Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Kodak 5300 printer won't work with Linux, any back door fixes?
Get a HP Printer.
Posted on Apr 26, 2009
MI IMPRESORA SOLO IMPRIME A COLOR PERO SI TIENE TINTA NEGRA
Posted on Jul 09, 2008
On the Kodak ESP 5200 series what does a 3501 error mean? can it be fixed by a user? will new cartridges fix the problem?
Hi!
The 3501 error code means "acces door open"
Please be sure that the printer's acces door is well closed.
If this doesn't fix the problem, please do the following:
1. Turn the printer off by pressing the on/off button
2. Unplug the power cord
3. wait for 1 minute
4. plug the power cord back in
5. turn the printer on
Hope it helped.
Regards,
Bogdan
Aug 20, 2011 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak Easy Share 5300 Printer error Error code 6203
Error code "6203" can be resolved as follows:
First, you need to open the access door of the printer and disconnect the power adapter from it.
You then need to wait for at least 30 seconds for the printer to get reset.
As a next step, you can connect the power adapter back to the printer.
You can turn on the printer, if required. Once the printer gets powered up, a message "Printer access door open" gets displayed.
Once this message gets popped up you can close the access door of the printer. get more help for Printer Error Code 6203
Hope this helps you.
Sep 10, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kadak Easy Share 5300 printer. Screen reads "Paper Jam Clear Jam
Try this one Take out the inks and printhead Leave the cartridge door open, then unplug the power cord from the back of the printer while the access door is open Close the cartridge door once the cord is unplugged Reconnect the powercord, turn on the printer, then your printer will look for your printhead "Printhead missing or not installed correctly..." Then put everything back. make sure it will snap in to place. Then print a calibration page, then scan it. This is just over writing the error message. Thanks Josh - Kodak Tech Support
Aug 12, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
I have the Kodak 5300 All in one easy share printer. Less than a yr old. Also a Del computer with Vista Operating system, Less than a yr old. About a week ago decided to take the time to learn the kodak...
try using the system restore option on Dell computer.........as you have vista,,,click on the start button and type system restore in start search box and follow the on screen instructions and select yesterday's date and proceed.......should help:)
Apr 16, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak EasyShare 5300 won,t print Color
Replace Printer Head. It was stoped up. Cleaning didn't do any good.
Jan 18, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak 5300 printer 4x6 printer tray
it could be a problem with printer and least with the print head.......i would advice to contact Kodak tech support...........
Aug 25, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak EasyShare 5300 Printer error message
Ten Step Process to Fix the "Print Head" Error Message on the Kodak 5300 Printer.
1. Clear a good spot it your back yard that is free of shrups and flowers.
2. Get the following tools: Flat head screwdriver, shovel, sledgehammer.
3. Dig 24" x 24" hole in your back yard and rope off the excavation area for safety.
4. Whaaaaack the heck out of the Kodak 5300 with the sledgehammmer until such time that it is not a recognizeable piece of electronic equipment.
5. Stab it with the flat head screwdriver, just in case it has the Terminator syndrome (comes back to life).
6. Throw the piece of garbage in the recently excavated hole in your back yard.
7. Cover up that useless piece of garbage and forget you ever owned it.
8. Get in your car and go to the nearest electronic store and ask to speak to the manager.
9. Ask if they sell the Kodak 5300 printer. If so, whack him with the shovel. You don't want to seriously injure him so don't even consider the sledgehammer of the screwdriver. After all, its not his fault that his company carries such garbarge. But the whack is just to burn off some steam from your frustrations.
10. Purchase any other printer but a Kodak and live happily ever after.
Jun 14, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Paper jam
Paper jam out of the box is a doozy. Open the printer access door. If the printhead centers, remove the ink and the printhead. With the printhead out, unplug the printer and plug it back in. Replace the printhead once the printer is up and running. Close the access panel and the issue should be fixed. If the printhead does not center, unplug the printer with the access panel up, plug the printer in and turn it on (all with the access panel up). The printhead should center.
Apr 16, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
My kodak 5300 will not accept the new ink cartridges
The version of firmware you originally had on the printer when you changed the ink cartridge was bad. There is a known issue that when you put in a new ink cartridge when the printer is in the error state "COLOR INK EMPTY. REPLACE COLOR INK CARTRIDGE" the unit writes that value to the new ink cartridge so you will continue to have that error.
So to fix your problem Open the access door and Remove the ink cartridges. Then download and install the new Firmware. Heres the link.
Kodak AiO 5300 Firmware
Then sadly you have to go get another new ink tank and install it.
If you can get through to kodak you should request reimbursement of some sort like a free set of ink tanks.
Mar 09, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printer won t turn on
Try pushing the on/off button after the lights go off and it should turn on. If not, you have a hardware problem and have to call Kodak tech support.
Feb 27, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
409 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
