Question about Digital Peripheral Solutions Q-see Qt428-803 8 Ch Dvr System With 8 Color Ccd Camera
Ho do you do a factory reset because you forgot your admin password?
Forgot router password
there is a restore button on the back, this will reset to factory settings;
username: admin
Password: admin
Dec 15, 2013 | ASUS Rt N10 Ez N Wireless Router 5 Network...
I am trying to login as admin, to be able to change the default password and secure the signal, but the default username does not let me log in. I'm using 192.168.0.1, login-admin, password-(blank). H
Looks like you wil have to do a facotry reset. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can ssets-up form scratch.
Dec 14, 2011 | D-Link DIR-615 Wireless Router
I forgot the password for the 192.168.1.1 page what do i do
Please do the following.
1. If you have changed the default password you will have to reset router and the password will be set to the default password. To reset the router to factory default keep the reset button pressed for 15 seconds while the router is powered on the reset button is located on the back of the router inside a small hole which needs to be pressed using some pointed object like a pen or a pin.
NOTE** its importaint to note that if you reset the router to factory defaults you will lose all the configuration and you will have to reconfigure the router***
2. if you have not reset/ changed the password ever try using the following user name and password
username password
admin admin
system admin
root root
admin
System
root
Aug 18, 2011 | Gateway Wireless-B Router (wbr-100)
I forgot my Password for NETGear WGT624 Please help
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
or
if there is a small hole in the front or back of the router push a hair pin in to reset to factory settings
hope this helps
Jan 17, 2011 | NetGear WGT624 Wireless Router
I changed my GE DVSR admin password but forgot to note down how do i reset it to dafault/factory default
i changed my GE DVSR admin password but forgot to note down how do i reset it to dafault/factory default
Jan 11, 2010 | GE Home Security
Cant login never had username or password if i did i forgot
Depending on which revision you have there are two possibilities
Default Username is: admin
Default Password is: password
or
Default Password is: admin
If neither of these work - you may have setup a new username and password and forgot - on the router you will see a reset point - reset the router to factory defaults and the username and passwords above will now work.
If this helped you then please help me and vote kindly, thank you.
Oct 14, 2009 | NetGear WGR614 Router
Forgot password on d-link wireless router and now locked out
try master reset, then use either
username:admin
password:admin
or
username:admin
password:(leave blank)
Jul 18, 2008 | Computers & Internet
I forgot the router's username and password.
Try admin, admin. If that doesn't work press the reset button and it will restore the factory settings. You will have to reconfigure the router.
Jul 16, 2008 | U.S. Robotics MAXg USR5461 (738168036790)...
Forgot password have reset but still wont let me in.
First reset again your router to factory settings, just in case. Do this by pressing the tiny button at the back of the router with a pencil, this works for most of the routers. Then check the router manual or go to factory website and find out default setting for admin and password. some router works with 'admin'/'admin' or 'admin'/'1234'. check factory website.
hope this helps.
Feb 14, 2008 | D-Link AirPlus DI-524 Wireless Router
Password for belkin router
If you have the router, the default username and password is usually printed on the bottom if not try these.
Username | Password
Admin (none)
Administrator (none)
Admin password
Administrator password
Admin admin
Administrator admin
try these in any order and switch round passwords to usernames these are the default passwords, if these dont work, then a simple push button reset will sort you out.
Ben.
Feb 07, 2008 | Belkin (F5D7230-4) Router (587009)
Digital Peripheral Solutions Q-see Qt428-803 8 Ch Dvr System With 8 Color Ccd Camera Logo
700 people viewed this question
Top Digital Peripheral Solutions Home Security Experts
Lawrence Oravetz
Are you a Digital Peripheral Solutions Home Security Expert? Answer questions, earn points and help others
