Question about Philips 19PR19 19" TV
My 19pr15 c122 will come on for a second then shut back off just wondering if its something fixable or should i just trash it
    President:
  • 2,992 Answers
It's seldom the parts that cost much, it's the labor to figure out which parts are causing the trouble that make TV repairs expensive. Many things can cause a TV to behave the way you describe, so I can't point out one or two specific parts. Even if I knew exactly what was causing the problem, you might have trouble getting the parts or lack the tools and soldering skills to replace them. It's possible to do more damage trying to repair a set without some experience. So while it's certainly fixable, it's probably not economical for this small of a TV. You could easily replace it for the same cost you'd likely face if you have a technician service it. Use this as an excuse to find yourself a new TV.
Posted on Jan 01, 2011
Machine suddenly shuts off during playback or record - is this fixable?
When something goes wrong during playback etc, all VCR's will shut down to prevent tape damage, or further mechanical damage.
There are two possible causes for this problem. One is there is some sort of damage to the mechanism, possible a plastic part that is broken. The second cause is the mode switch. This tells the electronics what position the mechanism is in. If that goes wrong the electronics might think it is in eject mode when it's in playback, for example, with things going very wrongs as a result. All are fixable if you can get the parts!
May 02, 2016 | Toshiba Televison & Video
Why doesn't it turn on?
Fixable but it will be a board that failed. You need to identify which one an replace that as well as the wire harness the fried.
Dec 15, 2015 | RCA LED46C45RQ 46 Inch LED Lit 1080p
PHILIPS MAGNAVOX MODEL 19PR15 C122 HAS NO SOUND
Check speaker. Audio circuit. Mute signal
Apr 01, 2010 | Televison & Video
Motorola c122 unlocked codes
You may purchase an unlock code for your Motorola C122 from a MOTOROLA UNLOCK CODE website. After entering your phone model and IMIE numbers on the site, the codes to unlock your phone in seconds will be provided to you.
Feb 09, 2010 | Microsoft LifeCam VX-6000 (68C-00001)...
When the monitor is hooked up it will come on for one second then shut back off. You can see windows open but it shuts off so fast. I checked and changed the cords no help. Is this thing trash?
Hi:
Usually when a LCD monitor has the problem that yours does, there is something wrong in the high voltage power supply board on the LCD monitor.
It is usually cheaper to replace it than pay for the repair, unless it is under warranty still.
Jan 22, 2010 | Samsung 225BW Monitor
TV struck by lightning
Looks like the flyback (high voltage transformer and probably the majority of the power board is kaput. It would be cheaper and probably worth your while to invest in a new TV rather than try to fix this one..
May 30, 2008 | Sharp 32C-240 32" TV
Philips magnavox model 25ts54 c122.
hi there, you do have a power supply section problem, check the bleeder resistor which is 100K ohms or up. do some test. ty
Dec 24, 2007 | Philips Magnavox 27MS343S 27" TV
Crackle, off, on, now won't come on.
Fixable! Bad IHVT ( flyback transformer ) Give me the service # off back and I can get you th part #..........T.
Oct 13, 2007 | GE 46GW947 46" Rear Projection Television
Philips 19PR19 19" TV Logo
66 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
