Wifes new notebook wont connect to router comes up failed to connect but has excellent signal
  • 600 Answers
Try resetting the router (disconnect power for a few minutes) and be sure you are entering the correct passcode
Posted on Jan 01, 2011
Connected wireless to router, excellent signal, but unable to connect to internet.
connected to wireless router with excellent signal may not means you are connected to internet. make sure your modem provided by internet service provider has signal! connect your computer to modem directly bypassing router. If you are online that means your internet is functional. Then connect modem to your Linksys router and use your wireless to log on to internet.
Your router wireless signal active and excellent means you are connected to router not necessarily the internet. The modem supplied by your internet service provider with active internet should be connected to you router on WAN port!
good luck!!
Oct 07, 2011 | Linksys Wireless-G WRT54G Router
Why wont the belkin wireless router connect to my wireless mini notebook
Hi i got your issue
Yes, it will not connect in your wireless notebook as this particular model of belkin router is a "wired router" it does not transmit any wirelless signal ......
If you want wireless connection you can look for the new model of routers from BELKIN
Thank you.....
With regards.....
Priya
Oct 03, 2010 | Belkin (F5D5231-4) Router
Cannot connect with laptop although signal strength says excellent. Intermittent problem. sometimes it works then drops connection. Won't even connect when laptop is next to router.
Please power cycle the router by unplugging / plugging the power cord.
Try changing channels; default is 6; try 1 or 11.
Change your SSID: personalize it
SSID broadcast: Enable
Check the advanced wireless settings and make sure MAC filtering - DISABLED.
Reset the Linksys router by pressing RESET for 30 seconds should everything fails and re-configure. Firmware is another consideration BUT this is just a new release.
Regards,
Angel
Jul 08, 2010 | Linksys WRT160N Wireless Router
Cannot access internet, Acer Aspire 5315
Try this. go to firewall. click on exception, and then click "secure socket tunneling" this should solve the problem. If it did not work the first time unclick it again. re start computer, and re do the exception thing.
Jul 01, 2009 | Acer Aspire 5315 Notebook
Though it shows network signal excellent does not to the net wort
How is your router set up? Are you using WPA or WEP security? WEP is the newer encryption and I'm affraid 9500 doesn't support this. Would try update firmware and hope that Nokia integrated fix for this in to the update.
Rate me if it helped. Thanks.
Apr 14, 2009 | Nokia 9500 Communicator
I have recently moved house from a virgin broadband connection taking my router and lap top with me. My new home has existing virgin broadband. Having plugged everything in as should be my laptop finds the...
Try reseating te broadband connection to the router.
It soundslike your router works if it connects to your laptop with a great signal. But its not sending any information through.
Try reseating. if it does not work. you might need to do a fresh reinstall of the router. Usually the broadband connections attach itself to a mac address of a network card. If you recently put a new router the network cards MAC address is different and it might not send signals through. like for me for cable i have the same issue.
Try this let me know how it does. If any problems please let me know.
I hope this helps
Please Rate.
Sep 18, 2008 | Belkin Computers & Internet
Wireless connection to router
You will need a range extender to get strong signal
Aug 26, 2008 | Acer Aspire 3610 Notebook
Replaced Linksys Wireless-B 2.4GHz 807.11b Router and Wireless B 2.4GHz 802.11b Wireless-B Notebook Adapter with Linksys-N Ultra Range Plus Wireless-N Gigabit Router, and Wireless N Ultra Range plus Dual...
Try resetting your IP address:
The laptop may be trying to use the IP address from the old router.
1) Click Start (assuming Windows 2000, XP, or Vista)
2) Click Run
3) Type in CMD
This will take you to a black command box
4) Type in: ipconfig/release
The chart should show your IP address as 0.0.0.0
Once this has happened, proceed to step 5
5) Type in: ipconfig/renew
You should now see a new IP address listed.
Also note that you need to set up your network key (assuming that you are using one) on both the router and laptop.
Make sure that your router is set up to perform as DHCP server.
FW
Apr 30, 2008 | Computers & Internet
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
