Question about Acer AL2032WD 20" Flat Panel LCD Monitor
I got my monitor for christmas and it worked fine and to day i moveid it from my brothers room and i pluged it in and i pluged it into my laptop and it is on but it says no signal and it is pluged into both things.i made sure that it is pluged in and on but it does not work. What do i do?
  • 1,675 Answers
Hi what you will have to do is make sure you have swapped over from the laptop monitor to the acer monitor, as you do not say what laptop it is, i will give you an example of what you have to press to do this, if you look on your laptop keyboard there is a key that has FN on it, normally on left hand side at bottom of keys ( but could be anywhere as well ) then look at the F keys at the top, and see if you have either a key with 2 monitors on it, or a picture of a side on laptop and a face on monitor this is normally key F4, it also could be F3, dependent on the laptop make, all you have to do is press FN key keeping it pressed and then press the ( either ) F4 or F3 key, or what ever key that has the monitor icons on it, this will then switch to the main monitor and disable the laptop monitor, when you want to Finnish using the external monitor, just press the keys again in that order and it will go back to normal...hope this helps
Posted on Jan 01, 2011
I have a compaq presario s3040se desktop the monitor quit
Try turning on the monitor before the Compaq system box, if Win is doing what it should, it will 'find' a 'new device' and reinstall the drivers for it. It may not look right but you can change the resolution after it boots up.
Apr 22, 2010 | HP Compaq Presario S3040SE (DF222AR#ABA)...
Acer AL1916 monitor wont turn on
normally along the number keys are cymbals, you must look for one that is a wireless sign, then i think you must press a key with this key to enable it, normally its a fn key
Nov 29, 2009 | Acer AL1916W 19" LCD Monitor
Screen Works With One Computer But Not This Mine
Soundes likw interference do you have electrical high lines near that area.
Feb 13, 2009 | Gateway FPD1765 17" Flat Panel LCD Monitor
Xps desk top doesnt talk to monitor
IF i understand correctly
I believe you may need a new audio card in your desktop
they're not expensive
Jan 16, 2009 | Dell Dimension XPS 400 PC Desktop
I have connected my microtek lcd monitor to my dell laptop computer. the monitor is plugged into electric outlet. the green light on the front of the monitor blinks. and i get a report of "no signal" but...
Have you tried pluging in the monitor in to the laptop before even starting the computer or Putting the computer in to "Stand by" then pluging in the monitor and then bringing the laptop out of "Stand by" or yet when you do have the computer on with the monitor pluged in, try "Fn" and a button hat has like two screens on it with a small bar in between them? All these should work.
Jan 04, 2009 | Microtek 997M 19" Flat Panel LCD Monitor
NOO black xbox 360 screen and sound do not work and only day 4
Check to make sure all your cable is plugged in all the way, and if you are using the HD cable, that it is switched appropriately (regular TV to "TV" and HDTV to "HDTV"). If all that is well, call Microsoft, your system is under warranty and they will RMA it.
Dec 30, 2008 | Microsoft Xbox 360 Console
How to convert a Brother brand printer with a continuous ink?
Yes your idea of using a Continuous ink system is good and its really much cheaper compare to using the ink from brother, there is many people that are using that ink system and its working fine...
Dec 28, 2008 | Brother DCP-350C InkJet Printer
Lines on the Screen, shut down and will not turn back on
Hi, the issue may with the LCD panel. I work in DELL and have been getting lot of issues like this. It's called vertical line defects.. You can connect and external monitor and press Fn and F8 to toggle the display over to the Monitor. If the display is fine, replace the LCD screen. If the system is under wrranty, call Dell tech support and get a replacement or else call 800-288-4410 (out of warranty repair) department to send your laptop for repair. If the display is the same on the monitor, then the video card/Motherboard has to be replaced.
If this information is succesfull, then please rate!!
Sep 17, 2008 | Dell Computers & Internet
Wacko Dell E151FPB
that sounds like a computer problem, not a monitor problem.  Plug the 'old' monitor in and see if your computer will boot with it.
Oct 14, 2007 | Dell E173FP 17" LCD Monitor
Acer AL2032WD 20" Flat Panel LCD Monitor Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
