Question about Samsung LN-R268W 26 in. HD-Ready LCD Television
HDTV Cable Box not working with HDMI connection
I have isolated the problem to the TV since it works on another TV with HDMI. (Although it has worked before on this TV which is the strange thing). When I try to change the source to HDMI on the Samsung LNR268W, the box is grayed out as if nothing is actually connected. I've tripled checked that everything is plugged in properly.
  • pickyp Aug 19, 2008
    it plain doesn't work. Even tried reversing the calbe ends. The samsung does not recognize the hdmi cable
  • Anonymous Feb 21, 2009
    Same exactly.  My HDMI worked great for four days on my Samsung A630 and then I got a grey screen.  Tried switching ends; tried getting new cable: nothing works. Further, with the cable plugged into the tv, the tv does not recognize that the HDMI is connected ---  if you press "source" on the tv remote and the hdmi slot on the tv is being used, then HDMI should be listed as one of the main options available; if not,then the tv is not recognizing it.
5 Suggested Answers
SOURCE: samsung lcd ln46a550pf3 no sound from hdtv reciever
ok your tv does not come with the very best sound, you have to get a receiver 7.1 or you can use the optical wire , that's if the system you are using has that option.
Posted on Jun 28, 2008
SOURCE: connecting HD cable box to DVR too HDTV
When I hooked up my HD cable box using an HDMI cable, I had to go into the cable screen menus and select HDMI output. You may have to do something similar when using an S-video cable. Your DVD recorder doesn't seem to have an HDMI input, so you'll have to use the S-video or (worst case) composite video (red, white, yellow cords). Your cable box may also be scrambling the signal so that you can't record. That may be why you can record by bypassing the cable box.
Posted on Jul 15, 2008
  • 93 Answers
SOURCE: HDMI Cable problem
Well, first you might want to try another hdmi connection behind your TV.If it appears to have the same message,you need to check your TV setup and be sure the HDMI video is active.
Secondly,go with the recommendation of the set top box.You will use component video cable to connect from your set top box component video output(Y PR PB) to your TV (Y PR PB) and see if that actually work.If so,just use the cable box for the time being and call your cable company for another cable box to replace this one!
solutiondoct
Posted on Nov 11, 2008
  • 7 Answers
SOURCE: hdmi grayed out/not available when cable plugged in
when you try to use your hdmi cable do you have the component your trying to use on? because the tv might need it to be powered up to recocnize the signal that, that input is in use
Posted on Sep 15, 2009
Sanyo 50in HDTV turns on fine, no picture or sound
How is your xbox connected to the tv? If its connected with hdmi cable. Unhook it from xbox and plug it into the back of the cable box. If nothing happens then try switching the tv input with the tv remote. Should have several different inputs. Hdmi,video,component,etc...
Feb 25, 2013 | Sanyo Televison & Video
My Home theater system was on with my TV. The video just went out audio is still on. I checked all my connections changed out a HDMI cable to the TV still no video only sound. Ran a HDMI straight from...
I appreciate that you did an isolation steps where the fault maybe by running a HDMI straight from your your Direct TV box.We could further steps by following mentioned below
1. Please make sure your connecting the HDMI cable on the right port
2.Please make sure you are using the HDMI cable compatible to the system.also try the supplied
cable from Bose.
3. If still does not work,please contact the manufacturer or contact the store where the item was purchased
Sep 04, 2011 | Bose Lifestyle 38 System
I have a Pioneer vsx-919 receiver an an LG TV. The problem is: Using an HMI cable I have hooked my cable box to an in port of the receiver, then put a an HMI cable from the out port of the receiver to an...
Assuming a single cause we need to isolate which single device is involved in all these failure modes.
"It comes out of both speakers" on what - the TV?
You don't say how the DVD interefaces with the receiver. Is the DVD feeding digital multichannel audio out at that time? Many DVD's are simple stereo until the show actually begins. You know that.
Try running an HDMI connection straight to the TV from the cable box. Result?
Substitute the other HDMI cable for the first one. Result?
If either one does NOT work satisfactorily we may have part of the problem isolated.
If they both work, the TV and cables are ok.
Attach the HDMI out of the receiver and IN to the TV and the HDMI from the Cable Box as before. Same result?
Can you try using Component Video out of the receiver to the TV just to change something in the equation? On my rig I 'see' no difference between HDMI and Component Video on my HDTV. A change in the result may help to isolate or work around part of your problem.
My $.02...
I'd recommend you go for minimal receiver involvement in the video side other than to send composite video to the TV from "Monitor Out" so you can set up and manage the receiver.
You can also send Cable- or Sat Box basic analog audio directly to the TV if it has inputs for audio. That way if you just want to watch the news or weather you don't need to fire up the Pioneer.
Your video sources (DVD, BD, Cable/Sat) will suffer fewer video anomalies if you send their best video directly to the TV and their best audio directly to the receiver. That way everything is handled only once by the best electronics you have for each function.
Dec 30, 2010 | Pioneer Audio Players & Recorders
How do I connect my hdtv cable box to the tv/monitor. There is no hdmi input on the tv.
Your setup has a TV/Monitor and a audio/video box. The A/V box is connected to the TV and other source inputs connect to the A/V box. Hookup your cable box to the A/V box either using component video (green, blue, red) RCA cables from cable box outputs to the A/V box inputs OR the A/V box also has a DVI/HDMI input jack which may work using a HDMI cable.
Select the proper source.
Aug 26, 2010 | Initial DTV372 37 in. HD-Ready LCD TV/DVD...
LC-26DA5U 26 in. HDTV-Ready LCD Television: i connect a hdmi cable 2 my hd cable box - the pic...
The cable box needs to be set to send different signals when using hd tv and standard tv. Usually a good setting would be 720p in hd and 480p in standard. The tv is working fine it is the cable box sending the signal. If you have another hdmi source such as a dvd player you may hook that up to show the tv is working just fine.
May 07, 2010 | Sharp LC-26DA5U 26 in. HD-Ready LCD...
My volumn doesn't work when using the HDMI cable
Your TV and the cable box may not be compatible via HDMI or the digital audio format of the cable box is not set to PCM (contact your cable provider for information on how to change this on your cable box... too many models to speculate). The easiest solution is to use the component connections on the box and the TV (5 wire - Green, Blue, Red, White, Red). This will give you HD and eliminate to question of compatibility. I hope this was helpful, best wishes.
Apr 22, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sony Wega Trinitron HDTV Blue Screen with Sound
Had similar problems with HD cable on dvd. swapping with another cable solved the problem.
Aug 11, 2009 | Televison & Video
Connecting HD cable box to DVR too HDTV
Jun 22, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Samsung lcd ln46a550pf3 no sound from hdtv reciever
Apr 10, 2008 | Samsung LN-T4665F 46 in. LCD Television
HDMI Connection
to narrow it down get the right cable and do your connection.if it does not work have the cable company take a look at your cable box.if that dont work then you can safetly say it is your tv.then it will be time to call in the repairman.
Mar 30, 2007 | NEC PlasmaSync PX-61XM2A 61 in. HDTV-Ready...
Samsung LN-R268W 26 in. HD-Ready LCD Television Logo
1,035 people viewed this question
Jerry Greenberg
Jerry Greenberg
