posted by mrcaster on Jul 08, 2008
Deck is up, no fuses blown, battery up to par, parking brake on,
1 Other User Has The Same Problem
Comment by Guest, posted on Aug 06, 2008
Similar problem - instaolled new battery and checked for proper charge. Sitting on the mower while depressing the brake pedal. PTO is disengaged. Engine "clicks" like it is a dead or low battery and engine will not turn over.
Solution #1
posted on Jul 27, 2008
If you are talking about a riding mower, then try turning the blades off before starting mower. I had my blade switch in the on position once and could no figure out why the tractor wouldn't start until I pushed the mower into the garage.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Tools and Hardware
Email this problem
Email this problem
This Problem Also Relates To:
Black & Decker 5700 Powershot Forward Action Stapler
Black & Decker Compact Power Screwdriver
Black & Decker 9072CTN Cordless Screwdriver
Black & Decker AAW100 Auto Wrench 8" Automatic Adjustable Wrench
Black & Decker DW682K Dewalt Plate Joiner
Bosch 6" 60-120-240 Grit Sanding Discs for Wood (6 Pack) SR6R000
Troy Bilt 17 Inch 29 Cc Gas Powered Clutched Curve Shaft Trimmer #41ADT52C966
Can you Help with these Tools and Hardware problems?
Black & Decker 19" Electric Lawnhog Mulching...
BLACK & DECKER GL685...
black & decker gl685... Answer This...
Coleman Powermate Premium Plus 6250W Portable...
Oil for Coleman Powermate 5000...
TS Fay just made our lights... Answer This...
Chamberlain Powerdrive PD422D 1/2 HP Security...
adj stop on opening model 940d
how do i readj the stop point... Answer This...
Multi-Function Door Control
The outside keypad works, but... Answer This...
Repair Service
Find Tool and Hardware Repairman Near You:
