is also on the...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
Jul 05, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Frigidaire Dishwasher FDB2810LDC1 not draining
Sure its redeemable if you have the time and money. If I understand you correctly when you move the lowewr spray arm the water drains out? If this is the case then more than likely its a pump motor or solenoid. Reason I say this is on the bottom of the spray arm is a impeller and under that is filter and then pump impeller that drains the water. If its not draining but will by hand then its your pump motor or solenoid. When you start the washer then press cancel/drain do you hear anything? Maybe a humming sound. One more thing could be a thermal fuse for the motor. These are usually not resetable its a one time fuse if it blows you have o buy another one.Hope this helps
Jan 25, 2010 | Frigidaire 24 in. PLD2850 Built-in...
My dishwasher is leaving a lot of residue on dishes
I had the same problem and fixed it by disassembling the lower spray arm and return filter, and cleaning all the junk out.
Most dishwashers have 'risers' that bring the water up to the top sprayer or arm located under the top rack. If the recirculating pump is plugged even a little there won't be enough volume or pressure to get the water up there.
Test this by putting a dry muffin pan in the top rack, flat, and running the dishwasher for a bit. If there is no water on the top (or the bottom) either the top sprayer or the sprayer arm underneath the top rack is not getting enough volume.
To fix this you need to clean out the screen and filter, where the water returns to be recirculated. If you don't have any confidence to remove the parts and clean it out yourself, get an appliance repair person to do the job.
Aug 26, 2009 | Dishwashers
Mildew and long dishwasher cycle
Get some household bleach and run a short wash.
Aug 22, 2017 | Kenmore 24 in. 16533 Stainless Steel...
Dishwasher rack rotting
Depends on the age.
Eventually dishwasher racks deteriorate.
It is rusting from the inside out.
Replace the rack.
Mar 12, 2009 | Whirlpool 24 in. DP840D Free-standing...
Food left on dishes
Scrape your dishes of food.  Dishwashers remove whatever is left.
Nov 26, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Black specks
is that a glass? can't tell. is there water curculating to the top rack? if not you probably have a bad chopper
Sep 16, 2008 | Kenmore 15899 Built-in Dishwasher
Dishwashers Logo
611 people viewed this question
Top Dishwashers Experts
