Question about Dryers
Our gas dryer is working on individual cycles, but does not let the gas heat come on. DLG2526W LG gas dryer. Where do I find instructions to re-set thermal overload or check the ignitor for operation?
  • Dryers Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Jan 03, 2011
My LG DLG2526W gas dryer wont start
I had a problem like this and our fix was to reach in and turn the drum a half a turn and push the start button. it worked for us because the motor had a dead spot on motor and once moved pass that spot, it did its job. you may have a different problem but, try it.
Sep 03, 2014 | LG DLG2526W Gas Dryer
My LG TROMM DLG2526W dryer is not heating.
Check thermistors. Two in heating chamber and one or two in fan housing. Clean surfaces and check for continuity.
Aug 17, 2017 | LG DLG5932W Gas Dryer
LG dlg2526w gas dryer lp no heat but it tumbles
The first thing you need to check is that the gas line is on and you have electricity to the machine. The next step is to open it up and check the ignitor, since that is a high failure item on your machine, that is where I would start.
Jan 17, 2012 | Kenmore Dryers
My LG dryer DLG2526W flaskes the CK FILTER light, but will not start. The filter is clean. Whats up?
The check filter light will always flash whenever you turn it on. It's just a reminder feature. Starting problem can be many things. Possible broken belt, door not closed properly or control board issue. You will require a professional LG technician to diagnose the problem.
Good luck
Oct 01, 2010 | LG D2526 Gas Dryer
How do I change the orphus on my LG gas dryer model number DLG2526W
You have to get to the gas valve which is located in the front right bottom of the machine.  You will need to remove the top.  The screws for the font panel will be on the inside top and might be a couple behind the door.  If you need more detailed instructions let me know and I can send you parts of the service manual
Oct 25, 2009 | LG DLE0332 Gas Dryer
LP CONVERSION KIT
I think it would be useful to call in an plumber to do the job and i think you are on the right track.
Sep 14, 2007 | Dryers
Dryers Logo
184 people viewed this question
Top Dryers Experts
