Question about Kitchen Ranges
Philco Oven, Type: E60SM/ALIM400TC Mod:F650D4W The oven turns on ok some functions don't work, when finished with oven and turn the knobs off it continues to run. Have to turn off at the wall and only when oven is completely cold it stops running when the power is turned back on.
How do i clean between the oven door and glass
Posted on Apr 04, 2013
  • 95 Answers
Many times the knobs get spun all the way around, and the adjustment screws on the backside of the knob, slide out of place. Try to "play" with knob, turn to a position where it will turn off. Turn off the breaker, and take the knob off, adjust the screws and you should be ok.
Posted on Jul 08, 2008
How do I turn the Miele oven on? Model is H6260BP
To turn on the oven, press the recessed On/Off button on the left below the rotary selector knob. Make sure that the system lock is off. (The display will show S 1 if it is on.) Press and release the function selector and rotary selector knobs if they are retracted. Rotate the function selector to the desired function icon (line up the dot). Then turn the selector knob to select the oven temperature. Press OK to start cooking.
Miele has the manual for the H 6260 BP oven on the product site on the Downloads tab: https://www.miele.com.au/domestic/ovens-1451.htm?mat=09514470&name=H_6260_BP . The direct link to the manual is https://www.miele.com.au/pmedia/ZGA/TX3587/10108150-000-01_10108150-01.pdf . See page 21 for a picture of the oven controls.
I hope this helps.
Oct 04, 2016 | Miele Ovens
Cant turn off oven in my stove Kenmore mod 3627526190
This is a major safety issue and I would not recommend attempting this repair yourself. Please contact a reputable repair service center.
Jan 14, 2015 | Kenmore Kitchen Ranges
Function selector knob loose
contact the bosch service agent for spares
Sep 03, 2017 | Bosch Ovens
Omega E60SM/ AC1M600TE gebruiksaanwijzing
the timer has to be on or the oven wont work
Jan 06, 2013 | Ovens
My older model electric hotpoint selfcleaing range, lower oven self cleaning function is not working. what could be wrong, maybe i didn't set a control knob correctly, don't have a maual for t
Back to the fifties! If the lower oven cooks normally, the heating element probably is OK. For self cleaning the normal temperature setting is bypassed and the heating element is set to a substantially higher level. Your oven may be unable to self clean because operation of the knob may not actually start the cycle. The thermostat could need replacing even though normal cooking is OK.
Sep 02, 2012 | Hotpoint Kitchen Ranges
I am looking for self cleaning instructions for a GE oven. MOD. VJ33VWLW-3 SER.ZH273130 VOLTS 120/208 KW 8.6 120/240 11.4 LR 27 TYPE B45 CAMCO INC. Made in...
You should have a selector knob turn it to clean then lock door with lever in the front select hrs on the timer should start up
Sep 18, 2011 | GE Ovens
Burners turn on sometimes as does the oven but then may not turn off
Hello, when you turn on one of the burner, can you hear some clicking while you turn on one of the burners? This is an electric ignitor, and when you turn one burner on all the burner ignitor will click.
It is possible, that you are turning your burners on the stove to quick. Take a look at one of knobs and you will see ignition--low---medium---high. To get the burning ignited the knob needs to be position at the ignition site. You'll hear it click-click-click and the burner will ignite.
Now, the oven. The oven ignitor is on a time delay. You will push the bake button and across the screen will say something like this "Please set oven temperature" You'll set the oven temperature to---let say 350 degrees---. Then the screen will say "push start button" then you push the start button to turn your oven on. Now, the screen will say "pre" this means that the oven is pre-heating the oven to your desired temperature. Before all this happens there is ignitor in the oven and it has a heater on the ignitor in oven. This heater will heat up to desired temperature and once it reaches the that temperature the ignitor will ignite and the gas will turn on.
Why--one would say for this procedure. The old kitchen stoves had a very bad habit of of flash over---that is gas will built up in the over and once the pilot light ignited the gas---wussh and it blow the oven door open. These ovens would sometimes huff too.
Therefore, take your time and your biscuit will be OK
I am sorry Sandan2. I didn't finish reading your question. Never mind on what I said here.
If the burners will not shut off sometimes, then there could a gas regulator problem.
One very important question. Is your kitchen stove using Natural Gas or LPG--liquid Petroleum Gas?
If it is using either type of fuel as mention above. It is very important that you contact Appliance repair person that is certified by the state that you live in that he/she is license by the state to work with gas appliances.
I wish you luck, but it very it important that you contact a certified Technician... Also, move the stove away from the wall and look behind it. There a black gas pipe and at the end is a brass valve, Take wrench and turn the gas valve off. The gas valve will have a stainless steel flex line attached to it, and the other end is to your stove. Don't use your stove.
If those gas burners and the oven are leaking gas. There is possibility to blow you and your family with your home up. Don't use the stove, Until you have it check out...please. GB you/your family...stewbison
Sep 07, 2011 | LG LRE30755ST Kitchen Range
We are renting a property with a Westinghouse mod 05-208307, never used it before, the setting have worn off around the oven nobs and don't know what they where pls help, can use over
The knob is the image of this link http://www.repairclinic.com/PartDetail/Knob-Dial-or-Button/5304441580/1063188 is pretty typical of all westinghouse knobs, that one shown is for westinghouse and perhaps can give you a good idea of the temp. set based on how far you turn it
Gene
Aug 13, 2011 | Ovens
Self cleaning frigidare oven FEF368CCTD
If this stove has knobs, Make sure the clock keeps time. If it doesn't you will have to manually turn this off. (DON"T FORGET OR LEAVE WHILE CLEANING) Make sure there are no large puddles of oil or grease on the bottom of the oven.If the oven is really dirty it may stink a little. Nothing but the racks can be in the oven.Press the lock button and slide the lock lever to lock the door. Set the stop time for 3 hours and turn the knob by the clock to auto. Turn the oven knob to clean. (MAY have to push to turn all the way to clean) It should start heating up. Let it finish and then cool down. It will not let you unlock or open the door until it is completely cool. Wipe out any remaining ash with a wet rag. ALL CLEAN!
Jun 28, 2008 | Ovens
Kitchen Ranges Logo
979 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
