Question about Falcon Radio Rc Helicopter
Hi my son has just got one from amazon we used duracell in handset charged copter as per booklet instructions it reved enough to lift off floor (just) then battery seemed to go flat ? Put back on charge but it revs sofar then cuts out ? Please help a fed up dad
  • 944 Answers
It seems the battery problem.Check if the battery is fully charged.Use volt meter to test it correctly.
If the battery is doing in the same fashion then it is called stoned battery.Sorry to say,You need to claim for a replacement.Since the battery is not used for many days this will problem will normally occur.The charges are being frozened up.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Jan 02, 2011
Spins to left, will not take off/lift?
GYRO Nano Hercules Unbreakable 3.5CH Electric RTF RC ...
www.amazon.com/Hercules-Unbreakable.../B00AAOJ...
Amazon.com, Inc.GYRO Nano Hercules Unbreakable 3.5CH Electric RTF RC Helicopter (Color ... you can remove the 8 or so screws that allow you to pull the fairing off, remove .... Also we purchased our helicopter from HobbyTron.com through Amazon and .... won't spin, so the entire helicopter spins, and doesn't generate enough lift to fly.
GYRO Nano Hercules Unbreakable 3.5 CH Electric RTF RC
Amazon.com, Inc.Nano Hercules Unbreakable Glow in the Dark 3.5CH RC Helicopter ... It can go forward, backward, up, down, left, right and hover. .... It worked for a few flights and now the copter will not fly off the ground. ... and ive had it for a year now and everytime I start it up and it takes lift off it starts to fly backwards but otherwise ok toy.
Hercules Unbreakable 3.5CH RC Helicopter - HobbyTron.com
Dec 26, 2015 | HobbyTron Nano Hercules Unbreakable 3.5CH...
Quad copter won't lift off ground
Maybe battery is not accepting charge. I would try using a new battery.
Apr 20, 2014 | Protocol Manta 4-Channel Radio-Controlled...
Nano copter instructions
How do I charge my Nano QX 18 Gram Quad-Copter?It came with a USB cord but I can not get it to charge.Do I have to go to a specific web site?
Jan 16, 2014 | Toys
Gyropter not lifting off after full charge
Mostly all the micro copters problem are the battery and the the pinion gear that's been worn out.
Check both of these part. Battery should at least gives out 350 mili amp. and the gear should touch the propeller shaft gear at the bottom of the copter.
Get a lithium ion battery for more power and longetivity.
Hope that helps!
Nov 20, 2011 | JCPenney Gyropter RC Helicopter
Hi my son just bought a Micro X Copter Alloy IV 4 channel, it worked at first but after just a few times it no longer will lift. The middle blades and tail blades are not getting enough power. It did not...
Maybe it is out of power an needs a charge? Also, if there is alot of pet hair, dust, and human hair, it could have gotten some in the axels in the blades causing it to spin slower, and could short circut the whole battery if you keep using it with the dust in it. I suggest taking all of the blades and axels and stuff off the main body of the helicopter and take all of the excess dirt and dust off. I hope this helped :)
Aug 22, 2011 | RC Micro X Copter Mini RC Helicopter
Air hogs pocket copter, brand new. Inserted brand new batteries into charger and controller per instructions. Plug the helicopter into charger and led blinks red as stated. About two or three minutes into...
You bought a defective mini copter, the internal micro relay is malfunctioning and I hope you could bring it back where you bought it. Replace it with a new one and let them try to test flight it before you go home.
Hope that helps you out.
Thanks for asking FixYa!
Aug 09, 2011 | Toys
Hawk talon v3 wont get enough power to lift off the ground after being fully charged. another hawk talon v3 rear tail rutter wont spin to go forward. how do I fix these problems in these two...
I too had the lift-off prolem and I fixed it by gently pushed the upper gear all the way up, using a nail through the bottom of the copter and a hole in the lower gear, while pushing the lower rotor down.
Dec 29, 2010 | Team International Hawk Talon V3 RC Indoor...
Lost Dynamic Falcon Mini Copter Manual/Instruction. What Does Flashing means while charging and why the green light isn't on?
The flashing red light means the batteries are low. The green light goes off when it's finished charging, or when there's not enough battery left to charge it.
Dec 21, 2010 | Atlus Video Game Consoles & Games
I have a nano copter blaster 3D. I have put new batteries in the remote control. When i switch the remot on I get a red light and nothing else happens. It was bought for some friends who returned it...
You have to charge the copter first. Open the cover on the remote control and plug the little cord into the bottom of the copter. Make sure the copter is turned off. Switch on the remote and you will get a green light which means it's charging. When it goes red (about 10 min) it's charged. Then uplug it, turn on the copter and fly!
Oct 10, 2010 | Toys
Falcon Radio Rc Helicopter Logo
105 people viewed this question
Top Falcon Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Falcon Toy Expert? Answer questions, earn points and help others
