Is Peterson Model G10-24/30-15 gas logs for vent free fireplace?
SOURCE: Need Instructions to use Fireplace Gas Logs
There should be a set of metal cards attached inside the fireplace.
First you should read everything there.
I know you have to first light the pilot light.
And then there should be a wall switch.
The problem I have currently is that it won't stay lit when the artificial logs are there.
Posted on Nov 23, 2008
  • 2597 Answers
SOURCE: Bad odor from vent free gas logs.
it could be leaking when the fire place is on you said you checked for leaks was this to the burner as well ? it sounds like unbrunt gas check the burner , hope this helps , are you feeling sick or headaches as this would b e fumes ?
Posted on Jan 14, 2009
mrgrzz
  • 88 Answers
SOURCE: Black sot from vent free gas fireplace
Thanks for your question,
your problem is either impingement on your log set, or a product of incomplete combustion, if you notice soot on your logs, then you will need to take them out, clean them, and reinstall them as to not have the flame touching them, you will need to clean the burners as well, make sure nothing is laying across the burners, as this too will cause sooting, as far as incomplete combustion, was this model a natural gas converted to propane or the other way around ? if so who ever converted it, did they adjust the gas valve according to specs? improper adjustment will cause sooting or hooking up a natural gas unit to propane will do this too, I will recommend using (Rutland White Off) to remove any soot from your glass, it works fantastic for this ! any ace hardware will carry it, please do not use windex or any other cleaner on the glass as it will more than likely leave a rainbow affect on your glass once the glass heats up, hope this was helpful to ya, please rate this solution, thanks agai
mr.grzz
Posted on Jan 25, 2009
  • 17 Answers
SOURCE: Pilot on logs won't stay lit
Hold pilot button longer. if this doesn't work your Thermopile has gone bad and will not generate enough Millivolts to keep gas valve pilot open. A new thermopile will generate 750 millivolts. It cost less than $20 dollars but is difficult to replace. You should call a certified technician. They will charge you about $100.00
Posted on Oct 27, 2009
SOURCE: Need user manual for Temco Model ADL36-2 Vent Free Gas Fireplace
Look behind the ceraminc logs chained to the burner frame. They are metal plates with instructions. That is how mine is.
I am looking to get new doors for this model, no luck looking online. Any ideas?
Posted on Mar 04, 2010
Wind blows out the gas logs
I am sorry, but there is insufficient information to give a proper answer. If it is a vented logset, is it in a vented indoor firebox/fireplace or an outdoor fireplace?
Jan 11, 2016 | Majestic Fireplaces Majestic VWF24NMD 24"...
My vented gas firs place keep gping into flame lift off. Hos do i fix this flame lift off. My gas log pro says i have to take the box out.??
I would suggest looking under the bottom louver of your fireplace as you have a b-vent or direct vent gas fireplace. From the looks of it alone it appears as its an early model Heat-N-Glo fireplace. If you flip down the bottom panel, where the two gold strips are at, underneath the gas valve you will find a sticker or a plate that has the model, manufacturer, and serial number. I work for a manufacturer that has been in the fireplace business for over 30 years and I'm betting $10 to a donut that is a Heat-N-Glo fireplace. Once you get the model, manufactuer, serial number, and date code sometimes you can search at www.heatnglo.com for AUTHORIZED dealers who can service your fireplace properly instead of a chimney sweep who may or may not be qualified to "trouble shoot" what is going on with the fireplace. It looks like an 8000GDV to me.
Best guess is a new pilot assembly if its a direct vent. If its a b-vent then a high limit switch might be needed as well with it cutting off that fast. It also could be a flue disconnect. Long story short I would find out the model, manufacturer, and then get on the manufacturer's website or call them to find out an AUTHORIZED servicing dealer for your fireplace. I hope this helps.
Apr 08, 2014 | Home
I have mislaid the instructions for my Genesis Miami gas fire, and need to relay the ceramic logs. can anyone please help?
This will depend on whether the fireplace is vented or is vent-free. Vent-free gas fireplaces are sold as a kit with the valve, burner, media (logs, glass, shapes, etc) all designed for a particular placement to work together to reduce dangerous chemicals. A vent-free burner and valve cannot have the logs removed and replaced with some other type of ceramic gas log because the exact placement of the logs is designed around the ports in the burner where the flames rise to minimize carbon created from the flames touching the logs.
If your fireplace is vented then the pull of the flue will remove dangerous fumes created by the same placement so there are no rules about re-arranging or replacing "media". If the fireplace is vented then you could use other log-placement-guides to identify the type of log and where it belongs with little worry because vented logs are designed to be able to have some adjustment anyway.
If vent-free and without a manual, an educated technician should do this for you because the BTU setting on the valve must be compared to the types of burners, port placement, size of ports, amount of ports and flame height. After this examination, someone familiar with the various hidden "tongue-and-groove" etchings in different types of gas logs can figure-out where to place the logs. They may have to test the fireplace burning once or twice to get it exactly correct but once you understand the idea of how a vent-free gas log diminishes the carbon-output of the amount of gas flowing through the burners then it is only a matter of watching the flames to see where the logs could be and comparing the size and layout of the logs to find the best fit.
Feb 02, 2014 | Grilling
36ECMII pilot light won't light
If you go to this link http://fmisupport.hcents.com/supportdocs/54024F.pdf it will take you straight to the owner's manual.
Now the gas log set is completely seperate from the fireplace. You would need to find out the model of the gas log set as any manufactuer of vented gas logs can go in this fireplace. Just for clarification the brand is actually Coleman but it was made by FMI. Now, the SPVBPD is a direct vent gas log set that was only designed to go into either the Amity, Oxford, or Victor hearth gas stoves. If you have the SPVBPD burner in a 36ECMII then you honestly need to remove that log set, as it was a burner only rated for direct vent fireplaces, and get a set of 18" LP vented logs. If you look at the link below you will see the owner's manual for the SDVBND. These logs need to be removed and you can go with any 18" vented log set. I suggest Peterson (http://www.rhpeterson.com/realfyre/vented-series/)
as they have the widest selection of logs and biggest array of dealers. Good luck.
Desa Tech SDVBND Owner Operation And Installation Manual
Jan 04, 2014 | Fmi Fireplaces SDVBPD Direct Vent Propane...
Vent-Free Gas Fireplace Turns Off
check pilot light to make sure properly in place with thermocouple check gas feed for proper pressure and new doesnt mean free from defects -bad valve,thermocouple,temp sensor
Mar 04, 2010 | Heating & Cooling
Gas logs while turned on seem to fade, nearly go
you must keep the burner and the pilot light area clean and free of dust also,the area where your burner gets air most of the time it has an adjustment to give it more or less air.I have had my dyna glo vent free model for 8 years.A good cleaning in late fall with low pressure air and 1 or 2 times through the winter depending on conditions of use.
gatesmason88
Jan 07, 2010 | Napoleon 36" Zero Clearance Top/Rear Vent...
need a fireplace log for temco fireplace, serial number 10807, model number adl 36-2. middle log is missing.
Dec 21, 2009 | Computers & Internet
I have a Peterson Real-Frye ceramic vent-free fireplace/ log set in my bedroom and my problem is that the log set constantly shut off and the piole goes out. What is my problem and how can this problem be...
there is a thermocouple which is a piece of metal that sits in the pilot flame if this is not in the flame the pilot will go out if this is bad the pilot usually will not light or stay lit let me know if this is useful or of any ?'s
Jan 06, 2009 | Heating & Cooling
Nov 03, 2008 | Heating & Cooling
Heating & Cooling Logo
56 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
