Question about Williams 2509612 Ceramic Mid-Size Heater
The poilt light is on but the unit will not come on is like no power
  • 111 Answers
Usually caused by an open limit switch, there little bottons with 2 wires check with ohm meter. if theres a button in center push to reset if you hear a click,then it was open and your good to go.
Posted on Jan 01, 2011
How do I light the pilot light on an old moffatt oven
iT SHOULD TELL YOU ON THE BOX WHERE THE RED BOTTON IS LOCATED. MOST WORK LLIKE THIS. YOU TURN THE DIAL TO PIOLT AND HOLD DOWN THE RED BOTTON AS YOU LIGHT THE POILT CONTENUE TO HOLD BOTTON DOWN FOR ABOUT A MINUTE AND LET GO IF THE POILT STAYS LIT THEN TURN DIAL TO ON. IF POILT DOES NOT STAY LET WAIT FIVE MINUTES AND TRY IT OVER AGAIN FROM BEGINNING
May 06, 2014 | Ovens
How do i light the poilt light on a comfortmaker
depending on how old the unit is varies... if you actually have a pilot assembly you will hold down the pilot valve located on the gas valve adn you would turn dial to pilot and push down red button or knob itself the stick a long match in pilot assembly area and lite...once lighted keep holding down for about 15 seconds to get thermocoupler hot adn then rotate dial to on...if it goes out star toperation again and if continues then the copper thermocoupler next to pilot assembly is dirty or bad... if you don't have a pilot assembly and unit is within last 10 years or so you may have a hot surface ignitor in there and it automatically glows on the call for heat and will lite..if your not seeing it its made of porcelein and could have cracked or went out.... some units also have spark ignition and originates from the board and then will go to a spark module ....repost if you have more questions a/c & heat servicer for 18 years...
Jan 08, 2011 | Heating & Cooling
Our Whirlpool gas range will light top (the burners) but the oven will not light.
dust could be on the poilt light blow it off with a air pump.
I hope i could help you out
Dec 31, 2010 | Whirlpool Kitchen Ranges
I can't get the stove to heat up! The pilot light is on and the burners all work
check the bottom pilot ligth in the boril at the back to the top that poilt ligth it for the ovens
Oct 18, 2010 | Ovens
The oven will not heat
sound like the poilt ligth is out.open the bottom you will see the poilt at the back to the top it will be shing try to ligth it from there
Oct 18, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
I just recently bought a house with a Tappan Gas Stove model TGF657 and I am having problems lighting the oven. I have never used or seen a gas stove before.
will be very careful went lighting the poilt ligth.ok make sure the gas it on and the knob on the sotve is off raise the hood you should see the poilt ligth between the burners ligth it with a matche in each one go to the bottom open the door there a poitl ligth at the back to the top ligth it
Oct 17, 2010 | Tappan TGF657 Gas Kitchen Range
My mp3 died and it wont turn on when i put it to charge.
my mp3 wont start but the light in on ,my sis poilt it n i don know how to fix it pls help me its dying
Apr 06, 2010 | RCA OPAL M4001 MP3 Player
I have a williams wall furnace model 5009622,and the pilot will not stay lit ,i cleaned the thermacouple,still no luck,i also then replaced thermal couple still wont stay lit,any other ideas thanx ,i was...
Assuming the pilot is clean and sharp. Before replacing the valve, clean any spade connections, those going up to the spill switch in particular. Clean and tighten all 4 connections. Good luck.
Jan 11, 2010 | Williams 2509612 Ceramic Mid-Size Heater
Williams 2509612 Ceramic Mid-Size Heater Logo
80 people viewed this question
Top Williams Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
