Question about Polk Audio AMR50 Computer Speakers
I plug the speakers in, but no audio comes out?
  • 27,725 Answers
Control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Posted on Jan 01, 2011
Hi - I bought sony speakers and need to know how to install them. I have a Lexmarkx2690 - color 3 in 1.
Unpack the speakers from the box and set them up how you would like them to go. There should be a power cable that needs to be plugged into the wall. Plug that in. Then there should be a green audio cable that comes from one of the speakers. On the back of your computer, there will be three or more audio ports. A blue Line in, a Green audio out, and a Red microphone. Plug the green speaker wire into the green Audio Out jack.
What do you need to know about the printer?
Jun 11, 2011 | Sony Speaker
Dell speaker connection color code needed
  • *Turn off your Dell laptop.
    *Connect speakers to the speaker control box. The speaker control box varies depending on the speaker system you have. Two-speaker systems will have a female jack on the back of one speaker that you plug the other into the second speaker. If your system has a sub-woofer, all of the other speakers will plug into it. The connecting cords are color-coded to the jacks on the back of the control box.
    *Plug an audio cable into the "Audio-In" port on the back of the control box. If the audio cable is color-coded, it will be green.
    *Plug the other end of the audio cable into the headphone jack on your laptop.
    *Plug the speakers' power cord into a surge protector to protect your system from power surges. *Plug the surge protector into a wall outlet.
    *Turn on your speakers and set the volume at a medium level. Be prepared to turn the volume up or down after you turn your laptop on.
    *Turn on your laptop and confirm that sound is coming from your speakers.
    Thanks for rating
    Good luck
  • Jan 25, 2011 | Dell Dimension 4600 PC Desktop
    I have a 32" LG
    Hello Undernet01,
    Yes, it's very simple. Connect the computer speakers to the headphone socket on the TV, then run a separate audio cable from the PC to the TV. A PC monitor cable wont carry an audio signal so you need to connect an RCA type cable or similar - depending on whether you have corresponding audio OUT sockets on the PC and audio IN sockets on the TV.
    You will then have sound from both the PS3, the PC, and the TV on the computer speakers. The TV speakers will automatically switch off when something is plugged into the headphone socket.
    Simples as pies.
    BElectric
    Dec 26, 2010 | Computers & Internet
    My speakers are plugged in, the error messae sounds are coming through the speakers but the sounds and audio devices say there is nothing plugged in and any media players say the same. I can't find any...
    look in the control panel for sounds and audio devices, if the error sounds are coming through, then the speakers are working, leave them plugged into that port, check your speaker configuration setting try setting it to stereo speakers. It also sounds like you may have it set to 5.1 and are only hearing the rear audio channel. problem being your two speakers connected to a 5 - 6 speaker configuration. Again, solved by setting the speaker configuration to 2 speakers (stereo) . Let me know the outcome. Thanks
    Aug 27, 2010 | Computers & Internet
    Speakers are plugged in but there isn't any sound coming out of the speakers, yet i know the speakers work i tried them on my laptop
    Things to check:
    1. Ensure you are plugging into the correct port. Some systems have both integrated audio and and expansion sound card. If it has both, the expansion card should be the port to connect the speakers. Generally all desktops use Green as the speaker jack color.
    2. Ensure the volume control is not muted. Set volume for 75%
    3. Ensure if the audio is integrated, that the audio is enabled in the BIOS
    4. in Control Panel, Sounds and Audio devices, make sure the sound card is the default playback device. Also ensure that Stereo desktop speakers are selected as the speaker tyoe.
    Mar 28, 2010 | Dell A215 Computer Speakers
    Speakers keep cutting out when they are plugged in and a high pitch squeal comes out of computer speaker
    How many Audio ports do you have in the back of your computer? Also, what Audio DRIVERS do you have installed in your computer? If you have REALTEK audio drivers, it SHOULD automatically recognize the speakers are being plugged in and change that ports usage over to speaker output, but not all drivers do this. It could simply be that you're plugging them into the wrong port audio port if you have 4 - 6 back there, as some motherboards do. Try different audio plugs and see if that works for you.
    Jul 06, 2009 | Logitech X-240 Computer Speakers
    I have boston ba745 speakers with woofer. The speaker wire coming out of the back of the woofer goes into computer and it's a wire with 2 plugs, a pink one and a green one. It doesn't appear to make any...
    The green plug is the main audio plug for the unit. It plugs into the green jack{output} on the computer. The pink one plugs into the pink jack on the computer if there is one. Google the manual for the speakers and you might find oyut what the use of the pink one is
    Apr 29, 2017 | Boston Acoustics BA745 Computer Speakers
    I cant get the rear speakers to play on my pioneer deh-p3000ib.
    Sounds like you have
    1) the rear speaker cable is plugged into the wrong colored hole
    2) the audio software thinks you have a subwoofer, but you don't? Check on the audio software for ways to configure the speakers, the latest chips auto-detect when you plug in a cable, and ask you what that was you plugged in.
    Jan 07, 2009 | Kenwood KDC-MP4028 CD Player
    Confused need help!!!
    i need the watt of da stero DC-Z92
    Oct 31, 2008 | Insignia 3-Way Indoor/Outdoor Speakers...
    Open Questions:
    Polk Audio AMR50 Computer Speakers Logo
    77 people viewed this question
    Top Polk Audio Audio Players & Recorders Experts
     Grubhead
    Grubhead
    ed_dantes
    Level 1 Expert
    Are you a Polk Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
