Question about Honeywell HW628 Window Mount Fan
Is there any way to take back off to clean???
I was wondering if there was any way to take the back off to clean it?? What kind of tool do you need??
I had the same problem. I called Honeywell and they told me that it was designed so it could not be removed and I would have to send it in for repairs. When I told them it only needed cleaning, the woman told me they won't do that and I should by a new one. Right. So, I took it to Home Hardware and they were very helpful. Apparently, the screws at the back require a special screwdriver that is not sold to the public. But, they did it for me and replaced them with common screws. Now I can open it and clean to my hearts content.
Posted on Nov 15, 2008
What kind of spark plugs do I need for a 1999 Valkyrie f6 1520cc
Hi, Anonymous for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing and printing please click on the blue links below. Good luck and have a wonderful day.
1999 Honda Valkyrie Parts
Plugs NGK or Iridium
Honda GL1500 Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda GOLDWING GL1500 Owner Manual
May 20, 2014 | 1999 Honda F6 C Valkyrie
Gas problem fixed on my bike. Now the problem is keeping it running. It starts after a few tries but it stalls right out and than it's hard to start back up. I have an 1985 Yamaha 700 Maxium
I wonder what the fuel problem was. It kind of sounds like the idle jet, and/or low speed jet needs to be cleaned. Also while your in there, i would clean all the jets, and check the float bowl height.
Great bike I use to have a 81 XJ650J, hell of a bike, i miss it.
May 01, 2011 | 1985 Yamaha XJ 700 X Maxim
I have a HP compaq 6735s notebook and it currently has a virus on it called security tool. i was wondering how to get rid of it because whenever i try to open a security program to get rid of it the virus...
Hello
I would suggest a full format and a reinstall of the operating system.
At the links below you will be able to read step by step instructions on how to reinstall your Operating System.
Windows Vista
Windows 7
Hope this can be of help.
Kind regards
Andrea
Sep 30, 2010 | Computers & Internet
Yamaha CDC-765: sometimes skips when playing CDs
The problem is in the laser for sure. Try cleaning with a cd cleaning tool. It's the easiest solution because changing the laser is not always available solution.
Stelios.
Feb 21, 2010 | Yamaha CDC-765 5-Disc CD Changer
My 2005 yzf 600rt will not idle and is backfiring. I think I need to clean the carbs but cant find a repair guide. I have never worked on a bike before except changing the oil and wonder how hard of a...
well unless you know how to its best to leave them be if you strip the carbs you will need a tool to set them back up again plus if you take out any jets or screws that adjust the fule mix you will never get it running right again without the right tools to set it back up and a jet can be wrecked by bad cleaning
its your bike? but if you have the cash drop it into a shop for a good tune up
Jan 19, 2010 | 2005 Yamaha YZF 600 R thunder cat
I need engine rebuid diograms for a sthil fs55 strimmer
you dont need a diagram. i used to work for a place where we rebuilt all kinds of gas and electric power tools and etc.. my experiance from trimmers the exact same way you take apart you put it back together. and you dont rebuild the engine you replace the muffler, the sensor, the spark plug, the rotor,and you can really take apart the carb.and clean it and put it back on
Sep 05, 2009 | Garden
LOSING SUCTION
is brushes moving, if so it is clogged , usually takes a star bit to take apart to clean
Feb 07, 2009 | Hoover U5753-900 WindTunnel Bagless...
Press-Grip Clasp
I just pressed the green clamps with pliers (which was a bit tricky to get the pliers just right and wedged inside the washer), but it works. Then before putting the black ribber piece back in, slide the green clamps back on, a bit further back on the rubber than they need to be. Then push the connections of the black rubber piece back on and finally use the pliers to move the clamps back up into place. Hope this helps!
Nov 16, 2008 | GE WSXH208A Front Load Washer
Shure E3C
This isn't really a solution, but should be relevant.  If you think that cleaning might be the issue, don't be too afraid to really dig in there.  The part you see is just a cover, not the speaker diaphragm itself.  I've had the tip part fall off (well, sort of break off) and that whole assembly doesn't do anything but cover the speaker.  The real deal is pretty deep in.
Jul 02, 2008 | Shure E3C Consumer Headphones
High Heat but does not dry
Check the exhaust tube that goes out the back of the dryer. It may be clogged with lint. Ours did this about a month ago and and a thurough cleaning did wonders. I bought a kit from Lowe's with all kinds of attachments. It was really easy.
May 26, 2008 | Kenmore 62602 Electric Dryer
Honeywell HW628 Window Mount Fan Logo
313 people viewed this question
Top Honeywell Dryers Experts
Jay Finke
Jay Finke
ray gallant
Are you a Honeywell Dryer Expert? Answer questions, earn points and help others
