Question about Winter Sports
Just received a 23 ft field and stream ladder stand for xmas. No directions...does any one know what link might have directions on line? I am not sure how to put the top part together..only going by picture on box which is not the safest thing to do.
4 Suggested Answers
  • 3 Answers
SOURCE: need instruction for a 17 ft. cosco ladder
Try going on-line to the manufacturers web site if there is one. More to the point is what is it you want to do that you can't with the ladder?
Posted on Jan 16, 2009
  • 384 Answers
SOURCE: How do I reduce the height of a leylandii hedge
Ladder and chainsaw seems risky if your asking the question. A heavy boar between two ladders would be a safer way to get you to the proper height.
Posted on Jul 15, 2009
  • 32 Answers
SOURCE: how do i put up my field and stream ladder stand?
is it a self climber or fixed?
Posted on Nov 02, 2009
How do I work out the storage capacity in liters for my fridge Frigidaire FPC523TEW1?
Hello Howard;
My name is Peter. I am a retired field service refrigeration technician.
Near the top side wall inside your freezer there is a label that gives you the exact cubic feet. Your model number has a rounded off cubic of 23.
So,
23 Cu.Ft. x 28.316 = 651.218 Liters.
Mar 13, 2015 | Frigidaire Freezers
What is the fridge capacity in liters?
Hello Howard;
So,
Mar 13, 2015 | Freezers
What is a telescoping ladder?
Cynthia. The ladders Justin are referring to are not Telescoping Ladders. A telescopic ladder is one that collapses into itself like a telescope or a collapsible tumbler or "cup". Generally stands about 2-3' tall when completely collapsed and you can feed out as much of it as you need provided what you need in height isn't more than the ladders total length.
These ladders are GREAT and are typically used for inspections and cable installers. Some are rated for a fair amount of weight but I wouldn't trust it. We love using them and have been a great tool to have in the arsenal.
I have attached a photograph of one of our telescopic ladders.
Jan 23, 2013 | Tools & Hardware - Others
How far from the ladder are you supposed to stand?
The "toss line" is five paces away from the ladder.
Jan 14, 2013 | Sport & Outdoor - Others
G5rv lite installation instructions
A G5RV antenna is a popular ham antenna due to its cost, weight and ease of installation. The G5RV is a really a dipole type, that looks like a "T" with the top of the T as the main radiator consisting of a single conductor main radiator and the bottom of the "T" (also radiating on certain bands) consisting of a 2 conductor 450 - 600 ohm "ladder line" that terminates in a fitting that converts ladder line to a coaxial connector.
One of the most popular configurations is the inverted "V". Depending on the version of the antenna, the main radiator will be either 102, 92 or 51 feet long. The ladder line will be 32, 42 or 16 feet (respectively) in length and will require a coax feed length of 70, 70 or 40 feet minimum (again, respectively) to present the proper range of impedences to your manual or auto tuner (the G5RV REQUIRES an external tuner to present an acceptable SWR or impedence match to your transmitter on all bands).
The inverted V requires a mast as high as you can erect, located as close as centered between support sources (trees, buildings, etc.). Ideally, there should be enough room between the mast and the main radiator supports to allow the main radiators to be fully extended. Also, the ladder line should be able to hang straight down without being coiled on the ground at the base. This means you'd need a 32 ~ 42 foot mast at minimum.
The top of the mast will be needed to be fitted with an anchor or hook that will support the center insulator that provides strain relief, splits the ladder line and allows connection of the ladder line conductors to the single conductor main radiators.
Unroll the antenna on the ground. Connect the center insulator to the top section of the mast by the hook. Install "antenna lead stand offs" every 3, 4 or 5 feet. Secure the ladder line to the stand off to keep it from touching / wrapping around the mast.
Use UV resistance parachute cord to connect to and support the main radiator insulator, and pull the slack from the line, from a point as high off the ground as possible. Do the same to the other radiator, trying to match the height above the ground as the first radiator. Go back and forth between the two radiators (or have a helper - so each can be pulled slowly, and evenly together. Inspect the mast to be sure it is still straight. Loosen or tighten the radiator support lines as needed to allow the mast to stand straight.
Secure all lines, connect and run coax to the connector at end / bottom of the ladder line. and connect the opposite end to your antenna tuner connector labeled "ANT". Connect a short coax cable between the transmitter's "ANT" connector and the tuner's "XMIT" connector.
Set xmit power to 5 - 10 watts, transmit and operate the tuner - or set up your radio to use an external auto tuner. Tune for lowest SWR or reflected power. The internal auto tuner on many radios is only good for correcting up to a 3.0:1 mismatch or SWR. The G5RV will present mismatches far in excess of 3.0:1 on certain frequencies and bands.
Jan 12, 2013 | Radio Communications
What is Bcc & cc for..?
Cc stands for carbon copy which means that whose address appears after the Cc: header would receive a copy of the message. Also, the Cc header would also appear inside the header of the received message. Bcc stands for blind carbon copy which is similar to that of Cc except that the Email address of the recipients specified in this field do not appear in the received message header and the recipients in the To or Cc fields will not know that a copy sent to these address.
Jan 14, 2011 | Computers & Internet
Hi. Merry Xmas. Did not receive user manual w/
Thanks for the reply.
You can download the user manual from the manufacturer's website by clicking this link
Direct download link: http://www.polaroid.com/media/document/a330ENmanual20090603.pdf
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
Have a Happy New Year.
Dec 26, 2009 | Cameras
Need instruction for a 17 ft. cosco ladder
Dec 20, 2008 | Measuring Tools & Sensors
Compass dial turned opposite direction
you might be able to reverse the poles back to normal with a magnet but be careful not to scratch face or get it closer than you need to to the insides of the watch.
Sep 26, 2008 | Field and Stream F25SLUMI Wrist Watch
Winter Sports Logo
108 people viewed this question
Top Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a Winter Sport Expert? Answer questions, earn points and help others
