Question about Tech Solution TS-900 Calculator
Looking for a Tech Solution TS-900 or TS-950 calculator
Hi:
I am looking to purchase a Tech Solution TS-900 or TS-950 calculator and have not been successful in my search. PLease help or direct me in the right direction.
Thanks,
Yliana
305-640-2039
  • Anonymous Aug 15, 2008
    I too am looking for a TS-900
    Randy
    (636) 537-5229
Need instructions for the MU, CST, SEL, MAR keys and what the arrow key is for above the MU key.
Just Google search (brand/model) user manual for instructions, as you don't indicate which calculator you have!
May 09, 2016 | Office Equipment & Supplies
Imei code calculator
Hi are you looking for network unlock code ..Then instead of using calculator you can directly purchase code from sites like Mobileunlocksolutions.com here they render unlock code for all mobile models at reliable cost ....You first verify that whether they are rendering code for your mobile mode ,country and network provider ..If yes then pay for it and unlock your phone ...
Oct 30, 2013 | Cell Phones
Building a box, need to know best dimensions for box and port
Hello dirt_digger6,
The specific sub you are asking about would seem to be the TS-302F which is the only 12" 800W Pioneer I have located.
Directly from Pioneer's support knowledgebase:
TS-W302F = Ported: 2.5 Cu.Ft. F3 = 39HzPort: 4  x 6.5 tuned @ 37 Hz with 12 % port noise.
An enclosure 16X18X21, constructed from 3/4" MDF will yield 2.69 Cu.Ft., allowing .19 Cu.Ft. displacement for the sub and port.
There's an excellent "box calculator" located here on the12v.com web site. You can measure the space you have to put the box and fiddle with the dimensions to get close to your ideal volume. There are also calculators on the12v.com which will allow you to calculate a port length based on port diameter (or width/height), enclosure volume, and desired tuning frequency.
Hope this helps.
May 07, 2009 | Car Audio & Video
Tech Solutions model #TS 5000 Cross-Cut Paper Shredder
my power cord seems to have overheated and the prongs won't stay out when plugged in. How do I purchase a new cord and how much does it cost?
Apr 20, 2008 | Tech Solution Office Equipment & Supplies
Potential Purchase
If you want to do that do not buy an 83 or 83+. all the 84's and all the 89's come with usb chords so you can hook them up to the computer, now how you do that i don't know cause i use an 83. You would have to do more research. I hope this can help. GOOD LUCK
Feb 01, 2008 | Texas Instruments TI-84 Plus Silver...
On/off button doesnt turn on
normally if you spill any type of liquid that would certainly affect your calculator from working- i would say that you need to have it replaced
Aug 31, 2007 | Tech Solution TS-900 Calculator
Tech Solution TS-900 Calculator Logo
495 people viewed this question
Top Tech Solution Office Equipment & Supplies Experts
Michael Galve
Michael Galve
Jim Keysor
Are you a Tech Solution Office Equipment and Supply Expert? Answer questions, earn points and help others
