ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile. send the IMEI no to me and i will reply you with unlocking code. IF Problem not Solved So Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator Enter The Puk code and Yes Enter The pin code and Yes So Puk code Open and Problem will Quickly Solved
If it`s the original radio then the code will not be needed.
If it`s not the original radio then it will have to be electronically linked to your car...and this can only be done by your Main Dealer or a Radio Decoding Service
you use the preset one button (press it until the correct number comes up) for the first number of the code, the number 2 preset for the second number and so on until the code is entered.
You can only change your code once you give the old one. If you cant remember the opl one then you cant put a new one just like the password. Only wayout is to re-install the firmware thru your phone's service centre. But you may put another code which you may forget again. My suggestion is not to put any codes. If you have to because of the earth shaking consequences on loosing the data, then it should be such which you cant forget however hard you may try.
===================================Philips Renault Code Entry
Turn on the radio and the display will show 'CODE'
Use the steering controls for code entry.
Press the [ ¬] button then rotate the thumb wheel for the correct first digit Press the [¬ ] button then rotate the thumb wheel for the correct second digit Press the [ ¬] button then rotate the thumb wheel for the correct third digit Press the [ ] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen, press and hold the [¬ ] button for up to 10 seconds to store the code ===================================
