Question about Water Heaters
Seems as though there is a whole in the tank causing wter to spew out, The whole is yhe top of the tank and appears to be very small, can this be patched or soldered?
  • 2 more comments
  • lyle maes
    lyle maes Jan 02, 2011
    Is it close to any pipes that come out of the top of heater
  • dkinney541 Jan 02, 2011
    approx 5" from top valve
  • dkinney541 Jan 07, 2011
    Thanks for your comments, I have had the tank replaced. Repair was not a viable option, according to the two local plumbers who came out to look and one I talked to via phone.
  • dkinney541 Jan 09, 2011
    Geno_3245,
    As you have indicated, the pro's have determined the same as your comments, I have replaced the tank.
    Problem Solver:
  • 15 Answers
It may be possible.Remove outside cover and inspect tank. some r metal and most r plastic and can be repaired. ck water line seals frist.
Posted on Jan 02, 2011
  • lyle maes
    this is only on tankless waterheaters an not tank. read heatmans soulution
  • Anonymous Jan 02, 2011
    that is only if u hav a tankless unit. ck heatmans for other solutions
If water heater has a hole, then water heater is rusted out and must be replaced.
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html
Immediate problem is ruptured tank.
Water heaters are under pressure, and rusted water heaters rupture and water runs until water is shut off.
This causes major damage inside home.
Protect yourself first, and then let's talk more.
1) Turn off water at shut off located on cold water line above tank.
2) Turn off power to water heater:
Gas heater, rotate valve to 'pilot' so pilot is lit but burner does not turn ON.
Electric heater, turn off circuit breaker.
3) Open tub spout on hot side and let run a bit to relieve pressure.
4) Now your property is safe.
You can limp along with failed heater if leak is slow.
Turn heater ON when you need hot water.
Typical Gas heater makes 41 gallons hot water per hour.
Typical Electric heater makes 21 gallons hot water.
Shower uses 5-9 gallons hot water, bath uses 12-14 gallons hot water.
If you are going to install heater yourself:
Look at label on side of old tank to identify size and particulars.
I buy ordinary heaters from Lowes and Home Depot and always look at scratch-n-dent models.
Buy same size heater if it worked fine before.
Buy new flexible water connectors.
Set water heater in drip pan.
Offer 10% less than price shown.
#1 rule) tankless heaters are a rich-man's toy, because tankless will never pay you back, and will become major money pit with 1 repair.
2) How to install gas heater:
http://waterheatertimer.org/How-to-replace-gas-water-heater.html
3) How to install electric heater:
Read link above because many of same steps apply to electric.
The difference with electric, is turn off power, disconnect wires, and reconnect wires exactly like before. Set electric heater directly on insulated surface like dense blue styrafoam. Cut styrafoam in a circle so it fits inside dip pan.
Also read:
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Add a comment for more free assistance.
Also take advantage of fixya phone service.
For a price, fixya expert speaks to you via phone about any do-it-yourself problem.
  • 1 more comment
    Thanks Gino,
    I guess I forgot some info - my hot water tank is an Armitrol WH-7P boilermate which is linked to my boiler or furnace. I am thinking all of the info and comments you provided for the electric and or gas hot water heaters may still apply, but thought the additional info might promote a different answer, thanks for your time.
    I have protected the unit by turning off the cold water intake which appears to pressurize the tank, i have also prevented the flow from the unit so the heating coil did not burn out. I think the unit somehow goes back through the boiler and have not turned it off, but have shut down the boiler because i an not sure how the system works, glad iys not too cold today!
  • Anonymous Jan 08, 2011
    I am not an indirect water heater expert. When heater is connected boiler, then it is called indirect water heater. There are similarities, and differences, between indirect and 'regular' water heaters. One similarity is that your heater has a hole. Your tank is rusted-out and it can rupture. I have a friend who welded his rusted water heater and got more life out of the tank., but he assumes the risk. As general rule, a rusted tank needs replacement to prevent rupture and water damage. I am going to suggest you get follow-up opinion from the professional plumbers at the Tank. Ask them if there is a way to limp along with indirect heater until you get it replaced. If I miss your post on the Tank, let me know what they say:http://www.thetankatwaterheaterrescue.co...
What would be the cause/s if the water heater was to overheat?
THERMOSTAT, inside or underneath the temperature control.
If the heater does overheat, the temperature/ pressure valve on the side of the heater will leak or spew water. This is so that the water heater does not explode. It is far more common for the valve itself to go bad.than the thermostat. The temperature/ pressure valve is a common replacement part. The thermostat is not available as a replacement part on most tanks.
Mar 29, 2016 | Water Water Heaters
Heater broke, my Amtrol water heater expansion 80 gal tank, takes hot water from the oil fired furnace, and keeps it hot, However, the tank is set at 140 degrees, but the water coming out if the hot wter...
Hiliary
sounds like the primary coil in side is cracked and is mixing hot water.. with the cold water in tank need to check and replace as necessary
Sep 15, 2013 | Amtrol Water Heaters
What should I do about a small leak on the side of my water heater?
What is the warranty on this tank?
Warranties covered failed tank.
Does the tank wall have a leak?
If the tank is leaking on top around inlet pipes, or leak is coming out of weld around TP valve, then water heater must be replaced.
Copy following link for troubleshooting and method for prolonging life of water heater by turning off heater except to make batches of hot water.
http://waterheatertimer.org/Leaking-water-heater.html
You can buy water heater at local box store. $350 for gas and $230 for electric, then get store coupon or offer 10% less than sticker price.
Electric water heater is simple to replace.
Gas water heater takes more steps, but how-to step-by-step appears on following link:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Oct 15, 2012 | Water Heaters
How do I Remove Magnesium Anode ?
The following page has instructions and a link to a video:
http://waterheatertimer.org/Replace-anode-rod.html
How to:
Rods are installed in top of tank.
Most are located under a 2" round plastic cover located on top of tank.
Some anode rods are connected to hot water nipple
Read owner's manual to see location of anode rod
See list of water heater manufacturers and brands to find product manual.
Before starting, turn off heater source: electric water heater: turn off circuit breaker; gas water heater move control knob to pilot.
Close shutoff valve on cold water side of water heater
Open bathtub faucet to relieve pressure and let air into water line.
Open drain valve near bottom of tank,, and drain 2 gallons of water.
http://waterheatertimer.org/Water-heater-will-not-drain.html
Use 1-1/16" socket for hex head rod
Rod will be rusted in place, use generous amount WD-40
WD-40 spray is flammable and will burn so be careful around heat source.
Loosening rod: go slow and check that water does not seep up when loosening rod because hot water can spew out hole if tank is very hot ... it is important to drain enough water out of tank to avoid accidental scalding.
Install new anode rod: One source says/ use pipe compound on thread instead of teflon tape. Other sources say use teflon tape. Either way, tank metal and anode metal must meet, so rod will work.
Dec 23, 2010 | Water Heaters
My water heater has a bit of water from the top is(very small amo
thats normall it just lets of presure when needed which will cause a little water
Dec 30, 2009 | Rheem 81VP15S Point-of-Use Electric Water...
There is a small leak at the top of the tank. How
ease off any pressure millaput putty 50/50 hand rubbed to mjx clean defective area work millaput over defctive area smooth edges (wet finger) leave over night if possible job done best of luck
Oct 13, 2009 | Water Heaters
Hot water is running very slow
Definitely calcium is your problem. If you want to work on this your self turn off the power and drain the tank into a bucket, you will find lots of calcium in the tank. Rinse it out a couple times with fresh water, and vinegar.
May 07, 2009 | TitanNet TITANTANKLESS. COM PRESENTS THE...
Water Heaters Logo
110 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
