Question about Sharp R-5H08 Microwave Oven
I broke the START button and in order to heat I use the sensor button. Can this be fixed on the microwave? or do I have to replace? Any help would be appreciated. Thanks, Elaine
  • Sharp Master
  • 9,047 Answers
The part number for the Start button on this microwave was JBTN-B048MRF0, but it shows as being unavailable.
We may be able to repair it for you, though. Details here.
Posted on Jan 02, 2011
My sensor touch buttons don't work....any ideas why?
With Power on Microwave There is Light Blinking It Means Is Normal Power Supply Supply Problem,Not Reaching Front Panel Power Supply
Feb 07, 2014 | LG LMV2015ST Microwave Oven
GE Profile Spacemaker XL1800 Magnetron failed and replaced but now it heats too much for one touch sensor buttons...Basically the unit stopped heating. I replaced the Magnetron. I test by trying to pop...
You probably just have a bad humidity sensor (aka gas sensor).Also be sure the internal cooling fan is running. That's critical.
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are working.
To access and replace the sensor, you may need to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can find handy exploded views and order parts by model number here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Oct 21, 2011 | GE XL1800 1100 Watts Microwave Oven
Inside Light stays on and the Start Button will not work at all!
You probably broke the door sensor switch.
The part must be tested before replacement.
Parts can be purchased from Partselect, Appliancespartspro, or Repairclinic. Have a look on google.
May 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave not heating
You need to replace the whole door latch with an original part.
If it is working but not heating, then test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.If turntable is not running check also the door switch.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
You can also order from MicrowaveSvc , they also provide parts.
Mar 18, 2009 | GE Advantium SCA1001SS Convection /...
I have a Sharp Micro Wave Model R 1512 F that the start minute plus key is broke. This is the third time and I would like to fix it myself. I can not afford another service call on this one, How do I fix...
You can order a new and improved select button assembly here.
We have the service manual for this model and have uploaded it to our site here to help you.
That, plus the R-1500-series service manual here will help you safely disassemble it so you can replace the select button assembly.
Also at our site, we have a video available how to remove a typical over the range control panel assembly in under 5 minutes.
You will need the free Acrobat Reader to view or print it in case you don't have it already.
Oct 11, 2008 | Sharp Microwave Ovens
Microwave does not heat
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
Here is a helpful link you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/cap_test.html
Info on ordering Sharp UK parts / spares is here.
The best place to order Sharp parts in the US is Tritronics.
Aug 17, 2008 | Microwave Ovens
I have a microwave unit separate from my oven unit. After I replaced the microwave plate with a dinner plate (because it broke) the following happened after a few weeks: The micro wave suddenly did not...
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Please write back with your brand and model number if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 30, 2008 | Microwave Ovens
Sharp carosel R310FK-keeps going
control panel is hung up - replace panel and keypad.
Dec 28, 2007 | Sharp R-510HW Microwave Oven
Not heating
You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383 When a microwave is not heating and is making extra noise, it's usually a bad magnetron or high voltage transformer. But once you've looked over the documentation I pointed you to, let us know if you still have trouble.
Aug 25, 2007 | Amana HDC21 Microwave Oven
Microwave Ovens Logo
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Ed Mac
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
