Question about Linksys EtherFast Cable/DSL Router
I want to add a newly purchased computer on to our Linksys router to connect to the Internet via Comcast. My computer says the cable isn't connected even though all the lights show up on the Linsys. HELP!
  • 600 Answers
You have 2 options to connect to the router on the computer.. either wired or wireless-- if you are connecting wirelessly then just ignore "cable isnt connected" --you can change the icons so it doesnt show in CONTROL PANEL>NETWORK CONNECTIONS
If your trying to get on the internet with a wireless connection.and running WINDOWS,(many problems with LINUX) .and have a wireless router all set up and configured to broadcast the signal (not hidden) ....
try resetting the router (disconnect the power to it for a few minutes) next --be sure the wifi switch is enabled on the netbook---TRY IT NOW--if still problems---go to CONTROL PANEL>NETWORK CONNECTIONS--right click oin your wifi card and choose properties--highlight INTERNET PROTOCOL and choose properties and be sure "OPTAIN IP ADDRESS AUTOMATICALLY" is checked--Does the laptop "SEE" the router?
You will need your SSID to logon to the router(internet)
follow this is a link to a troubleshooting flow-chart-Do check it out
http://www.daileyint.com/hmdpc/laptop/wireless.gif
If you continue to have problem..indicate at what point in the flowchart it is getting stuck
If this was helpful, please indicate so, if not -comment back so we can dig further to resolve this
Posted on Jan 01, 2011
How can I set one router to connect with another
Easy way: Run a long ethernet cable from where the Comcast router is to the place you'd like to have the Linksys. Tell the Linksys not to act as a router or try to connect itself to the internet -- in this set-up, it's just acting as an access point. It probably needs to know the IP address of the router so it can send packets out to the Internet -- that information is called "Gateway" on my router. Feel free to add more detail to the question if that doesn't help!
Feb 18, 2014 | Computers & Internet
I HAVE A NEW HP DESKTOP AND AN OLD LINKSSY WIRELESS G
Hi Vivian,
Chweck you cables and where they are conencted.
You will need to make sure that the Comcast modem is providing internet, you can do this by connecting your laptop to it using ethernet directly if it connects to the internet, that will be a good thing.
From your comcast Modem, the ethernet Cable should go to the linksys where it says "WAN". this should give you an internet connection and make your comcast modem communicate with your linksys Router.
Jul 22, 2010 | Linksys Wireless-G Broadband Router
WIFI not working with Linksys wireless-g broadband router/Comcast
Unplugging the wireless router and connecting it again should not have altered the wireless connection/configuration. You have connected the cables correctly because the Internet works when you connect a LAN cable to the router.
The Linksys wireless configuration or the wireless card configuration in the computer was changed it to lose the wireless connection. The wireless card configuration needs to be changed to match the wireless router's settings or change the Linksys with new configuration settings and configure the wireless card accordingly.
To secure your router with a login password and wireless security, please follow my instructions - click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Should you need further assistance, please leave me a comment.
Dec 25, 2009 | Linksys Wireless-G Broadband Router
Internet connection problems
Sorry but that seems to be a pretty convoluted explanation. Here is how it should go.
Vonage unit connected to phone line(s) and cable modem. Linksys connected to Vonage box. Computers connected to Linksys.
Ethernet has a length limitation of about 300 feet before you need another switch (hub) or a repeater. Does your wire length exceed this?
Apr 20, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Linksys wrt160N router inconsistant internet connection
Check on your cables makes sure they are inserted properly and the cord should be free of kinks, scrapes or loose connections......Also check the back of your computer make sure your ethernet card (the one that has the green lights/LED's) is seated properly (not loose)....
Good Luck.....hope this helps...if not let us know....cheers
Apr 13, 2009 | Linksys WRT160N Wireless Router
Connection
Hi Susie
With related to your particular issue it seems like that your broadband modem is not configured for the router. There are basically 2 types of connection. DSL and Cable modem. Verizon, ATT are DSL and comcast other providers give you a normal cable broadband connection. If its comcast make sure the cable from the comcast modem is going to the internet port in the linksys router and also make sure that there is a system connection the linksys router and the cable from the system goes to any of LAN 1, 2, 3 and 4 ports. Then reset your cable modem by using a pin and inserting to the reset hole in the modem. You could use the same step to reset your linksys router as well .If its a verizon or dsl connection you need to put normally your username and password in the router page. here is the link to how to configure linksys for your internet modem.
Here is a video as well on it?
http://in.youtube.com/watch?v=vSAXMO7aNzg
http://tinyurl.com/5tqqhl
Also post the linksys router model. your ISP modem model number and also information on how many systems are wired to the router and wireless and let me know if you need more help.
Thank you
Rakesh
Dell Laptop Expert
Jan 09, 2009 | Linksys Wireless-G Broadband Router
Linksys Wireless-G WRT54G Ver6
Try reconfiguring the Linksys router. Click on this link for instructions on how to configure the router with a cable Internet connection.
http://www3.nohold.net/noHoldCust56/Prod_6/KnowledgePortal/KPScripts/amsviewer.asp?docid=4da24a60bfc84fe9ad65ce672b4b8b52_KB3686_EN_070208_v1.xml&amsstatsid=4067617
After configuring the router and if you already have an Internet connection, then connect your second computer to any numbered port of the router (port 1,2,3, or 4) and test the Internet connection.
Configure the wireless settings of the router by following the steps on this link.
http://www3.nohold.net/noHoldCust56/Prod_6/KnowledgePortal/KPScripts/amsviewer.asp?docid=2f99c35863934424a932742692a5e83b_KB4024_EN_070329_v1.xml&amsstatsid=4067626
If you want to have a wireless security for your network, you may clck on this link for instructions.
Then try connecting your wireless computer to the name of your wireless network and enter the security key (if you have created one).
Sep 08, 2008 | Linksys Wireless-G WRT54G Router
Connecting to internet
Ok, cable (coax) comes in from wall and attaches to modem. Ethernet cable goes from modem to WAN Port of router. You may have to reboot both devices to ensure that your modem (internet service provider) assigns IP address to your router. If PC is close enough, attach new ethernet cable from one of the 4 ports on your router down to your PC's ethernet adapter. (where your modem used to plug into). Router will now assign an IP address to your PC and you should be able to access the www.
Good Luck and let me know if you have any more questions.
Jul 13, 2008 | Linksys Wireless-G Broadband Router
Wireless router needing ethernet connection?
Hi ABVT66 - Didn't your router come with two short cables? It should have. One is the cable that hooks up the modem to your router and the other is the cat5 (ethernet) cable that connects your router to your pc. Let me know if you have these cables. Also, if you check your device manager on your pc, click on the + next to network adapters and it will tell you your network adapter. DON'T RATE THIS 'TIL WE'RE DONE. Thanks.
Jeff
May 22, 2008 | Computers & Internet
Linksys 5-port Workgroup Hub
Hi Tman,
Here is a link to the Xbox ports. http://support.microsoft.com/kb/908874
In the firewall option, direct those ports to the IP of your Xbox. I don't have an xbox, but I would think there is someway to set a static IP on it. That way DHCP won't change your xbox ip when you reboot it. Some routers allow you to assign a specific IP to the xbox, but not sure about yours.
Visit this site, http://portforward.com/routers.htm It may have your router, and will tell you how to setup the ports for your xbox step by step.
Jan 06, 2008 | Linksys EtherFast Cable/DSL Router
Linksys EtherFast Cable/DSL Router Logo
47 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
